My jmb 22883 is stuck on standby what is the problem
When you swich it on it goes to standby as normal but when you click the on button to turn it off standby it goes black then goes back to standby. I had it 10 months when it happend and i have tried on separate occasions to turn it on but it still does it. Thankyou
markevans
  • 148 Answers
SOURCE: Flashing pot and pan light
shut off the power and see if the unit will reset. if its plugged in, it will be easy, look under the sink. if not, try a breaker.
let the power stay off for about a minute.
then back on.
if not restored, then you have logic boards that failed.
sorry,
good luck
mark
Posted on Dec 28, 2007
hawkwatcher
  • 67 Answers
SOURCE: stuck on standby
Unit is in protect mode there are a few problems that can trigger protect mode the most common is blown channel (shorted outputs). Sometimes one of the 15v regulators may go bad causing imbalance of supplys triggering protect mode. Also sometimes a bad solder connection could cause unit to go into protect also. I work for Denon authorzied repair center in Michigan if your nearby and Shipping to Michigan is economical let me know kstahl65@att.net
Posted on Feb 15, 2008
Kiranbala
  • 91 Answers
SOURCE: dell inspiron 1150 screen goes black after standby
Let me help you regarding this, As your notebook is not having low room to handel the standby applications, i suggest you to change the power options in the control pannel. There you find POWER OPTIONS icon click on it and go to advance tab, there u find the option called WHEN YOU CLOSE THE LID, put it to DO NOTHING. So that nothing happens when you close the lid. I hope this helps you. BYE
Posted on Nov 14, 2008
  • 55 Answers
SOURCE: stuck in standby
Sorry about that. When the tv goes bad like not turning on, the green light will blink, and goes right back to red standby light while the dtv letters will briefly show on the lower right of the tv screen, then go back to blank screen. The tv will need to be taken to an authorized service center for repair. Common causes are a bad inverter/power supply, power control board, or circuit board.
Posted on May 18, 2009
SOURCE: goes into standby mode
press the off/on buttun and keep it pressed in while pressing the standby button... it should fix it
Posted on May 31, 2009
Pioneer SX-20 Stuck on standby
It may be in protect mode because of damage to other components.
Mar 19, 2018 | Pioneer Audio Players & Recorders
Jmb tv troubleshootingMy jmb tv won't turn on. The stand by flashed a few times and the tv turned off and will not turn on. No response at all. I have changed the fuse but still nothing. Model no,...
Hi , silly question but I have a jmb tv 32 inch code Jt0132003B/01 but can't find the power button on the tv !?! I looked all over the tv but doesn't seem to have one ??? I don't want to leave it on stand by so my only option is to turn off at wall but that turns off My talk talk and DVD player too , any know where is it !?!
Apr 19, 2014 | Televison & Video
HI i have a JMB LCD TV MODEL 42883 today it started turning its self, on and off standby,the standby light is flashing on and off i`ve even tried taking out remote battery but nothing works sometimes...
hi I have a JMB LCD TV MODEL 42883which has only worked for one week b4 the screen was cracked by accident everything else is perfect.would solve one of your problems your having with your tv.will sell it at reasonable price.07719651554 if interestd
Mar 01, 2011 | Televison & Video
ITS ON STANDBY MODE & NOT ABLE TO GET ITS DISPLAY
Try this, not sure if the same would work for ya.
Swich off the amplifier.
Prior to the process check the wires connecting the speakers are not creating a short circuit which is apparently putting the amplified into a standy mode.
1. Press the "A" "B" and power key all at the same time and hold on to it.
2. The amp will go into a reset mode and will keep blinking till it gives a normal "click" sound and the amp turns on.
3. this process would take about 2 - 3 minutes.
4. You may then release the buttons.
5. If it goes into a standby mode again and does not power on, or the standby keeps blinking, get assistance from the engineer.
6. Once it is on, you shall need to do the resetting of alll the configurations done earlier.
Hope it works, it costed me 3k to get the job done.
Nov 12, 2009 | Denon AVR-1603 Receiver
TV will not turn on
Hey guys this one is a no brainer when you push power button AND STANDBY LIGHT COMES ON NEXT PUSH THE BUTTON ON THE LEFT NEXT TO POWER BUTTON AND WALLA IT TURNS ON
Nov 11, 2008 | Televison & Video
Standby button stuck
Hello. Check all of the buttons on your unit to make sure that they are not stuck...you can feel the click they make as you push it then they pop back out as your finger pulls off. Any stuck button will lock up your microprocessor and keep the unit from turning on. All other problems will require a consumer electronics technician to trouble-shoot the turn on circuit. If you know how to use a meter and know how to solder\unsolder and require further assistance you can contact me. Good luck.
barneyluc
Oct 19, 2008 | Onkyo TX-SR601 Receiver
Wii standby light
To be precise, you can turn this option off from the Wii System settings -> Wii Connect 24 -> standby connection -> off
When this setting is swiched to off, your console shuts down entirely and there is a RED light on the power button. There will be no need to turn off the console pressing the power button.
Jun 10, 2008 | Nintendo Wii Console
Standby problem
When a alptop goes on to standby its quite common to require you to press the power button.Just turn off and power saving and standby problems you have by going into power management in control panel.
Mar 28, 2007 | HP Compaq Presario V2000 Notebook
Televison & Video Logo
158 people viewed this question
Top Televison & Video Experts
