Kenmore 70 series top load washer model 110.22722100
Started the washer,it filled with water I put the clothes in and came back a couple minutes later to smell what smelled like a candle burning,so I stopped it.I tryed to start it again and got nothing so I let it sit a few minutes.Then I switched it to spin to try to get the water out,and it just made a humming sound like the motor was stuck and did nothing. I spun the aggitator and it spun freely.I then bailed out the water and tried starting it again.It did start filling with water but still wouldnt spin the water out.
  • FoofiesTwo Jan 08, 2009
    Same exact problem... We don't know for sure but we think that the transmisison is going out... whether it's a problem in the transmission itself or if the belt pulley or other part is jammed and so the transmission is doing all the work to pull the belt through, which results in the burnt rubber (or burning candle) smell and the transmission burning itself out. My husband didn't realize that the machine had been making a grinding noise for some time, so bless his heart, he had a repair man come out and replace a broken belt to the tune of $125 ($19 for the belt, the rest for labor). Since that cost is 1/4 of the price of a new top load washer (don't want to get into the discussion of top load vs. front load), we have decided it is time for Old Bessie to go out to the country and so we're looking for a replacement. I don't know exactly how old the machines are as they were in the house when we bought it, but the washer and matching dryer are probably at least 20 years old, and this is the first problem ever... too bad it will be the last! You've probably long since had a resolution to your problem, but for anyone else who may run into the same issues, DO NOT continue to run the machine if it makes a grinding noise, and especially if you smell burnt rubber as you could cause irreparable harm to the transmission that will be beyond repair or beyond the amount of money you'll want to spend on a repair.
  • 14 Answers
SOURCE: um..... not quite sure....
Most likely the transmission on the motor has seized and will need to be repaired. Look under the washer, if there is black grease on the floor then its time to replace the motor and/or the transmission. If you have seen smoke then its probably the case.
Posted on Jun 20, 2007
the dr
  • 447 Answers
SOURCE: 10 yr old Kenmore 70 series top load washer
Sounds like either the water level sensor (called a pressure switch ) is malfunctioning or there is a mechanical problem with the switch meaning that the tube that goes from the switch is
a) Kinked or crushed
b) has a small hole
c) Has become clogged
d) Air dome (where tube goes to on outer tub) is clogged
Posted on Jan 19, 2008
watugot
  • 290 Answers
SOURCE: kenmore 70 series
Mrquest
If it is draining the water then the motor is running. ou most likely have a broken motor coupler between the motor and gearcase.
Remove the two screws that hold the console to the cabinet and flip the console back.
Remove the two clips that hold the cabinet to the rear panel of the washer and unplug the lid switch harness. The cabinet will tilt forward and slide off.
Remove the clips holding the water pump and move it to the side.
Unplug the wires from the motor and remove the clips holding it.
You will see the motor coupler.
Make sure you can turn the gearcase shaft with a pair of pliers so it is not locked up.
Post back with the complete model number from the washer if you need further help.
Thanks, Mike
Posted on Apr 03, 2008
JOE LLAMA
  • 26 Answers
First thing is to remove the 2 screws from the console, they may be hidden in the front or bacl of console. After removing screws, lightly push the base of the console towards the front of the washer and pick up. This will expose your lid switch connection. Using a jumper wire, jump out the black and white wires then try advancing your washer into spin/drain. The culprit will usually be the lid switch assy.
Posted on Apr 04, 2008
  • 1073 Answers
SOURCE: MAYTAG WASHER DOES NOT SPIN AND DOES NOT DRAIN
you have a bad motor
Posted on Apr 16, 2008
I have a Kenmore Series 70 Super Capacity washer. The model number is 110.23712 200 (which doesn't seem to be a valid number when I do an internet search, but is the number on the plate on the unit). I...
Getting Sears parts 110.23712200
I will tell you what happened to me. One day my water valve quit. On that veryday my sister in law paid her weekly visit to wash her and my BIL's clothes. She bypasses 5 laundry matts to get here. I tell my wife we should not have a $75 water bill. So the water would not fill in the washer. I told her to get a 5 gallon bucket and fill it up then see how many buckets it took to fill the washer. 7 buckets later the washer kicked in and started doing it's thang. 35 gallons of water to wash a full load on highest level. Then 7 more buckets to do the rinse. 70 gallons of water to wash one load of clothes. I figured I had her cured from coming over every saturday just to wash clothes. But she found out I fixed it. LOL She has a washer and dryer at her house but IF she goes overs a certain amount she uses then the trailer park charges her extra for water. Soo she comes ta my house. Sweet.
Mar 11, 2011 | Kenmore Washing Machines
I have a top loading kenmore 70 series washer. It
The drain line is probably clogged. Maybe that a sock or other piece of clothing get between the clothes tub and the outer tub that holds the water. In this case it may then get into the drain hose that's attached to the pump.Remove the hoses from the pump and pull the item out. In case it clean there, check the outer tub port- open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then,try to remove the clothing through the port.
Sep 13, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Kenmore Series 70 washing machine whines and low flow on cold H2O
Yeah you need to replace the water valve. To get to it you need to remove the cabinet on the newer direct drive models, If yours has a rear access panel then you simply pop the top to get to the valve after removing the hoses. Fairly simple job. Here is a good website for direct drive coupling replacement . It shows you how to open the cabinet. http://repair2000.com/coupling.html
GVI 151 is the generic part that fix all belt drive models. Direct drive will need its own little water valve buy hay it ain't but 20 bucks.
For a better explanation post you model number in the comment box and I will research it further for you amigo.
Jan 20, 2009 | Kenmore 22422 Top Load Washer
Washer keeps filling with water...
you hae a stuck float switch, it shuts water off when it reaches a certain height, fixing it involes removing the top of the washer (not easily done)
Jan 11, 2009 | Kenmore 22422 Top Load Washer
Kenmore series 70 washer doesn't fill
check your incoming water supply, the buzzing sound is coming fromthe waterinlet valve , soundslikke its trying to fill. possible that the valve is no good as well,
Nov 23, 2008 | Kenmore 22422 Top Load Washer
Kenmore 28731 top load washer
You will need to replace the motor coupling. Here is a video to show you how to do it.
Oct 24, 2008 | Kenmore 23822 Top Load Washer
b) has a small hole
Jan 19, 2008 | Washing Machines
Kenmore 70 Series Washer
i have a kenmore 70 series washer model 10020722990
it will fill with water but will not wash. if you put it on spin the water will drain but it will not spin. it sounds like the motor turning. is it a clutch that has broken.
Sep 05, 2006 | Kenmore 22422 Top Load Washer
Washing Machines Logo
288 people viewed this question
Top Washing Machines Experts
