Question about Kenmore 24032\24036 Top Load Washer
Kenmore wash basket
The wash basket is banging into the sides. Even after I remove the clothes.
  • 172 Answers
Hi pagrzych,
If the tub is getting out of ballance you can first make sure the rear automatic feet are leveled by tilting the washer forward and dropping it back down, the rear feet are made to automatically level when the machine is tilted forward. If after leveling you still have a problem the kenmore washers have springs that center the wash basket into place. Pull the washer out and tilt it back you should be able to see the springs on the back bottom of the wash tub. The are directly behind the motor and transmission. These springs can be easily replaced if broken or if they have came out of position. Good luck with your repair and I really hope this helped you. Please rate me if I helped.
Mike Anderson
Posted on Oct 28, 2008
Basket is out of balance and makes loud banging noise
I have a Kenmore 24832200 and it was doing the same thing and it was because one of the springs had came off the tub...Hope this helps...
May 21, 2010 | Kenmore 24902 Top Load Washer
There is a banging during spin cycle and clothes come out soggy-wet. Checked the coupler already, looked fine. Please help??
take the adetator off. and check the shaft of the transmission. possibly your drive block and basket drive are stripped. if it's just your drive block no prob but if it's both major surgury.
get a putty knife and take the cap off
under lid of agetator you will either find a 7/16 bolt or you will find a 1/4 inch drive socket
either way remove
then the agetator will slip right off.
next if you have them remove the 2 peices on the shaft you will see the drive block and the 2 ears of the basket drive.
turn the basket with your hand
what happens does it make the sound?
let me know if this helps or if you need more help?
Apr 05, 2010 | Kenmore 22422 Top Load Washer
Kenmore 80 series model 110 after wash clothes are left soaking
when empty and off, open the lid and see if you can rotate the inner wash basket by hand. if you can easily, then the clutch is worn. This will prevent the basket from going into a high spin and wringing the clothes out. Replace the clutch by removing the top control panel, removing the clips that hold the cabinet, pull cabinet off, remove drain pump clips and pump, remove motor clips and motor, remove transmission (3 bolts). Now you will have access to the clutch, replace as needed, reverse dissasembly to complete. remember to unplug.
Jul 01, 2009 | Kenmore 22422 Top Load Washer
Kenmore front laoder washer with loose wash basket
Highly likely that either your bearings or spider arm has gone out, this is no easy fix. You can 'search' above or click on 'troubleshooting' in blue to browse (which is good)
Try these sites for spares.
Feb 26, 2009 | Kenmore 46462 Front Load Washer
Whirl pool washer bangs when in spin cycle
if new did you remove shipping strap in back..the unit cant lean more than 2 degrees..make sure clothes are even in tub..try to wash clothes alike..
Dec 25, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Thumping and banging
make sure all shipping pins are out the tub should move all around from side to side if it level still bangs its eather the balance ring top basket are there 3 slides on a plate above the motor just put some silacone oil on tham move around
Feb 09, 2008 | Kenmore 24032\24036 Top Load Washer
Washing machine
This sounds like the brakes have gotten some residue on them and are grabbing way too hard. The banging is the tub stopping too fast and the torque from this makes the tub bang into the cabinet. Just one bang at the end of a spin. Is this correct???
Nov 25, 2007 | Kenmore 23012 Top Load Washer
Kenmore washing machine 110.24852300
needs to find a regulator for Kenmore washing machine
Oct 08, 2007 | Washing Machines
Washing Machine Suspension Problem?
smirkin, the question here is if the basket is listing against the tub or the whole tub and basket is listing. If the basket is listing and banging around it could be the drive block has worn or broken. I will attach a photo of one. If the whole tub is listing it could be a spring that broke. You can remove the front panel of the washer by pressing in on the two clips on each side of the washer top, The front panel should drop and pull out. You can see if any of the suspension sprins broke. The drive block is located under the basket. The agitator and basket have to be removed to change it out. Take a look at the back
Sep 07, 2006 | Whirlpool LTE6234D Top Load Stacked...
Kenmore 24032\24036 Top Load Washer Logo
103 people viewed this question
Sal De
 Brian Main
Brian Main
