Question about MSI Computers & Internet
Question Problems with DIMM slots !!!
My Laptop is MSI ms-1671(X630X). I have two blocks of RAM memory, but in the bios I can see only one. I tested the blocks on other notebook and it works perfect. I cleaned DIMM slots but nothing. The notebook is loading very, very slowly. I was searching how to clear coms or remove bios battery but I couldn't find it. Any suggestion? Thank you in advance !!!
  • 400 Answers
Hello
Try installing the memory on one memory slot at a time to make sure that both memory slots are working ,try one memory by itself and then the other one.
If you install both at the same time example 2x 2gb ram and bios only sees 2gb and not 4gb then it's problem with one of memory slots and motherboard must be repaired.
You can try bios update:
http://www.msi.com/product/nb/EX630.html#/?div=BIOS
Good Luck
Posted on Feb 20, 2012
Can i chage my processor pentium 4 to core2duo my motherbourd is(MSI PM8M-V H (MS-7104 v2) thnkz
No, you cannot upgrade to a core 2 duo with that motherboard because it is a socket 478.
Jun 04, 2012 | MSI Computers & Internet
I want tobuy 1gb memory card for my ms 6787 ver2.. what is the specific type of memory card is the best for my board (1gb or 512mb only)
For this particular motherboard, you need a 184-pin DDR SDRAM DDR 266 (PC 2100) memory module. These can be found in sizes ranging from 256MB to 1GB. There are several places that these could be found on the internet. Pricing for a 1GB module seems to be around $44 or $45 USD currently.
The MS-6787 supports a maximum of 2GB of RAM (1GB in each DIMM slot).
Hope this is helpful!
May 09, 2011 | MSI P4MAM-L (MS-6787) 400/533 MHZ FSB...
Error 53.21 hp color 5550
Doesn't specifically mention the 53.21 error this is the closest they come so you will know it deals with the ram anyway
Control panel message Event
log error
message
Description Recommended action
53.XY.ZZ CHECK RAM
DIMM SLOT X
To continue press
CANCEL JOB
None An error occurred on some
memory of the printer.
X DIMM Type
1 RAM
Y Device Location
1 DIMM Slot 1
2 DIMM Slot 2
3 DIMM Slot 3
4 DIMM Slot 4
ZZ Error Number
0 unsupported memory
1 unrecognized memory
2 unsupported memory size
3 failed RAM test
4 exceeded maximum RAM size
5 invalid DIMM speed
Press CANCEL JOB. If the problem
persists, replace the DIMM card in
the slot indicated.
Click Here for Memory
hope this helps and if so please mark FixYa!!
Jul 30, 2010 | Office Equipment & Supplies
Sd ram 256MB -does not read more than 128 MB per slot
I checked the specs of this motherboard at the following link:
http://www.msi.com/index.php?func=proddesc&maincat_no=1&prod_no=340
The specs says the following:
• Supports four 168-pin unbuffered DIMM using eight memory banks.
• Supports a maximum memory size of 348MB (8Mx8) or 768MB (16Mx4) registered DIMM
only
• Support ECC (1-bit Error Code Correct) function
• Supports 3.3v PC100 SDRAM DIMM.
According to this, the only memory DIMMs guaranteed to work on your motherboard are the 3.3v PC100 SDRAM DIMMs.
However, it seems that your problem lies within the density of the memory module. It looks like the motherboard was made when 256MB sticks weren't very common yet, so there could just be some compatibility issues.
I believe that the motherboard only supports 128MB per side. The RAM you bought probably has memory chips only on one side. Check your new stick. If it only has memory chips on the one side (small black squares) then the only thing you can do is take it back and look for a double-sided stick of 256MB. Even then, it may or may not work with your motherboard.
Nov 08, 2009 | MSI MS-6163 Pro Motherboard
Install DDR-DIMM PC3200 to MS-6367 MSI
That motherboard was made for PC2100 DDR266. A PC3200 DIMM *SHOULD* be backward compatible. Depending on the density of the PC3200 memory you might have problems. If you have not bought the memory yet I would go with the PC2100 for sure since the PC3200 will give you no speed gains at all and will be running at PC2100 speeds anyway.
If you already have the PC3200 memory then I would say just give it a shot. The worse case scenario is your machine will not boot up with the higher speed ram installed. Assuming you take all the normal hardware upgrade care and do not physically break anything you can test this memory with no harm to your motherboard.
Aug 12, 2009 | MSI MS-6367 Motherboard
What type and how much memory can i put in the MB MS 6577 Ver 4.1?
1GB Of PC2100/PC1600
According to:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=bph07843
Apr 24, 2009 | Computers & Internet
Dell Latitude CPx H500GT fails when using 2x256 Mb memory in bay
If the laptop is in warranty, then dell will take care of it. Also, are the two ram sticks the same speed? mixing ram can be bad. also, goldmemory software is excellent for ram testing.
lastly, if there is a bios version that allows you to use both ram slots, use that bios. a newer bios is not always better.
Dec 24, 2008 | Computers & Internet
Increasing Memory Ram
According to the memory configurator at www.crucial.com your motherboard has two RAM slots that can handle one gig of PC2700 RAM each.
Look here for more information.
http://www.crucial.com/store/listparts.aspx?model=MS-6390
Aug 28, 2008 | Intel Motherboard
Installing new ram...wont work
Go HERE for troubleshooting guide. Scroll down to: Stability Problems - Memory Issues.
Jun 03, 2008 | MSI 915P Neo2 Platinum Motherboard
Whether supports DDR?
Hi valentin122, you're board does not support PC2700 memory.
The link below will take you to you're board,
MSI 845 UltraC (MS 6566). Suggest you add to you're favorites.
http://www.msicomputer.com/product/p_spec.asp?model=845_Ultra-C
There is not a bios upgrade to support PC2700 memory.
Bios link.
http://global.msi.com.tw/index.php?func=downloaddetail&type=bios&maincat_no=1&prod_no=295
You're manual is here.
http://global.msi.com.tw/index.php?func=downloadfile&dno=3466&type=manual
See page 2-5 in you're manual.
The mainboard provides 2 slots for 184-pin, 2.5V unbuffered DDR DIMM with 4 memory banks. You can install PC1600/PC2100 DDR SDRAM modules on the DDR DIMM slots (DDR 1~2).
To operate properly, at least one DIMM must be installed.
Here is a link for you're memory. To reach you max GB, you would need 2 DIMMS.
http://www.computermemoryoutlet.com/Standard_DIMMs-PC2100_(266MHz)_DDR-184^pin_NON_ECC_(Usually_for_desktops)-memory.htm
Have more questions, feel free to ask.
Good Luck!
Mike
How to vote you're expert.
Enter FixYa.com site.
Sign in to your FixYa account.
Locate My Profile on our FixYa's homepage.
Under My Problem locate your problem and click on it.
Under the solution given by the expert, choose.
Apr 12, 2008 | Computers & Internet
Computers & Internet Logo
66 people viewed this question
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
