Question about LG WM-2277HW Front Load Washer
LG washer comes on then shuts off
Just that! it comes on then turns itself off
  • thatchick Oct 27, 2008
    plz i need help to fix it . I have alot of clothes and I need to get them done
    Scholar:
  • 62 Answers
I need a little more info, does it make any sounds b4 it shuts off is there any codes F1 or anything like that. Does the water start to fill? Does it start to rotate or anything at all b4 it shuts off?
Posted on Nov 05, 2008
How do I get my lg waveforce WT5001C washer to turn on? The power went off and now the washer lid is locked shut and none of the lights are on. I checked the wall plug and it is fine.
Having the same problem with my LG WaveForce top loader. Power went off and now lid is stuck shut and machine will not turn on. Power outlet is fine.
Aug 27, 2013 | LG WT5001CW 27" Top Load Washer with 5.2...
My LG washer (Lg tromm Wm2377cs) is coming on by itself when the door is open. The panel stays lit, then eventually goes dead, only to come on again later by itself.
not just yet? still need to check other items? the timer, the push start? etc buying a new board may not solve ur issue less ur sure of the cause, the door actuator may be stuck closed however cant see how it would effect the start staying continually on so I would check both out at the least
Mar 08, 2013 | LG WM-2277HW Front Load Washer
Not cooling and shutting off, indicator light flashes
the outdoor indictor light on my lg split comes on after some minutes on the one inside and the cooling has reduced please can any1 tell me what the problem is
Jan 18, 2013 | LG LSC121PMA Split System Air Conditioner
LG LCD comes on and then shuts itself off after about 10-15 seconds.
i had the same problem i turn the backlight off and it stays on
hope this will help
Feb 26, 2011 | LG 42LC2D 42 in. LCD HDTV
LG front loading washer is turning itself on,then off
You have a fault microprocessor, or the "Brain" is sporadically faulting... You need to get this looked at... it isn't a minor thing unfortunately... look get a firm "Quote" from a reliable service center man
Jan 31, 2010 | LG WM2455 Front Load Washer
Tub filling with water after cycle is finshed
If your washer fills with water, usually slowly, after the cycle is over you have a inlet water valve which is not shutting off completely. LG usually uses a separate valve for the hot and cold. If you turn off the valve where the hose comes from the house and observe for continued water fill, first one, the reopen it, then shut off the other you should be able to see which (hot or cold) is the culprit. If you post your exact model number I should be able to list the part numbers for you. The inlet valves I am speaking of are the part where the hoses connect onto your machine.
Nov 07, 2008 | LG WM3677HW 3.7 cu.ft. Front Load Washer...
LG Font Load Washer flashing error code FE
FE is Fill Error. If door is closed and washer is plugged in, FE means water is too high and water pump will turn on.
This happens most often when a water fill valve will not shut off completely, allowing water to continue to fill washer, sometimes very slowly. If you shut off one valve (where the hose comes from the household plumbing) at a time you may be able to tell which valve is the culprit. The hot is a single coil valve, the cold is a multi coil valve. Both are the part where the hoses connect onto the machine.
To access valves, remove 3 phillips head screws at the back of the washer holding the top cover in place. Slide the top back about two inches and lift it off.
Oct 12, 2008 | LG WM-2277HW Front Load Washer
Lg plasma mt 42pz10
I wish I had an answer for you but I'm in the same boat. I've got a 42pc5d and it's doing the same thing. I'll turn it on using either the remote or the power button on the unit itself. The LED will blink either two or three times, then shut itself off. I tried plugging the unit into a different outlet. I tried unhooking all inputs (PS3, DVD player, antenna, etc). The tv was still shutting itself off. I called tech support and the lady who answered asked me if there was a power button on the unit. Well, of course I understand LG has hundreds of models but I felt like I was dealing with someone who didn't care enough to even open the manual to see for herself. Anyway, after a "reset", the TV is now nothing more than a very expensive paperweight. To say I'm displeased is an understatement.
May 03, 2008 | LG MZ-42PZ14 42 in. Plasma Television
LG WM-2277HW Front Load Washer Logo
897 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
