Question about Electrolux Dishwashers
My dishlex dishwasher starts then every 2 minutes flashes 10 after restarting i have cleaned out discharge tube and pump no difference what could it be it does wash after awhile then goes back to beeping and flashing 10 water pressure all ok
SOURCE: Dishlex dishwasher
I have the same problem and the main conrol board was replaced. No Problems since.
Posted on Jun 11, 2007
  • 17 Answers
SOURCE: vulcan dishlex mark 8 leaking water from bottom front door in wash cycle.
try adjusting the feet at the front of your dishwasher so it leans back slightly to keep the water towards the back of the washer
Posted on Dec 11, 2007
danekeeper12
  • 6 Answers
SOURCE: Dishlex 500E dishwasher won't drain.
keeps washing ????? is it stuck on the wash cycle? is this what you meant?? any way simple things first. suction blocked....Discharge blocked? sometimes hoses keep junk in them that blocks the goesinta and the goesouta.
if stuck in the wash mode unplug the thing for 3 minutes or more to reset...try again.... reset again....
bad new parts----- that always sucks!!!!!
Posted on Aug 15, 2008
SOURCE: dishwasher flashes on Fast Wash
I am hoping I have just fixed mine with same problem. Couple weeks ago started stopping at start of cycle with fast button flashing. Check filters so one on top of unside machine and one on tap if you have one on there. Mine were blocked but still wouldnt work. I pulled out machine to find a kink in the water pipe. I have straightened this out and up to now its working. Fast button flashing refers to water inlet problem.
Posted on Aug 22, 2008
SOURCE: dishlex global 500 rinse and wash problem
This was due to a faulty pump motor which I have now replaced.
Posted on Jan 21, 2009
Dishlex dx 203 buzzer
solenoids that control water flow (taps) buzz when failing Check out the water in solenoid.
May 26, 2013 | Dishwashers
Dishlex dishwasher won't complete a cycle. Number 60 shows up and a small flashing line. ??????
Drain pump is blocked. .If you are good with tools you can clean it yourself. Let me know
Mar 28, 2013 | Dishwashers
Hi there, we have had our dishlex 300 dishwasher switched off for a while and today I turned it on. I started a cycle and it stopped after a few minutes and then the Eco button started flashing. I opened...
Hi just read your posting.Now the reason these dishwashers flash ECO is because there is either water in the bottom tray or your drain pump is open circuit.Is the machine making a pumping noise when it is flashing the ECO light,or is it completely silent?Please reply on additional information and I am sure I can help you.Looking forward to your reply.
Sep 12, 2010 | Dishwashers
Dishwasher wont work
hi
Try to access the pump hose and remove blockage.If that does not fix the problem you will have to replace the drain pump.
Mar 28, 2010 | Dishwashers
Hi, My Dishlex dishwasher DX 302WB ia showing 10
check this
1)blockage in boiler tank.(cleaned)
2)water pressure is less.(check solenoid filter)
if it's programmed in timer mode within the period it must reach the water level in the tank due to this also it may happen.
Jan 06, 2010 | Electrolux Dishwashers
Dishlex 300 eco light
pump auto starts if overfull
sound like the machine is overfilling
check the level ,u may need to clear pressure line
or it may be bocked with gunk
if u dont know call for service
it shouldn't be a major.
Jun 16, 2009 | Dishwashers
Dishwasher stops after 10 minutes inlet/drain light flashing
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer
Replace if defective (note: uncommon problem).
May 31, 2009 | Miele 24 in. G646SC Plus Free-Standing...
Hotpoint FDW60 flashing eco light
if the eco light is flashing, this indicates that saftey float switch has activated in the base of the dishwasher usually caused by a leak, a polystyrene float activates a microswitch which cuts of the water inlet supply
Mar 28, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Dishlex Global 300 Dishwasher
Thomo, make sure the sprayer holes in the spray arms are clean. Grains of rice seem to be a dishwashers biggest enemy as they don't desolve and eventually end up lodged in the spray holes. The holes at the end of the spray arms are the ones responsible for the washing out of the soap powder from the dispenser, if they are blocked this does not happen.
Hope this helps
Cheers
May 29, 2008 | Tecnik 24 in. TKD795/3 Built-in Dishwasher
Dishwashers Logo
21 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Garth Jackson
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
