Question about Kenwood Car Audio & Video
Need tto know how to wire kenwood ps200t amp because it is different than others
4 Suggested Answers
  • 58 Answers
SOURCE: i pulled the wires out of the abs plug that goes
Splicing your wires together will accomplish nothing but to waste your time.The sensors send an electrical signal to the computer.No signal means no ABS and the light will turn on.You will not get a signal by splicing the wires.
Posted on Oct 18, 2009
  • 150 Answers
SOURCE: I NEED TO KNOW HOW TO WIRE THREE 3012 THWELVES TO
Its hard to tell what you can or cant do without knowing exactly which kenwood amp you are using. Generally speaking though most kenwood amps are stable only down to 2 ohms. you will be better off just using 2 of your 12s wired in parallel- that will give you a 2 ohm load. There is a way to use all 3 simply by wiring them in series, it will end up giving you a 12 ohm load on the amp though which will work fine but you wont ever achieve the full power that the amp can do.
Posted on Jan 31, 2010
SOURCE: kenwood model kdc 128
Blue with white stripe.
Posted on Aug 04, 2010
Need a wire harness plug for a kdc319
Kenwood adapter looms are readily available from your local Auto Accessory store, of from Ebay.
These are a 'plug & play' solution (pre-wired), which eliminates the need to cut any of your existing vehicle's wiring.
Ideally, you want a single adapter loom with Kenwood plug on one end, with your vehicle's "factory" plug on the other (all common brands are available).
e.g. Kenwood ---> Ford; Kenwood ---> GM etc etc
Cheers,
Dec 30, 2012 | Kenwood KDC-319 CD Player
I need to know how to wire this to my amp i have never wired a 3 way system and i need to know if i do any thing different
Typically on these units there is only one hookup for the amp or a left and right hookup. The crossovers are already inside the speaker box and will send the highs to the tweeters and the lows to the subs. Make sure that if you amp has an adjustable crossover that it is set to full so that all frequencies go to the speaker box.
Mar 11, 2011 | Kenwood KSC-7702 Car Speaker
I'm putting in a kenwood and the wires are different then my factory wires, how do you go about know where goes what after you splice the wires
i would go to walmart and get a wire connector to fit the plug so you don't have to cut the wires that way if you need to put factory back in nothing is cut
Mar 08, 2010 | Kenwood KDC-319 CD Player
I NEED TO KNOW HOW TO WIRE THREE 3012 THWELVES TO A 1800 WATT KENWOOD AMP
Jan 17, 2010 | Kenwood Kfc-w3012 12" 2400 Watt Car Subs...
Kenwood kac-x1r flashes code e-03
HI DUDE EVERY REMOTE WIRE THEY HAVE FUSE NEAR THE BACK OF PLAYER TRY TO CHANGE IT .... R...TRY UNPLUG UR AMP .. AND ..FIX IT BACK
Apr 16, 2009 | Kenwood KAC-X1R Car Audio Amplifier
I need to know how to wire my 2 12' kenwood w3514 dvc sub woofers parellel
For parallel connections, simply wire posotive to positive and negative to negative. But beware! this lowers the impedence (ohms) by half. In other words if you have 4 ohm woofers, in parallel they would be two ohms. Make sure your amp can handle that. Otherwise connect them in series.
Apr 04, 2009 | Kenwood KFC-W3514DVC Car Subwoofer
Diamentions off subwoofer box for 600watt in meters please
You need to know the speaker travel distance (excursion) and a few other numbers from the maker of your speaker, then you can plug those numbers into a box calculator. Just the wattage isn't enough to know.
Also, you will get different numbers for sealed, ported, and bandpass boxes, so you need to know which type you want ahead of time.
Mar 16, 2009 | Kenwood KFC-W2505 Car Subwoofer
Hello, I have a Kenwood KDC-MP225 powering a KAC-8101D that was pushing 1 Bazooka EL1200, the last amp blew the other 1... I was driving along 1 day and cranked it up before the cd started playing, I...
First off try a different source that you know works that you can control the volume of. (ipod) This will tell you if the amp works. If it still doesn't work try a different speaker that you know works, any speaker will do, just keep the volume down. Second see if running a new set of RCA's helps maybe something got pinched if it still is not working then your head unit line out is bad, try a different output and see.
Thanks,
Mark
Nov 20, 2008 | Kenwood Car Audio & Video
Car sound system
You probably have a phasing problem. Reverse the speaker connections on ONE of the amps.
Sep 28, 2008 | Kenwood Car Audio & Video
Car Audio & Video Logo
79 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
