Question about Cameras
My HDV527W camera only says usb connected and it never charges
I've plugged my camera into the computer for countless hours and have unplugged it and it still doesn't charge. Is it the battery that needs replacing or is it something that I'm not doing right? When I plug it in, all it says is USB Connecting and when I unplug it, it doesn't turn on when I try to push the power button.
Have you loaded the driver program for the camera ?
Also the camera should be switched on when connecting to the PC.
Posted on Feb 20, 2012
  • Eric James Stuart
    Eric James Stuart Feb 20, 2012
    How do I do that? The camera just says USB Connecting when I plug it in and it hasn't turned on for like, 6 months. And what's the driver program?
Nikon s6300 won't turn on
Coolpix Cameras are tricky to use with chargers. I will assume your USB Charger EH-69P is 100 - 240V 50/60 Hz so it CAN work in many places around the world with an adapter. Do not go over 240V or you could damage it.
These cameras like to have the power supply connected when it is on to charge - meaning if you have it connected and you plug the charger in the wall it will NOT charge. So if you plug the charger in the wall first and then plug the cable in the camera it will work. The camera is actually ON when it charges and I never REMOVE the memory card when it is ON.
When you have a dead battery. Plug the camera in and make sure the ON LED lights and the Charge LED flashes. Then don't mess with it. Let it charge completely (Charge LED stops flashing and is OFF) and then unplug it. It will turn off. Then later you can turn it on.
May 08, 2017 | Nikon COOLPIX Cameras
My computer doesn't recognize my fujifilm finepix 98100 anymore.
Try NOT connecting your camera to your computer.
The best way to transfer pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa.
Organize edit and share your photos
Nov 23, 2012 | Fuji FinePix Cameras
I cant download pics off my camera to my computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Nov 02, 2012 | Canon Cameras
I can't upload my photos from my camera to my computer! help?
You neglected to specify the make and model of your camera so I'll assume it uses a memory card of some type.
Aug 15, 2012 | Cameras
Camileo P10 charging problem
I had the same problem with the P10 not charging via USB, I purchased mine second hand so it came with no charger. I assumed it would charge by the USB cable but it did not, the red light flashes but doesn't charge. Luckily I have an external battery charger for a different camera i got some years ago that takes a similar battery , the P10 battery didn't fit properly so I had to place it at a 45 degree angle into the charger making sure the outer contacts were lined up properly and taped it into place. After an hour it was fully charged and the camera is working fine. The charger is a 4.2 volt charger. New external chargers can be picked up on ebay cheaply
Jul 04, 2012 | Toshiba Camileo P10 Flash Media Camcorder
My camera has been plugged into the computer for 24 hours now and the battery still isn't charged. How long does it take to charge and how will i know when it is done charging? i have a Vivicam X029
The manual merely says "a few hours." The LED on the back of the camera lights up while charging and goes off when finished. Not all computer USB ports put out enough current to charge batteries. If you're using a hub, bypass it and connect the camera directly to the port. If that doesn't do it, try another port if available. If that doesn't do it, use the supplied AC adapter and plug it into a wall outlet.
Aug 05, 2011 | Vivitar Cameras
Hi! I've recently discovered that I cannot find my usb cable for my Polaroid t730 camera. I've looked everywhere and am worried that I cannot get a replacement. Is there anywhere that I can find a...
Consider NOT using the USB connection.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Jun 12, 2011 | Cameras
I have plugged it in and it my computer will not recognize that the USB is even plugged in, but it does charge the camera.
Try all the different USB Ports on your computer, sometimes certain ports can 'glitch' and not recognize the device that you've plugged in. If you've tried plugging it in all the ports and your computer still hasn't recognized the camera, re-install the driver software for the Olympus SP800UZ.
If all else fails, you can also contact Olympus customer service, they're quite prompt and helpful.
May 17, 2011 | Olympus SP800UZ Digital Camera
My camera won't charge, i plug it into the computer throught the USB & the camera lights up like it's actually charging but after a cpl hours I took it off the USB & as soon as i cut it on it cuts...
The C1033 does NOT charge batteries. By plugging it into the computer you've actually drained the batteries faster since the camera has to spend juice communicating with the computer (even if only to say it has nothing to say). Put in a fresh set of batteries, and next time don't leave it connected to your computer.
Mar 26, 2011 | GE C1033 Digital Camera
Cameras Logo
43 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
