Question about CDV Software HIP INTERACTIVE Sudden Strike 2 for Windows
Sudden Strike2 running too slow how to accelerate?
My ford icon 1.6i only accelerate at 2000 rpm and idel between. 0.900/1000rpm and use accessive fuel..pullaway is weak??
Problem with my Ford Ikon 1.6? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jun 10, 2012 - The same problem presist on slow speed also. ... Still the problem presist on sudden acceleration and when we strart up in signals. .... Ford ikon 2002 clx 1.6i starting problems start quick on running can it be the starter?
Ford Ikon fuel consumption, miles per gallon or litres/ km ...
www.cfcr.eu/ford-ikon-fuel-consumption-miles-per-gallon-or-litres-km
Ford Ikon fuel consumption, miles per gallon or litres/ km ... How much fuelconsumed Ford Ikon 1.6 i, liters / 100 km or miles per gallon. Ford Ikon 1.6i it is a ...
Oct 24, 2015 | Ford Cars & Trucks
Car all of a sudden after getting gas wants to stall and slow to accelerate it also sounds rugged and wants to stall, could it be bad gas?
yes it does sound like you got some bad gas. there could be water in the fuel causing these problems.
Jun 03, 2014 | Cars & Trucks
The car will run fine for about 10 minutes then it will stop accelerating???
ENGINE HESITATES WHILE ACCELERATION
LOSS OF ACCELERATION
It can be fuel pressure issue or it's the problem with accelerator pedal or its clogged filters causing there.
There are many other possibilities. I suggest you to go through the list of help links mentioned below, these will help you to confirm where the actual fault lies: -------
Jerks and Hesitates During Acceleration?
http://technoanswers.blogspot.in/2012/07/2004-dodge-town-country-jerks-and.html
Loss of acceleration?
http://technoanswers.blogspot.in/2012/02/loss-of-acceleration.html
Headlights flickering and car hesitates to start?
http://howtobyme.blogspot.in/2012/02/headlights-flickering-and-car-hesitates.html
How exactly the Vehicles Accelerator Cable works?
http://repairhelpcenter.blogspot.com/2011/11/how-exactly-vehicles-accelerator-cable.html
How exactly Vehicles Accelerator Pump Diaphragm Works?
http://repairhelpcenter.blogspot.com/2011/11/how-exactly-vehicles-accelerator-pump.html
2000 Toyota Avalon: Engine Lean Codes and Knock Sound on Acceleration?
http://whatisbyme.blogspot.in/2012/05/2000-toyota-avalon-engine-lean-codes.html
2004 Toyota Avensis: Acceleration And Deceleration makes noise on Front End?
http://whatisbyme.blogspot.in/2012/05/2004-toyota-avensis-acceleration-and.html
Wheel hop under hard acceleration?
http://technoanswers.blogspot.in/2012/04/wheel-hop-under-hard-acceleration.html
2009 Chevy impala accelerator pedal sensor?
http://technoanswers.blogspot.in/2012/02/2009-chevy-impala-accelerator-pedal.html
Nissan Pathfinder stalls and bucks on Acceleration?
http://technoanswers.blogspot.in/2012/02/nissan-pathfinder-stalls-and-bucks-on.html
Acceleration lag problem?
http://repairhelpcenter.blogspot.com/2012/01/acceleration-lag-problem.html
These details will help.
Thanks.
Nov 28, 2012 | 1999 Mercury Cougar
My vitz loses power when going uphill and when overtaking ie sudden acceleration. instead of gaining speed it slows down. what causes this problem. thanx
Usually a bad catalitic convertor does the exaust can't come out the tailpipe clogging the system n not allowing it to work as it should
Jul 14, 2011 | Toyota Yaris Cars & Trucks
I have a 95 cavalier. I have had a new control module and 2 new coils installed. I have new spark plug and wires. I have a new heat sensor. My problem is. Im driving down the road and my idle is rough at...
There is a part called a throttle positin sensor which would do very much as you described it.The sensor cannot detect how much gas you are giving it nor does it know how much gas is being delivered.It is also an input for the control module which tells the rest of the system how to react.The symptoms of sudden acceleration and slowness could also be the transmission(not very likely though),but the rough idle and strange acceleration appear to be more likely the sensor.The transmission would likely have other symptoms such as rough shifting,gears winding out if you know what I mean,shifting back and forth between gears at a certain speed in which you are just at the same speed,meaning not accelerating or slowing down,say just cruising at 35 mph.Also,there are no lights because the check engine light HAS to be the worst thing ever invented for a car.It illuminates for things even when your car is running fine,but you would think for something like your situation,SOMETHING would illuminate.People have spent thousands replacing everything which the computer tells them from the check engine light diagnostic,yet it remains on.I have seen it.If you are in the USA,call any AAA approved shop and they would likely say something similar.Good luck,Greg
Mar 02, 2011 | 2004 Chevrolet Cavalier
How to have more mileage without compromising the power and speed???
Some of the general points are given below if followed will help you a lot on daily basis 1 Cut down on Static running of the engine. Reduce the idling time 2 Do not accelerate with out any reason when you start in the morning. 3 Fill the right fuel and oil. 4 Always run the vehicle on the recommend speed by the manufacturer which is given in the manual provided. 5 Avoid sudden burst of speed and then slowing down by sudden breaking. 6. Keep the tire pressure correct as less pressure burn more fuel and use more power. 7 Clean the spark plugs every fortnight. But once a month is a must. 8 Do not Overload. 9 Real good tip which you may not have been told i.e. When you reach the particular speed and are running it on for some time, reduce the acceleration. This way the vehicle will run without extra consumption of fuel due to the momentum it has already gained. This can cut down consumption fuel by 10 - 25 % depending on the nature of drive, short or long.
Dec 09, 2010 | 2008 Yamaha YZF-R15
I have an 1997 saturn sl manual trans all of a sudden it';s slow to accelerate and the rpm's skyrocket when trying to get any acceleration
Sounds like a slipping clutch. The engine races but the car fails to respond quickly as if it is disconnected. The issue will be worse when trying to ascend hills. There is no easy fix, you need to renew the clutch disc.
Sep 03, 2010 | 1997 Saturn SC
My 1988tE slow acceleration, bad cold start
You have either a fouled plug or clogged injector this is common when not using premium fuel try a good octane booster and injector cleaner in the same tank of fuel in will shudder till the clog is dislodged If this does not help change you sparkplugs when your car is running correctly you will be able to Haul again Love My 89 TE would'nt trade it for any SUV
Jun 07, 2009 | 1988 Mercedes-Benz 300
CDV Software HIP INTERACTIVE Sudden Strike 2 for Windows Logo
65 people viewed this question
Top CDV Software Video Game Consoles & Games Experts
James Wishart
Bill Boyd
EnergeeUK
Level 1 Expert
Are you a CDV Software Video Game Console and Game Expert? Answer questions, earn points and help others
