Question about Panasonic VIERA Televison & Video
Vertical Band has appeared on my TH-42PX60B
I have developed a vertical band approx 2" wide down my screen It is approx 2/3 of the way across and goes from top to bottom. It is a dark grey band and is permanently there. Can anyone advise me if this is repairable - or do I need a new panel (which basically means it is landfill!)
  • David Feb 24, 2012
    Thanks for taking the time to reply, but I know from experience this cannot produce this symptom (let alone the fact the band is there on all inputs and on internally generated images - eg menu)
  • Panasonic Master
  • 1,205 Answers
HI
Before getting a new tv set I would try all cables and contacts, as well as looking in the troubleshooting section in the manual.
hope you succeed
Kolbrun
Posted on Feb 20, 2012
4 Suggested Answers
freelance-au
  • 131 Answers
SOURCE: the tv has two black vertical bands down the
Hi
This is not really a very simple fix but it can be done if you are ok with stripping down your tv, Please see the following video.
Hope this helps
Posted on Apr 05, 2010
jojack2k5
  • 34 Answers
SOURCE: vertical bands on screen
bad x drive board on bottom of set where lines appear
Posted on Apr 29, 2009
  • 899 Answers
SOURCE: black band running from top to bottom of screen
this will need to go into the shop to get one of the video processing boards replaced that controls that part of the screen , this will happen when it gets to hot inside the set ,( thermal break down)
electech
Posted on Oct 31, 2008
Disney princess tv suddenly narrowed the visible part of the screen. Now everything is squished into a two in wide band with all the rest of the screen is black.
if that 2 band according to you from top to bottom,it has a defective vertical stage.if this two band appears one on top and one at the bottom,it`s on vertical stage.leaky capacitors,resistance changed or resistor devalued ang ic`s, are too weak to amplify a signal to make the screen complete....
Jan 29, 2014 | Disney 13" TV
Panasonic TC-P42S2 .. Transparent 2 inch wide vertical discoloration on panasonic 42 inch plasma, very left of the screen.
Fixed mine, myself! Black 3 inch vertical band (stripe) appeared after a cros country move on our PC-T50G10. Occasionally we would see white band with multicolored pixel width stripes. Took the risk of taking off the back to see if I could see anything. Found places on sides and bottoms where plastic like 2" flat cables could be seen. Guesstimated where the band was and found that I could flip down a black cover on one end of the cable. Tried to pull it, gently. Mistake. Realized it wouldn't one out like computer hard drive cables, so I took out the screws holding the plate on the other end (it's only an inch long). That allowed me remove the cable. Took it out, cleared away dust, put t back and closed the black over. It worked! Put the screws back in, back on and... we are happy (although I do have four extra screws!). Just be gentle.
Feb 17, 2012 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Two inch wide vertical band spreads across half of screen
this is a problem is your scan section either letf or right scan boards are bad. if its under warranty take it back if not it needs to be serviced. you can probably do it yourself.
Jul 01, 2009 | Televison & Video
White Vertical Band on Screen
Hi...there,
It's seems you got a busted screen panel...
Dec 15, 2008 | Dell E171FPb 17" TFT LCD Flat Panel...
Grey transparent vertical band centre of screen
enter the bios nad set the keyboard option to unlock
Oct 23, 2008 | IBM ThinkPad R50e Notebook
Grey transparent vertical band on laptop screen
This problem occurs due power fluctuations and over heat .You have to change the laptop screen .No other way to go..
Good Luck
Siju.D
RCA F32450
All vertical perimeters in service mode .
Aug 02, 2008 | RCA F32450 32" TV
Green vertical lines on panasonic viera screen
I have two vertical very thin green lines on TV how do I fix
Jun 26, 2008 | Televison & Video
There is a band developing
The band is developing across both the top and bottom of the screen it is called cinemascope picture. it is a vertical failure. it is not a major problem. it is on you accrding to cost of repair. it is due to less supply or part failure in vertical section.
Sep 24, 2007 | Philips 32PT5441/37 32" TV
Televison & Video Logo
417 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
