Question about Car Audio & Video
Wiring harness for Performance Teknique ICBM-5254 (or wiring diagram / help with wiring)
Ok so this item has been in storage for a long time, and I just recently found it. My friend wanted it, but we had to hook individual wire clips to the pins out of the back of the stereo because the harness is gone. Unfortunately, the wiring diagram lists 14 wire connections, and there are 16 pins. Is anyone that owns this product able to shine some light on which (1 being top left when looking at pins, 16 being bottom right) pins go to which wires? Thanks in advance for any info. you can provide.
KaeZoo
  • 156 Answers
SOURCE: wiring diagram
Red: voltage source controlled by the ignition key Yellow: constant voltage source Black: ground Blue: power antenna activation wire (if equipped) Blue/white: amplifier activation wire (if equipped)
Posted on Jun 06, 2007
  • 631 Answers
SOURCE: performance teknique icbm-896 stick on diagnostics
If it's in protect mode, it probably has shorted output transistors. To eliminate other possible problems, read through the following page:
Amp in Protect Mode - Troubleshooting
Let me know if you have any other questions.
Posted on Sep 11, 2008
  • 631 Answers
SOURCE: performance teknique icbm 892 1200 watt amp
DD, JL and pioneer in that order. I don't recommend any particular size but 12s are a good compromise.
Posted on Sep 22, 2008
blueextc3221
  • 15935 Answers
SOURCE: ICBM-DIGITAL MONO-Channel 2000W AMPLIFIER speaker much
Look into competition lines of different manufacturers.... Massive Audio DMX, Soundstream, Atomic APX, Incriminator Audio Death Penalty Series, Kicker Solo X etc. In car audio, you have to pay to play. Dont expect a 100.00 subwoofer to take 2000W continuously.
Massive Audio offers a no questions asked warranty. Even covers blown voicecoils!
Posted on Dec 22, 2008
SOURCE: Need a Nak CD-45Z wiring harness, or diagram
Rob, I had the exact same problem, I kept searching on line and came upon Alex in Australia, he deals in Nakamichi products, and has the part (plug/wiring harness). He charges $55 for the part and $30 for express shipping.
Here's his email: aminassian@optusnet.com.au
I have also found a site with the Manual: http://www.nakremotes.com/default.htm
Click on "Model List" and look for your model, in the manual there's the wire color code for the pinout. I also have the pinout by wire color, no room to include, will send in another response.
TOP
[ 1 2 3 4 5 6 7 ] Looking @ pins in socket
[ 8 9 10 11 12 13 14 ] Naka CD45-Z deck
Note: The above diagram is done from the perspective of looking directly on to the connector pins. If you are having trouble figuring out which way is which, just use the ground wire, which is always black, as a reference for making sure you are doing the pins correctly.
Posted on Jan 26, 2009
Need pin out for a Performance Teknique icbm-9706 i lost my harness
It should be a standard 12 pin wiring harness used in many products.
I suggest getting a harness off another set.
Jan 14, 2017 | Performance Teknique Car Audio & Video
Installation-wiring
Performance Teknique might be able to supply a manual and/or wiring instructions.
Jan 01, 2014 | Performance Teknique Icbm-7348 Cd Mp3 Wma...
I needed the conector for performance teknique icbm 9778
i have the whole stero but if you want to we can talk ...mine works perfectly but the monitor doesn't flip up cuz i rip the wire that's connected between the stero and monitor..call me at 562 480 7084 thanks
Jan 01, 2013 | Performance Teknique ICBM-9778
Hey I just recently buy a performance teknique
good luck finding one, check ebay, or call Teknique directly.
Feb 13, 2010 | Performance Teknique ICBM-9794 Car Video...
Wiring 12" icmb-5612 preformance teknique subwoofer
That sub has dual 4-ohm voice coils. It can be wired either as 2-ohm, 4-ohm, or as 8-ohm.
2-ohm = voice coils in parallel (both positives and both negatives connected to your speaker amp out wires).
4-ohm = use only 1 voice coil (either is OK).
8-ohm = voice coils in series (connect the positive of one voice coil to the negative of the other and connect the remaining positive and negative to your speaker amp out wires).
Mar 24, 2009 | Performance Teknique ICBM-5612 Car...
I lost user manual for Performance Teknique ICBM-9493TV Car Video
Yo I have a icbm 5254 in dash monitor and in order to bypass the parking brake security, splice the wire that's marked "park brake"(mine is Pink, yours may be Orange,but it'll be the oddball colors) into the acc or aux wire(usually yellow) and it'll play dvd while moving. Hope this has been helpful.
Feb 28, 2009 | Performance Teknique ICBM-9493TV Car Video...
Performance teknique icbm-896 stick on diagnostics
Sep 10, 2008 | Performance Teknique ICBM-896 Car Audio...
Performance Teknique ICBM-779
You may have a defective speaker or a wiring fault. Disconnect the speaker from the amp and measure the resistance across the speaker wires. The resistance should be near the rated impedance of the speaker.
Jan 27, 2008 | Performance Teknique ICBM-779 Car Audio...
Performance Teknique ICBM-9550 Amp Problem.
one of the power transistor of your unit shorted check use a tester
Aug 27, 2007 | Performance Teknique ICBM-782 Car Audio...
Car Audio & Video Logo
99 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
