Question about Refrigerators
Heaps of frost/ice in freezer: Whirlpool wro34uw
I've had my brand new Whirlpool fridge/freezer wro34uw for over a year and it's been great. Just the past 2 days, heaps of ice has accumulated on the floor of the freezer - it's as if someone spilled a glass of water in there! (They didn't). Have removed the ice once already today, and it's back again this evening. It's not connected to water supply (just the power point) so I can't figure out where all the water is coming from. The fridge often makes cracking or popping noises, and little whiney noises (has been doing so since we bought it). Any tips?
    Problem Solver:
  • 18 Answers
You probably need to fully defrost the freezer. Switch it off for at least 24 hours and collect the water as it defrosts. Do not try to scrape it as it can damage the product. The cracking and poping noises are most likely the product trying to auto defrost. It is probably too iced up for Auto defrost to work which is why you need to fully defrost. Good luck.
Posted on Feb 20, 2012
Whirlpool fridge model wro34uw leakage help please. I've noticed that most people that have posted have water hooked up and ice/water dispensers - my fridge doesn't have these features, just a...
At the back of the fridge check for a small drain hole that allows the water to flow out to the top of the compressor They do block up from ice and food residue (peas -milk etc) I would have a very serious talk to the rental agency as the fridge repair is the responsibility of the land lord as it came with the property. Ask for a new fridge or a good serviceable fridge. The freezer door gaskets are probably not sealing ( gone hard) allowing air in with the air moisture turning to ice.
Jun 25, 2013 | Refrigerators
My fridge freezes milk and everything in it
If the fridge is freezing everything, try this before thinking it's the thermostat first turn down the temp gauge in the freezer, not fridge to about medium, still a bit to cold turn down a little more. It save me heaps
Aug 13, 2012 | Whirlpool 21.0 cu. ft. Top Freezer...
My whirlpool frost free fridge freezer's alarm keeps going off, ice-cream doesn't freeze?
Check condenser is clean, fans working, thermostat set correctly, try to check internal temp with digital thermometer
May 17, 2012 | Refrigerators
Fridge too cold!
don't forget that just turning down your fridge temp dose not mean your problem might be over yet. the freezer setting may also be too high & that will affect your fridge temp as well. i set both my control settings to around 50% of what is on the scale & that works perfect for my 7 yr old fridge. also, very important, is make sure the freezer portion is going through it's full defrost cycles, or it will freeze the upper portion inside the fridge. you should not have any frost build up in your fridge, nor should you have any in your freezer. that's why they call them FROST FREE. try the slow temp decrease over a period of a few days & hopefully that will work for you. good luck.
Dec 01, 2011 | Refrigerators
GE 17.2 freezer on top fridge on bottom. Freezer is cold, but fridge is warm. Help!
Is there any frost buildup on the rear panel inside the freezer? If so you have a defrost problem of a bad defrost heater, defrost thermostat, or defrost timer/ control board. If no frost then you probably have a clogged defrost drain. Remove the rear panel to access drain hole.
Nov 09, 2011 | GE 17.2 Cu. Ft. Top-Freezer Refrigerator
8 year old Whirlpool Gold refrigerator: Freezer icing up. Found ice on shelves and on the bottom under the vegetable hydrators. The shelves and drawers constantly have a humid film on them. Last week,...
for no frost type;cleaning of freezer cub underneat is a must...cloggged drain outlet buildup thick frost on your freezer cub..
.ie..for frost type;you must set your thermostat setting to normal,replace it with new one
Oct 20, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Freezer froze,ice and frost,freezer door froze, warm in fridge
change thermostat sensors in fridge and freezer easy
Feb 04, 2010 | Refrigerators
The things in the freezer are not frozen and there is ice in the milk in the refrigerator. It a 6 year old Whirlpool side by side.
You possibly have a 2 part problem. Do a 12 defrost and make sure the product in the fridge is not near the auger (cold inlet vent into the fridge). Fridge gets its frost from the freezer compartment.
Nov 13, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Frost-free fridge-freezer; internal floor icing up
drain plug and or line probably plugged should be clear if ice was problem in between the casing shouldnt be a problem let unit run normal and check temp the amount of high humidity and usage [open and closing of doors] has caused a lot of frost free and regular units to frost and or ice up
Sep 29, 2009 | Freezers
Freezer cold but not fridge
too much ice bulid up will stop enough cold air being blown into the fridge.Try turning it off letting all ice melt then turn it back on again and set thermostat at a lower temp.There may be ice you can't see.
Aug 05, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Refrigerators Logo
192 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
