Question about Zebra GK42100111000 ZEBRA GK420T PRINTERS 4 PRINT GK42100111000 Dispenser
GK420t MEMORY PROBLEMS - CANNOT PRINT VARIABLE BAR CODES
Hello kind problem-solvers :) This is our problem: 1) We have a ZEBRA GK420t print. 2) We are using ZebraDesigner 2.2.2 (Build 2728) (2009) as a software on Windows XP or 7. 3) We need to print labels with Variable bar code data, with an increment of 1, so changing the value of the bar code with 1 every next label. I follow the Bar Code Wizard of the Zebra Designer soft and set the counter with great care but the counter doesn't work. No matter if I check the 'Use printer's internal counter' or not, nothing happened. The bar code stays at the first number who has been set. The same if I try to set a counter for a variable text field, time field etc the starting number do not grow at all, altough it prints in this original configuration. It seems that there is no memory at all in the printer or software, to make the counter work. Please give me a hint and receive my gratitude in advance :)
  • aron.ovidiu
    aron.ovidiu Feb 20, 2012
    I find how the counter works - the quantity has to be set on the print-comand panel but the problem remains because it prints all the labels in a row, without pausing between labels.
    I need to introduce 2 variable text-fields at every next label.
    For example I need to label an inceasent number of objects, everyone with its particular weight and price.
    So I need the bar code counter working in the background on its own, and 2 variable text-fields (keyboard inputs) that have to be filled at every label, so the printing have to stop for fill in at every new label.
    Please help.
jwr1914
  • 31 Answers
SOURCE: Zebra S4M Printer doesn't print
The fact that the Data message is displayed, means it is 'seeing' something. You may be losing the command character at the beginning that would cause the machine to ignore the rest of your code. If this is the first time you have attempted to use the serial port, you may have a setting incorrectly set. You need to match your Host exactly or the data may be framed incorrectly. The old standard was to send your data 8 bits, 1 stop-bit and no parity. Try Xon-Xoff with hardware handshaking too. I hope this helps.
Posted on May 27, 2009
jwr1914
  • 31 Answers
SOURCE: Zebra 105SL label issues
I am surprised that you are using that sequence of buttons to solve this problem. I am pretty sure that they want you to go into the "Media Sensor Calibration" setup in the config menu. It is a bit more complicated than what you have described. I also believe that the size of the gap on two of your labels might be out of tolerance (they are usually 1/8" gaps between the labels). The black marks are a problem for the transmissive sensors. You may need to move the transmissive media gap sensor (remember it has two parts: upper and lower). I would usually setup mine for a place beyond the black mark so that you are looking at just the white paper.
To start out:
1. Load the backing of a 6" strip of media (no label attached).
2. Remove a ribbon (if you usually use one).
3. Close the printhead.
4. Press SETUP/EXIT and then NEXT/SAVE until "Media and Ribbon Calibrate" appears.
5. Press "+" to start the calibration procedure. You should see the "Load Backing" in the LCD Display. You already have the backing loaded so continue to the next step.
6. Press "+" to answer the message and the next screen should say, "Remove Ribbon". You have also removed the ribbon.
7. Press the "+" to continue. You should see the screen say, "Calibrating Please Wait". After the sensors are setup by the machine a new screen should appear, "Reload All".
8. Open the printhead, and move the labels until they are loaded correctly to print. Smooth out the ribbon and load it correctly.
9. Withe media and ribbon now loaded, press "+" to continue and the machine should say, "Media and Ribbon Calibrate".
10. Press the Setup/Exit button once. It should say, "Save Changes Permanent". Press Next/Save to finish the process.
11. Do a normal calibration of your stock and print a label.
You are done. The machine will run for the labels you have setup the sensors for. Unfortunately, you must do this for each of the media types. To automate this, you could run a Configuration listing, capture the settings you just created for each type of label. Take these to a programmer to have them send the setup to the machine before the job. This is beyond the scope of this type support to really help you.
Posted on May 29, 2009
  • 254 Answers
SOURCE: ZebraDesigner Pro is changing my settings
use a different driver for each printer.
Posted on Sep 03, 2009
  • 1121 Answers
SOURCE: My Zebra Z4Mplus printer is skipping labels when I print
check the label margins, and label dimensions, and spacing , normaly is these problem, or is a printer driver problem, try reinstall driver
Posted on Jan 13, 2010
SOURCE: Zebra printer is printing two copies when only 1 is checked
Same problem exactly and was not able to get a response from UPS or the zebra company, someone please help!!!!!!!!!
Posted on Aug 04, 2010
In my application,i want to print the barcode generated from the application.i am using TTP 244 plus printer for printing the generated Barcode.but printer skips two lables and print the generated bar
Please verify the following:
- Driver: If you are using the standard printer driver, maybe you want to try another driver(Download an excellent driver at www.nicelabel.cl, searching by your brand and model name).
When installed, you should go to advanced settings and use the callibrate options.
- Software: Maybe your software has a configuration and the driver has another, set the same length for both and verify if the problem persists.
- Sensor: If the sensor has an issue, then you should try contacting a local reseller or partner for zebra. If that's the case, you probably will have to repair the printer($) or definitively replace it for another($$). Since it's a desktop printer, check your warranty first and maybe you are covered.
Jan 16, 2015 | Zebra GK420t thermal transfer and thermal...
Zebra GK420T Red light keep flashing
Seems its loosing calibration, try to reset to factory defult setting and it will calibrate with the labels that have at the moment. Please check settings at windows drivers (should be set up at Thermal transfere if using ribbon otherwise Direct Thermal if not using ribbon.
That issue can happen aswell if when sending a job to the printer with wrong settings, it will overrwrithe the previose settings of the printer.
you can untick the setting " use printer settings" at drivers as well.
if you need diferent driver go to www.seagulldrivers.com - this driver let you to resett printer to factury defaults. Hope it helps.Paulo.
Apr 03, 2014 | Zebra GK420t thermal transfer and thermal...
NOT PRINTING ON TO LABEL
When I have that problem with my GK420t, it seems that the font needs to be changed. Try switching to one of the other "Zebra" fonts.
Mar 03, 2014 | Zebra GK420 Thermal Printer
I have a Zebra GK420t Alternately Flashing Red and Green light error message. How do i clear this.
From the owner's manual:
Alternately Flashing Green and Red: Needs Service 8
8. FLASH memory is not programmed.
• Return the printer to an authorized reseller
You can find the complete owner's manual on Zebra's web site.
Jul 25, 2011 | Zebra GK420t thermal transfer and thermal...
Hi, when I try to print to a networked GK420t, it prints the first page then feeds two and a half labels and then flashes a red light. At which stage it completely loses network - pings time out.
The problem that you are facing can be resolved by doing a reset on the printer and then setup the printer on the network again. This will resolve the issue.
Jul 05, 2011 | Zebra GK420t thermal transfer and thermal...
I have a GK420t Zebra Thermal transfer printer that prints the test print perfect but when connect to mainframe and start printing from mainframe system the print is upside down. The top of print is on the...
You need to add the ^POI or ^PON command to your format on your host system. Look it up in the manual to see which is right for your app.
You could also get labels that are wound the other way on the roll. Inner wound vs. outer wound.
Jan 05, 2010 | Zebra GK420t thermal transfer and thermal...
Zebra GK42100111000 ZEBRA GK420T PRINTERS 4 PRINT GK42100111000 Dispenser Logo
182 people viewed this question
Top Zebra Office Equipment & Supplies Experts
pkwc
Dave Busselle
Level 1 Expert
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
