Question about Panasonic TH Televison & Video
I have a Philips tv model # 42TA2800. TV power suply gives buzzer. Can you tell wich part from power suply does not work. thans
Power suply turns on. But power suply gives buzzer. Does not display picture. Wich part have to replaced from power suply. Pleas advice me. Thanks.
  • 6 Answers
SOURCE: Viewsonic N3250W no power light ?
check out this website, it's got everything you need. I have to give all the credit to Alain, a brilliant guy in France who dug in and solved the problems. he gives instructions for the professional to fix the problem, but he also gives the sources for the power supply board to be purchased and for the little chip that causes most of the problems. I decided to take a risk and save some money and bought just the chip for $20 and very carefully soldered it in after removing the old one. The tv is fine a month later. The board comes out with no soldering, just some quick connectors and the back of the tv will come apart after you remove all the screws and the base by gently prying the back case from the front bezel along the sides of the tv. if you look closely, you will see the small cavities to pry from.
here's the website:
http://pagesperso-orange.fr/alain.mionnet/enii3210j.htm
Posted on Aug 06, 2008
  • 44 Answers
SOURCE: Hi. My Philips flat TV will not show any picture
I had the Same issue. on a 50PF9431D/37 set. Many Plasma Set's use a LJ44-00118A PS-505-PH Power supply from Samsung. Known to have this common problem. If you can, or have a friend that can Solder components?. Unplug your set remove the back panel & locate your power supply. It will be the PCB in the center of the set just above the Video/Audio connections. http://www.shopjimmy.com/power-supply-unit-lj44-00118a-from-philips-50mf231d-40.htm. Is a Link to a photo of the PCB. Make a note of the locations of all cable connections then unplug them all. Un-install PCB, Check all Fuse first. I believe their is 5 or 6 of them on the PCB. Then replace the two 3300uf 10v 105C Radial capacitors at C8060 & C8059. Look to see if the Caps are deformed and or split at the top. The location of the caps are in the Lower bottom edge of the PCB. A local shop may Carrie them if not, digi-key has them. Part # http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=493-1754-ND. Total cost was $7 with S/H.
Posted on Jun 25, 2009
SOURCE: sony ke-42ts2u. When you hit the power button,
i have same problem did u find the fault
Posted on Sep 23, 2009
  • 17 Answers
SOURCE: Mikomi TV power pack/transformer/AC adapter replacement
Do not buy anything from LCDPayless. They are crooks. I order power supply for Protron 32" and they sent me some garbage that is not working. I returned it and they refused to reimburse me full amount and then they claimed they didn't receive it at all. STAY AWAY FROM THEM THEY ARE THIEVES.
Posted on Feb 11, 2010
  • 1768 Answers
SOURCE: Plasma tv picture not coming on and power light flashing
Yes, you have power supply issue.
the power on circuit is malfunctioning and the flashes is the indication that the voltage levels for the power on regulation is not correct therefore shut down to protect the circuit from further damage. You TV unit needs servicing by an plasma TV specialist.
Also check to see if you do not have the TV in sleep or hibernation mode.
Posted on Apr 23, 2010
Fuse and fet / eft of power supply fused no. W18NK80Z. this is not available. Philips lcd model no. 42TA2800.
Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Oct 24, 2015 | Philips Televison & Video
I am repear to philips crt tv 21pt2217/94 this tv power suply not work ?plese help
check the fuse resistor for tea1506 and confirm that all parts
from the psu are ok before you try to power the tv.
check well any mistake will destroy the new parts
Nov 30, 2014 | Philips Televison & Video
My Samsung HDTV takes almost a half hour to turn on. I push the on/off button and nothing seems to happen. I do have the TV connected to cable but even when I use the Samsung remote or the button on the...
Tv have a power supply board problems.That the board where the tv power a/c cord plug into it.Take the tv aparts and check the tv power supply board carefully for dying and leaking components parts that are calling capacitors parts these capacitors parts are most likely bugles ups or puffing up onto it tops and leaking.These capacitors parts are dying and leaking that why it give the tv power supply board low power and long time to power up the tv.Have all the tools and know basic electronic also can do basic soldering work?Yes,than changes all these dying and leakages bulges ups capacitors components parts with the same Miro Fared and thoes voltages on the capaictors parts like 5 or 10 volts higher than those capacitors parts was in the power supply board u are replacing,these 5 or 10 volts higher rating will help these newly replace capacitors parts withstand heat better and last longer and the operation on the tv power supply board.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish tv power suply board for the replacement.
Aug 19, 2011 | Samsung LN-S4041D 40 in. LCD HDTV
I have a 42PFL3403 model (42"). Was bought brand new. After a few months, started with problems. The image went off (sound OK). At the begining was enough to turn off and turn it on again. With the...
This tv it new still under a year old?Yes.Tries take Philips warrenty repair.The tv problems,to the tv are the causes of the tv power supply board.That the board where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish power supply board for the replacement.
Jun 23, 2011 | Philips 42PFL3403 42 in. TV
2003 philips 50" plasma tv with picture fading. How do I fix this?
Hi,my philips plasma 50FD9934 dont turn on just led flasing red and green contniusly.Please help!!!!This is a power suply problem?thanks
Nov 14, 2009 | Philips 50FD9934 50 in. Plasma Television
Tv wont turn on
your tv is in shutdown mode replacing the power suply module may corect this problem
Oct 16, 2008 | Philips Magnavox 51MP392H Rear Projection...
Philips tv demo
Try holding the volume up and channel down buttons on the set at the same time. Give me the model # if that doesn't work.
Jan 17, 2008 | Philips 32PT6441/37 32" TV
Green light comes on for 2 seconds and then nothing
most of the time the led in front of the tv will blink red and that will tell the technician wich circuit to look in. if it does blink at all when it shuts down then the problem is more than likely in the power supply. the part number for that is 313819875691
Oct 12, 2007 | Philips 20PF5120/01 20 in. EDTV-Ready LCD...
Astar 27" TFT LCD TV, Model LTV-2701
the power cord is the same as a computer power suply. Can be found at a computer store and its really cheap.
Aug 14, 2007 | Astar LTV-2701 27 in. HD-Ready LCD...
Televison & Video Logo
194 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
