Question about Reebok Exercise & Fitness
Body sculpture bt5400
When start pressed the belt doesn't move and err appears on display, when checked there isn't any voltage getting to the motor but there is mains voltage getting to the circuit but the relay isn't closing'what's likely to be the problem?
  • 33 Answers
SOURCE: Belt won't turn.
HI, please replace the control board
Posted on Oct 02, 2009
maxtreadmill
  • 832 Answers
SOURCE: will not move belt
Press the Stop and the Speed Up keys down while inserting the safety key.
Press the Stop key one time. The Time window should read EP:2P. Some newer models may also say FP, Pass, or the like. This means that it passes the EPROM test.
Press either incline key and the incline will calibrate automatically.
BE CAREFUL, THE TREADMILL WILL RUN AT FULL SPEED IN THIS NEXT MODE! DO NOT STAND ON THE WALKING BELT. Press the Speed Up key and hold it down until 85 is shown in the Distance window (some models may show the 85 number in another window).
If the top speed of the treadmill does not match the displayed speed on the computer console, adjust the max speed potentiometer (pot) on the motor control board. This is the board that the red and black motor wires connect directly into in the motor area. The Max Speed pot is clearly labeled. The max speed potentiometer is a small square with a mobile center and is located in one corner of the board and is labeled MAX SPD. It is near the harness that carries the speed signal labeled H,W,L. Using a small insulated screwdriver adjust this potentiometer clockwise to speed up and counter-clockwise to slow down the max speed of the treadmill. A tiny turn of this potentiometer will make a big difference in speed so be careful when making adjustments. It is not important to get the speed set exactly at the max speed of the treadmill but do make sure to get the speed within .2 MPH of the max speed of the treadmill. For instance if the max speed of the treadmill is 10 MPH, make sure to have the speed set between 9.8 MPH and 10.2 MPH. Some models have a 12 MPH top speed, so please check your manual if you aren’t sure. THIS IS A VERY IMPORTANT STEP BECAUSE YOU WILL GET AN ERROR MESSAGE IF THIS STEP IS SKIPPED. After completing calibration of the speed, press the Speed Down key. The treadmill will automatically return to 0 MPH. Please allow the unit to stop completely before continuing. Press the Stop key once and remove the safety key.
Posted on May 31, 2010
taran_2005
  • 10515 Answers
SOURCE: My second hand Body Sculpture
There could be many causes for the same. Few of the major reasons are mentioned below :-
1. It could be due to faulty motor.
MOTOR TESTING
DC motors can be easily tested in a number of ways. Many times a motor is replaced only to find another problem exists so be sure to test the motor if you think it is a problem.
Methods to test a motor: 1) Cordless drill battery- get a fully-charged, 18 volt (preferred) cordless drill battery and on most treadmills connect the red and black motor leads to the battery (some have different colors but if you have two wires and get it hooked up backwards, the motor will just run backwards and won’t be harmed). If good, the motor should operate at about 1 MPH.
2) Car battery- these are 12VDC high amp batteries so the motor will turn slowly but you can walk on the belt. Always be careful with battery acid on these things so we don’t recommend bringing them in the house…take the treadmill to the battery.
3) Lantern battery- a fully charged lantern battery should operate your motor at a slow speed but lacks the amperage to have someone walk on the belt.
4) Use an outside DC converter with a variable speed input. The most complex but also the best way to test a motor. If you have a way to do this, it is the preferred method and how we do it in the field on local service calls.
2. Faulty speed sensor could be one of the reasons.
3. Even friction could lead to this problem. You could lube your treadmill ( read the owner's manual for the complete maintenance schedule )
Lastly, it could be a faulty control board ( though seems rare ). It might appears fine visually.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Aug 26, 2010
  • 14 Answers
SOURCE: While in use ,a cracklering sound heard and smoke
What kind of treadmill? Sounds like you need a new motor control bd.
Posted on Oct 25, 2010
  • 30 Answers
SOURCE: wen i switch on the
usually this means your motor control board (mcb) is damaged . remove the motor control box from under the hood remove the mcb from the box and check for damage and/or electrical burn smell . there is an overload resistor that usually blows up this is due to an overload caused by the issue you described or too much friction between the belt and deck board . if damaged you will need to get it repaired contact glide fitness products in santa ana california 1866 637 4600 for all details, i have had them repair many of them , it cost $200 plus shipping which is a deal considering a new one is $1000 if you need to send it for repair , remove the wax board and small electrical componet on outside of box and put in a safe place as you will need to reinstall them on new box
if this is caused from too much friction and you have an auto waxer the waxer nozzle is plugged clean this nozzle once a month or contact glide regarding their non clogging wax
good luck
Posted on Jan 28, 2011
My BT3152 treadmill has stopped working, the belt no longer moves
Is anything jamming the belt or motor drive pulley? Look carefully for anything that could be jamming it. If you suspect the motor could be bad, take it electrically out of the circuit and connect it directly to the your power supply, if it spins up you know its working, however, it could still be tripping off when under load.
Nov 09, 2014 | Body Sculpture Bt3152 Motorised Treadmill
Body sculpture BT5810 motorised treadmill. My treadmill switches on normally but after the 321 countdown to start error E1 is displayed and the belt does not move at all. Appreciate any advice you can...
see the step attached. clean the s. sensor , and diagram attached.
God bless you
ERR1 indicates a speed issue. In this case, the motor speed as reported from the optic sensor differs
from the speed setting.
Analysis: Optic sensor signal issue -- Either the optic sensor signal is not right, or it is read incorrectly, or
the signal is not reaching the display.afb1d921-a008-4e96-876a-cd31ffa20ecf.gif
Oct 31, 2013 | Body Sculpture Bt3152 Motorised Treadmill
Belt does not move
test the s.sensor for faulty, try to clean and tight the connector see the diagram attached.
2) test the terminal input for motor, if there are voltage the motor can be faulty. see my personal TIPS use the multimeter.
3) test the output control board, for input terminal motor, if there ARE NOT voltage for input voltage motor, the board is faulty, replace.
God bless you2374fb03-ba8d-41db-a055-835f5f00c3d8.gifc4b98225-bd14-4141-aa27-338b5241deb6.gif
Body sculpture treadmill runs for 6 seconds then stops
1( LUBE the deck belt, this happen because the lack of maintenance
2( LUBE the rollers bearing too.
3( test the input voltage motor, if there are the motor need repair.see my personal TIPS
4( test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
God bless you
Oct 07, 2012 | Body Sculpture Bt3152 Motorised Treadmill
Drum wont turn but the moter does
Hello Deanna - This particular issue could be caused by a variety of reasons. I would suggest trying the following steps:
1) Verify a circuit breaker isn't tripped
2) Advance the timer control dial slowly 360 degrees-
If the washer starts spinning, then that means the motor and drive belt are fine but that there is something wrong with either the timer control dial or the agitator solenoid. Call in a professional for this.
If the washer doesn't budge, then verify that the drive belt(s) is attached and not broken by removing the back panel. If the belt is broken, replace it. If it is loose, then tighten it by loosening up the bolt holding the motor and moving it on its swingarm (much like a car alternator) until there is a 1/2 to 3/4 inch deflection in the belt.
Some washers use reversing motors. It's possible the motor works on the spin cycle but not on the wash cycle. If so, call a pro.
3) Visually inspect the lid safety switch- Is it loose or cracked? If so, the washer might work intermittently, stopping at different cycles.
4) Check motor and drive belt- Remove the main access panel (usually in the back). Is the motor spinning, but the drive belt isn't? If so, then you have a drive belt problem.
Sep 30, 2012 | Frigidaire Affinity ATF7000E Front Load...
Khhc2090s trouble
The sensor errors are probably just from opening the door and interrupting the sensor cook cycle.
By the way, you should always press "Stop" before opening the door of a running microwave. Otherwise, the door switches will prematurely fail.
I would first check the door switches and their mounts. See this help file.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
You can also download manuals, installations info, and parts lists here.
dee77f7.jpgWe're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer.
Nov 25, 2011 | KitchenAid Microwave Ovens
E000002-0000 WHAT DOES THE CODE MEAN?
as you didn't specifed the model, here is general description:
The temperature of the fixing film is as follows:
1. has exceeded 100°C, but does not reach 115°C within 1 sec thereafter.
2. has exceeded 140°C, but does not reach 150°C within 1 sec thereafter.
3. has exceeded 160°C, but does not reach 165°C within 1 sec thereafter.
It can be due to faulty fixing heater in models with fixing film, or faulty thermistor's in models with teflon roller.
In most copier's the procedure for clearing is the same.
If it is temporary trouble, you can reset the error:
While copier is showing the error:
1) Press the User Mode key ' * ' .
2) Press '2' and '8' on the keypad at the same time.
3) Press the User Mode key ' * ' on the control panel.
Then choose ( if touch panel ) COPIER, FUNCTION, CLEAR, ERR turn it off and on.
If the model isn't with touch screen instead of pressing on display use the arrows to get to clear press OK and then err and ok, turn off and on.
If the clear doesn't help's call service!
Sep 16, 2011 | Canon Office Equipment & Supplies
Exercise & Fitness Logo
176 people viewed this question
Top Reebok Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Howard
Howard
Are you a Reebok Exercise and Fitnes Expert? Answer questions, earn points and help others
