Question about Google Android
ClubMz Extreme Cell Phone manual - Google Android
How do i reset my cell phone voicemail pin number?
Go to "settings". In "Advanced Settings" there is an option to return your phone to it's original state. From there you can set it up again. WARNING: This will also erase all of your contacts, so write them down before going to this extreme measure. I would try MANY times to get the PIN correct before doing this!
Sep 03, 2014 | Cell Phones
Can u plz tell me how to move the clock to extreme right top corner or how to remove it
I think you cant move it. But you can remove it. Go to settings, then time and date and then clock. In that you have a option called show clock. If you do not have these options, please refer your user's manual.
Nov 05, 2010 | Nokia Classic 2700 Cell Phone
My phone nok 1650.by mistake i put in the charger + and - interchanged to the phone. Now it is totally dead what might have happened? I appreciate ur answer
the charging circuit might be fused, or battary got drained, reverse the polarity of the charger, connect it and charge it. I am not sure but it must have done some extreme things on the processor.
Oct 05, 2010 | Nokia 1650 Cell Phone
Issues with Clubmz software
I have the same problem !
I want my 15 $ back !
May 04, 2010 | Google Android
I forgot my nokia n73 security code or lock code
Prodigal brother you have. Go to the nearest Nokia Care and have the firmware re-installed. A word of caution, remove the memory card. You will loose all the data on the phone. And in furute use a password only as an extreme. And it should be such which you can remember even under extreme conditions and need not write it down.
Jul 29, 2009 | Nokia N73 Cellular Phone
Dont remember the lock code i put on my phone, need a way to unlock it.
you will need to contact your cell phone provider or the manufacturer of the phone to have this unlocked. In some extreme cases, you will have to return the phone and have it replaced.
Jul 11, 2009 | Cell Phones
Incoming calls on home phone ring 1 time and then extreme static
When you unplug everything connected to the phone jack what happens? If it works, you have too many ringers or a short on the line. If it still trips the ring, you have a defective box.
Carl
Jul 06, 2009 | AT&T Lands Phones
Google Android Logo
98 people viewed this question
Top Google Computers & Internet Experts
Robet
Robet
Sunil Pratap Singh
Sunil Pratap Singh
Are you a Google Computer and Internet Expert? Answer questions, earn points and help others
