Question about Dishwashers
Homeking HL13 dishwasher showing error E3 - Dishwashers
  • 1314 Answers
SOURCE: Error e3?
i need your serial num its important 17
Posted on Jan 04, 2008
SOURCE: Baumatic BDW13 14 dishwasher SHowing E3 Fault
word_answers.gif I had the same problem and changed the two thermostats on the base and got it working. You can get them from partmasters.co.uk (thermostat protector) cost 17.99. They just screw in and are dead easy to fit
Posted on Jan 23, 2009
  • 4 Answers
SOURCE: error e3
Drain pump probably not working. Put machine on cycle 7 and it should turn on the drain pump straight away. you can hear this near the bottom of the machine. if it is silent hten the pump probably needs replacing. I repaired mine be removing it and then dismantle the magnet from the tube then give it a good clean out.
Posted on Mar 02, 2009
  • 4 Answers
SOURCE: SHOWING E3 ON DISHWASHER
Had the same problem (apart from the code) and the answer is to stop putting plastic in the machine ! It seems the dishwashers need the heat radiated from the Ceramic plates, stell knives etc to help dry. The plastic simply absorbs some water and then your dishwahser spends most of its drying time trying to get that water out again. Also Plastic doesn't radiate any heat to help. As soon as we stopped putting plastic plates and tupperware containers in, hey presto the dishes are drying again
Posted on Apr 13, 2010
SOURCE: Delonghi DW 47s dishwasher shows E3 error code
My DW67s also did this. I assume they are very similar models. According to the instruction manual, E3 means longer than usual water heating time or water not heating.
The heating element is not like the conventional one like what resembles the element in an electric oven. Instead, the element wraps around a water pipe and heats the water while one of the pumps circulates the water. That pump can become stiff due to lack of use because of a rubber seal which can get dry and tight if not used for long periods of time. Ensure the machine is unplugged, tap is off and emptied of dish racks and water before laying it on its side. Access is via the underside cover. Simply free up the pump again by rotating it with your finger. A sensor which is screwed onto the side of the pump can be removed for finger access. If you feel much resistance in the rotation of the pump at first, then after it becomes looser, then you have probably solved the problem. If it is really jammed then perhaps you have a chicken bone or something stuck in it and requires further disassembly. If it was already freely spinning and the problem isn't solved then perhaps the water heater itself isn't working or the pump motor is burnt out or an electrical connection somewhere is faulty.
Posted on Jan 31, 2011
I have a Samsung Dms300trw dishwasher shows e3 error how do I fix this
In the manual I have for this machine model E3 means: Longer heating time but not reaching required temperature. The possible causes: malfunction of temperature sensor or of heating element.
Apr 27, 2016 | Samsung Dishwashers
My dishwasher gives an E3 error
The E3 error code is not a defined error for this dishwasher. If you are sure it is E3 then best option is to give the controller a reset. This is done by
Press the Delay Start + Normal + Power keys at the same time for two seconds to enter Service Inspection Mode.
- "ALL" is displayed for the first three (3) seconds and then "t1" is displayed.
Press OFF at this stage. Do not attempt to run the inspection as this could damage the dishwasher unless you are familiar with the what each mode does.
If the Error E3 keeps coming back then call the Samsung technician.
Apr 15, 2014 | Samsung DMR57LF Builtin Dishwasher
Error code E3 on Samsung DMS500TRW dishwasher
3E error in Samsung dishwashers normally relates to high temperature error. This means the dishwasher is detecting over 80deg C water temperature. However if it is 5E that means drain error. If your dishwasher is draining correctly then please check the error again.
Apr 14, 2014 | Dishwashers
E3 Error
the E3 error is a result of water temperature not getting to a nominal value within a particular time. This could be caused by several factors like heater faulty, wash pump not working well, wash arms not circulating water as required. Need model number to help you further pin point if possible.
Refer this site for 60 inch dishwasher and this site for 45 inch ones.
Jan 02, 2013 | Smeg Dishwashers
Dishwasher showing e3 error
E3 error arises due to the malfunction of temp sensor or the heating element. Check for the thermostat.
Jul 02, 2012 | Baumatic 23 in. BDW13 Built-in Dishwasher
My currys essentials cdwtt10 dishwasher is showing an error code E3?
https://www.google.com/url?q=https://webcache.googleusercontent.com/search%3Fq%3Dcache:OPXBPu7tuokJ:http://www.buyspares.co.uk/images/mediator/1513/1)%252520instruction%252520manual%252520cdwtt10_ib_final100413.pdf%252Bcdwtt10%26gbv%3D1%26hl%3Den%26ct%3Dclnk&sa=U&ei=LyZwUZH_JOOM0AXIsIDoCg&ved=0CC4QIDAEODw&sig2=6sN7aESIiy5pjbjk2Hk34g&usg=AFQjCNH_UPwOjOW7e2lIRMSJj2ik3P7Ukg
Feb 25, 2012 | Dishwashers
Hi - have a kenwood KDW125L3A and is showing error E3 - help please. Ricardo
E3 is a temperature error. There are two thermostats,90 degrees and 78 degrees. This requires removal of the ride side of themachine to access. The other signal for the E3 error is the heating elementitself. If the water isn't heating at all, either the element or the 90 degreestat is faulty. You can change both and none of it is difficult to change for amoderately competent.
Jun 03, 2011 | Kenwood Dishwashers
E3 showing on Kenwood model KDW243A
E3 means longer heating time. Usually this indicates the heater element has failed.
Aug 01, 2009 | Bosch 18 in. SRS45E02 / SRS45E08 Exxcel...
LG LD-12AW2 ( Not 12BW5 ) Error code E3 shows.
WTF, do you have any solution on this stinking website
Sep 06, 2008 | LG 24 in. LD-12BW5 Free-standing...
Error e3?
Apr 02, 2007 | Maytag 24 in. MDB5600A Jetclean II...
Dishwashers Logo
330 people viewed this question
Top Dishwashers Experts
