Question about Toshiba Qosmio F25-AV205 Notebook
Ac adapter ,
Ac adapter not making connection ,replaced with no results,have'nt opened the pc to check anything yet,need advice.
    Scholar:
  • 136 Answers
Check the socket where the adapter plugs in to the laptop, and see if the central pin is there or if it is bent.
Posted on Oct 28, 2008
Connected to the AC socket, but no reaction from the laptop. The charging indicator and DC indicator is not burning.
First remove the pattery if possible and see if that makes a difference. If it does, your battery is bad.If not, put the battery back in.Either swap a different compatible AC adapter to test to see if the problem is with the AC adapter or the computer, or else get a voltage meter and manually test the voltage of the power supply. If it is the AC adapter, replace it. If the power supply is good, it may be the socket where it plugs into the laptop. Is it loose? If you have come this far in my instructions and haven't found the problem, it is probably something internal to the laptop, and you would be better taking it to a professional repair person instead of taking it apart yourself. Just judging by the fact that you are coming to FixYa for advice.
Mar 02, 2012 | Computers & Internet
Tip
My dell pa 12 won?t start ?
When i start my dell pa 12up and it takes 10 mins to load to windows XP, , when the windowsloading screen comes up the FANS go crazy. I then wait till i’m at thedesktop at which point i immediately shut down the pa 12(which takes afurther 7 mins) while the FANs are going crazy.
answer :
Now if i start the pa 12 again it works normally.
I had to do this procedure everyday, untill today when i switched the pa 12 on, waited till the desktop appaered and i removed the battery while the pa 12 was on..
Now when i switch the pa 12 on it powers up but i’m not getting anything on the screen
First try a different AC adapter (such as :pa 10 ac adapter)
If no change then the issue is the motherboard. Often the AC adapter will fail then the battery discharges and you get the symptoms youdescribe.
SO AC adapter then MB
It shows no power on your laptop but it shows you the dvd player led comes on then off.
I would suggest try the following:
1. Remove laptop battery, optical drive, hard drive and ram. Remove external peripherals as well.
2. Make sure AC Adapter is not yet connected to the laptop. Pressand hold on the laptop’s power button for 10 seconds to drain the powerflea.
3. Connect the AC Adapter to a known good power outlet, check ACAdapter power LED if it is on. Try to sense if AC Adapter is not makinga bit of noise when it is plugin to the wall power outlet.
4. Connect now the AC Adapter (hp dv6000 ac adapter)tothe laptop. Check if AC Adapter LED stays on when it is connected tothe laptop. If the LED stays on means the AC Adapter is fine. If the ACAdapter LED turned off check the AC Adapter pin that goes to the laptopAC socket if it is loose.
5. If laptop AC Adapter stays on after connecting to the laptop try topower on laptop. If no power LED comes on then this is motherboardproblem.
6. Before replacing the motherboard there is one checking needs todo. If you can open your laptop bottom part then good, do this whenlaptop is not connected to any power source. Try to reseat the laptopCMOS battery then try to power on laptop after, if still fails thenreplace motherboard. I hope this helps.
on Feb 09, 2010 | Computers & Internet
My ASUS P4T533-C won't turn on
This is really a common problem with computers these days. It may be caused by a number of reasons like a faulty charging system, faulty battery or anything burned out on the computer's system board. But in this scenario, i would suggest the following
1. Remove the battery and connect the laptop with the AC adapter only and see if it will respond.
2. Remove the AC and re-connect the battery and try to turn it on
3. If the above two do not work, then consider changing the AC adapter for your laptop. You can try to use a different AC adapter that has the same rating as your laptop's. The problem might be with the Charger.
4. But if all this does'nt work, consider getting a Computer Technician who can open up your computer and check the circuit board, there might be a problem with one of the chips
Mar 01, 2012 | ASUS Computers & Internet
My acer laptop adapter's green light is blinking... therefore it's nt charging...............
Thanks for using FixYa!
Please check the following:
1. Check your power supply, make sure it is connected properly.
2. Check your ac adapter from and to your laptop and outlet.
3. Check your battery if its properly installed.
If you need further assistance, please let me know.
Regards,
fossildude
Nov 11, 2010 | Computers & Internet
I bot a hp mini laptop recently.. ws working well..bt sddnly it ws nt chrgng ystrday and showed cross sign over battery in control panel.. why is it nt chrgn and wht to do?
If the laptop is still working when it is plugged in , then the ac adapter is good and the battery is just bad. If the laptop will not work when it is plugged in then more than likely the ac adapter is bad.
Oct 27, 2010 | HP Mini 1000 Netbook
2 months ago ive bought new charger...cause there was a fault with my previous one. It might also be a socket on laptop, so ive fixed both of it!but in the recent time,something went wrong...my charger...
Turn everything off. Take off the battery. Connect the ac adapter and turn on your computer. If it works with the ac adapter connected and your battery off then you have a defective battery.
If it does not work then it's either your ac adapter or your dc jack inside your computer. Try a different ac adapter at the store you bought the battery and you'll know if your adapter is bad. If it works with another adapter then exchange the adapter again (I know, I know, I've been there). If it does not work with another adapter then you're back to the dc jack but at least you'll know for sure.
Make sure that whoever is replacing the dc jack is good at soldering and replaces it not just solders the same one back on. Don't forget the shield to the dc jack. Good luck!
Oct 16, 2010 | Computers & Internet
Acer 5920 aspire wont start
3. Connect the AC Adapter for laptop to a known good power outlet, check ACAdapter power LED if it is on. Try to sense if AC Adapter is not makinga bit of noise when it is plugin to the wall power outlet.
4. Connect now the AC Adapter tothe laptop. Check if AC Adapter LED stays on when it is connected tothe laptop. If the LED stays on means the AC Adapter is fine. If the ACAdapter LED turned off check the AC Adapter pin that goes to the laptopAC socket if it is loose.
5. If AC Adapter stays on after connecting to the laptop try topower on laptop. If no power LED comes on then this is motherboardproblem.
Jan 19, 2010 | Acer Aspire 5920-6727 Notebook
I have a dell Inspirion 9400 and it won't start. When I press the power button, all that happens is the power light and the dvd player light comes on and about 3 seconds it turns off. Does it with and...
It shows no power on your laptop but it shows you the dvd player led comes on then off. I would suggest try the following:
1. Remove laptop battery, optical drive, hard drive and ram. Remove external peripherals as well. 2. Make sure AC Adapter is not yet connected to the laptop. Press and hold on the laptop's power button for 10 seconds to drain the power flea. 3. Connect the AC Adapter to a known good power outlet, check AC Adapter power LED if it is on. Try to sense if AC Adapter is not making a bit of noise when it is plugin to the wall power outlet. 4. Connect now the AC Adapter to the laptop. Check if AC Adapter LED stays on when it is connected to the laptop. If the LED stays on means the AC Adapter is fine. If the AC Adapter LED turned off check the AC Adapter pin that goes to the laptop AC socket if it is loose. 5. If AC Adapter stays on after connecting to the laptop try to power on laptop. If no power LED comes on then this is motherboard problem. 6. Before replacing the motherboard there is one checking needs to do. If you can open your laptop bottom part then good, do this when laptop is not connected to any power source. Try to reseat the laptop CMOS battery then try to power on laptop after, if still fails then replace motherboard. I hope this helps.
Dec 12, 2009 | Dell Inspiron 9400 Notebook
Cannot get my computer to turn on
remove all external peripherals. remove laptop battery. remove ac adapter.
plug ac adapter to wall power socket without the laptop connected check if the ac adapter led will stays on. if yes then connect it to the laptop and check if the ac adapter led turns off. if yes motherboard laptop has problems and need to be replaced.
if ac adapter led stays off without connecting laptop, try different wall power socket, if still ac adapter led is off then replace the ac adapter.
if ac adapter has light stays on then connected to laptop but laptop cannot even power up even the ac adapter led is on then laptop motherboard needs to be replace.
Dec 09, 2009 | Dell Studio 15 Laptop
Toshiba Qosmio F25-AV205 Notebook Logo
75 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
