Question about Roper RGX4634KQ Gas Dryer
Dryer steaming up my house
We bought this Roper dryer and then 2 weeks later we had to have the glow plug replaced. Now the dryer works but it takes up to 2 hours to dry a normal size load. After the 1st 1/2 hour cycle I open the door and the inside of the door is damp and condensation dripping from it. And some days it steams up the windows in our house. We've only had this dryer for almost 2 months. I made sure the dryer vent is always clear and even made sure the vent going outside was free and clear and I can't figure it out.
    Genius:
  • 1,028 Answers
Ck vent againalso be sure dryer is not pushed back too far crimping vent hose..to double ck leave rear vent hose off and dry a load ..may be some lint and moisture in house but if dryes in mormal time will confirm vent problem ..vent may only be partially blocked also look for hole in vent hose or better yet replace entire vent hose
Posted on Oct 27, 2008
We have had problems with our dryer not atarting. The repairman has come to our house 2 times. The first time, he said that it was a heat sensor switch that needed to be replaced, so he replaced it. It...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 08, 2011 | Roper Dryers
I replaced the timer and it still dosen't work and clothes don't get dry
you have to check the igniter fisrt, if your dryer is white you have a plug at the lower left corner, remove it,turn the dryer on and look for the igniter to glow. if you see no glow after 1 minute replace the igniter. if it glow and goes off and no gas is ignited then replace the coils.
Feb 13, 2011 | Roper RGX4634KQ Gas Dryer
Dryer is not putting out heat. Gas is connected and working in other parts of the house near the dryer.
Check the ignitor underneath the drum. (You have to open the panel to see it) It should glow shortly after the dryer starts, then the flame starts and the ignitor shuts off. If the ignitor does not glow then it or the thermostat is bad. If the ignitor is glowing but the gas does not light then the flame sensor may have to be replaced. If the gas ignites but does not stay on either the flame sensor or the coils are at fault.
See also: http://home.howstuffworks.com/how-to-repair-a-dryer.htm
If everything above is OK then the thermostat2.gif or the auto sensor is not working correctly.
Nov 24, 2009 | Roper RGX4634KQ Gas Dryer
I have a 6yro roper gas dryer. model : rgx5634kq2 everything works except it wont heat up ignitor is good as well as thermal fuse
Hello, If your igniter is glowing does not mean it's good, Take a look at it while it is glowing..Is it orange in color..Uneven glow? then it's bad...the igniter needs to be pulling 3.5 amps in order for a) the gas valve to open B) gas to ignite once gas valve opens. The glow should be a brillient yellow that you find hard to look at. If the igniter is bad the only other possibilty is the flame sensor. It is the gadget hooked to the side of the tube where the flame is. Using an ohms meter disconnect the 2 wires from the terminals and check for condinuity..If you have no reading (condinuity) you should replace it. Good Luck!!! If you have any other questions or concerns please feel free to comment again. Mike
Jul 23, 2009 | Roper Dryers
Dryer wont heat
ck whiten thermal fuse on blkower housing of dryer may be behind back panel..if fuse of ck the flame sensor with volt ohm meter should show a complete circuit..or just jump it out in any case should be 110volts fed to connector going to valve ..also may be bad ignitor (glow plug)may show burnt spot
Sep 18, 2008 | Roper RGX4634KQ Gas Dryer
Roper Gas Dryer
Taking the back off the dryer towards the bottom in the center there is a white pc.of plastic about 3 inches long and 3/8" wide. Its clipped on the inside panel and has a screw securing it. It has two wires clipped to it.Thats the fuse ! I got a replacement form the local Sears parts store for about $15.00.
Oct 27, 2007 | Roper RGX4634KQ Gas Dryer
Roper gas dryer not heating
the glow plug (ignitor)must draw 3 amps or more to function properly if its ok check the flame sensor for continuity located on the side of the burner housing and if its ok then the gas coils on the top of the gas valve are faulty let me know if this helps
Sep 11, 2007 | Kenmore 74962 Gas Dryer
Dryer won heat timer dosen't avance
huntman, the model posted shows as a gas dryer. In the lower left side there is a square plastic peep hole. Take a putty knife and pull it off. Set the dryer to high heat and take a look in the hole. Does the ignitor glow? If it doesn't you either have a bad thermal fuse or a bad ignitor. Start with the thermal fuse. You will have to remove the back panel to get at it. I will attach a photo. You can ohm it out, or just jump the wires temp. to see if the ignitor glows. If theral fuse is good and the ignitor does glow, you probabley have a bad set of coils. These sit on the gas valve are easy to replace. The timer won't advance without the heat. Check this out first...Catriver..post back.
Mar 15, 2007 | Roper RGS7745PQ Dryer
Roper RGX4634KQ Gas Dryer Logo
117 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Roper Dryer Expert? Answer questions, earn points and help others
