Question about Microsoft Xbox 360 Console
360 wont play games
When i put a game in and load it says play dvd. it can take swiching it on and off up to 10 times before it will "catch" and then it says play game. it plays fine then.
  • 2 more comments
  • Anonymous Oct 27, 2008
    wont play games says to put in an 360 game
  • ladyshady23 Nov 10, 2008
    some games say open tray, u open and close it several times and it says unrecognizable disk.... why will some games play and some not?
  • Anonymous Nov 11, 2008
    it says its a dvd
  • Anonymous Apr 12, 2009
    Mine wont load games but plays dvd fine I cant play a brand new game so it aint the disc what should i do my warrenty has ended
    Novelist:
  • 111 Answers
Some of the Xbox 360s have been known to have issues with their DVD-ROM Drives, On Older Xbox 360s The actual Drive has been known to cause slight scratching and scuffing to your Games.
If your Xbox 360 is having problems reading games, their is potentially a problem with the DVD Drives Laser, i had this issue last year with mine, Out of the blue the DVD Drive stopped working and wouldnt read discs. The i would suggest Calling Up the Xbox Customer support Center for your Country (numbers Available on www.xbox.com/support) and explain your problem to the person on the end of the line.
The only solution is usually to return your Xbox to microsoft Free of charge, which will be either repaired/replaced and sent back to you.
Also, once the solution is solved, it is important to NOT leave Games/DVD's In the Xbox's drive when not in use, Especially when moving the Xbox around as this can knock the laser and cause a fault ! their is only ever a DVD in my xbox drive when it is in use, i take mine out all the time to help prevent these sorts of problems.
Hope This helps !?
Posted on Oct 27, 2008
My xbox wont read eny disk
The dvd drive needs a new laser. Dont swap in another 360 dvd drive as it wont play games. it will need the drive key flashed to another drive to work.
Lasers are around 10-15 on ebay.
Dec 23, 2012 | Microsoft Xbox 360 Elite Console
When we put in a game for our 360 system it says it's playing a dvd we can't get the game to work. how do i fix it so it says play game amd not play dvd? (it only does this with 1 game. the rest work fine
Ok if your for certain thats the original dvd drive and the other games work then its too many scratches on the disc or your laser lens needs wiped off with qtip and rubbing alcohol.
If you get an xbox thats say play dvd all the time on every game and it says to play this disc stick in a xbox 360 console then its the wrong dvd drive for that motherboard and you wont get the key (on a chip in the motherboard on the cd drive) unless you have the original dvd drive taken out of your xbox. Then you can just switch that little motherboard on the bottom of the dvd drives and it will read games. This is for those who will look at this with a xbox off ebay that they cant figure out how to fix. Its just an expensive dvd player.
Dec 26, 2010 | Microsoft Xbox 360 Console
Xbox 360 - Please put disc into an xbox 360 console to play
Try getting a disc drive cleaner. (Maxwell).
www.walmart.com is and example retailer.
May 24, 2010 | Microsoft Xbox 360 Console
My xbox360 wont play some xbox360 games it says put in 360 console well it is a 360 console. What so i do?
you do it is very simple , you can manually fix your problem with the use of repair guide,, it is a complete version to fix your problems caused by xbox.
if you want to download click here.
May 14, 2010 | Microsoft Xbox 360 Console
Xbox 360 wont play games
If your Xbox 360 will not read your games this is because of the sensors on the back of the drive taking too much heat.
You need to send it in to get it fixed or you can fix it yourself using a good guide
Feb 05, 2010 | Microsoft Xbox 360 Console
Wwhen i put a game in my x_box 360 it thinks its playing a dvd. So i put a dvd in it and it works , just wont play games
If your Xbox 360 will not play your games this is because of the sensors on the back of the drive overheating it is not normally the laser.
Luckily you can fix this yourself and get back to your games and to do this you need the proven Xbox 360 Repair guide.
Or you can send it in and they will fix it for you the repair will take about 4 weeks.
Jan 31, 2010 | Microsoft Xbox 360 Console
Wont load games
It sounds like the dvd rom is failing inside the unit. Please give Microsoft a call for a free replacement:
1-800-4-My-Xbox
Dec 02, 2009 | Microsoft Xbox 360 Console
Played too many dvds on the xbox, now it says play dvd notplaygam
best thing to do is send it back in to microsoft, if you open the xbox 360 case you will void the warranty, and they wont bother helping you. If you have already voided the warranty, you can find xbox 360 dvd drives on ebay or craigslist for around 30$ USD. Only the drive alone, not a whole xbox
Jan 01, 2009 | Microsoft Xbox 360 Console
Disc wont play
i have the same prob my solution get a sony
Jul 01, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
146 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
