Question about Smeg WDI12 Front Load Washer / Dryer
Is there any quick wash in smeg WDI 12C washing machine??? If yes how do we use it?..
5 Suggested Answers
FitzOriginal
  • 842 Answers
SOURCE: I have a WD1 12C
This will potentially sound odd, but run the 90 degree cycle again with 3 dishwasher tablets in the drum. The smell is bacterial and probably the result of a build up of residue from biological soap powder (Which is simply bacteria that eat your stains). Dishwasher tablets are anti-bacterial and will kill the bugs making the smell
Posted on Jul 07, 2011
  • 6277 Answers
SOURCE: Washing machine WDI 12C
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Following are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Jul 23, 2011
Testimonial: "Spot on. Drained the system cleared the filter of 3 £1 coins, 1 safety pin and 6 collar tips. And all this for free. 20 minutes job done. "
  • 6277 Answers
SOURCE: my smeg wdi 12c washer
Could be that there is water still inside keeping the garments wet so sorry, try this but no promises!
John C
Posted on Jul 30, 2011
caroldon
  • 17130 Answers
SOURCE: Hi I have a smeg wdi 12 22038 washer/dryer. The
It is possible that the machine does not start off the cycle because there are errors or feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven from the flow into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
The program seems to go back as there is a feedback and so the start button must be checked for moisture or shorting. Also dry the board and connections.
Now check the rest of the cycle.
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
Thank you for using fixya.
Posted on Aug 11, 2011
I have a smeg washer drier wdi 146 with error code e13. Can you tell me what the problem might be. Thanks
i beleve your door interlock is fautly
or the wiring too it can overheat and cook
so youll need a new one from smeg uk
and check out the connector for any issues
see here for some details
although its a different model i would assume the company uses the same error code setup for all its models
and i would order direct from smeg
http://www.ukwhitegoods.co.uk/forumsphpbb3/washing-machine-forum/error-code-e13-smeg-wdi12c6-washer-dryer-t75513.html
Dec 20, 2014 | Washing Machines
Hi I have a smeg wdi 12 22038 washer/dryer. The washing load gets washed then spun but the drying cycle then does not begin, instead the load is washed again!!! Please help? also can anyone direct me to...
Aug 11, 2011 | Smeg Washing Machines
Washing machine WDI 12C showing error coed E 06 during wash cycle after an intermittent grating noise was heard several times during wash cycle (possibly on pumping out). Wet clothes and water remain...
John C
Jul 23, 2011 | Smeg WD16BA Front Load Washer / Dryer
I have a WD1 12C Smeg washing machine - when I open the door there is an awful smell reminiscent of stagnant water - the machine it self seems to be running OK I've put it on 90degress empty but still...
Jul 07, 2011 | Smeg WDI12 Front Load Washer / Dryer
Smeg WD1 12C, error code 10
I have a smeg wd1 12c washer dryer showing error code e01 any idea how to fix it?
Gilly
Nov 06, 2008 | Smeg WDI12 Front Load Washer / Dryer
Loud noise coming from machine
i would say its the bearings in the drum rather then the motor,that would be expensive over $200?
Dec 19, 2007 | Smeg WDI12 Front Load Washer / Dryer
Error code e14
E14 Dryer temperature probe in short circuit or interrupted
Jan 29, 2007 | Smeg WDI12 Front Load Washer / Dryer
Smeg WDI12 Front Load Washer / Dryer Logo
151 people viewed this question
Top Smeg Washing Machines Experts
Tom Chichester
myrlanthian
Are you a Smeg Washing Machine Expert? Answer questions, earn points and help others
