Question about Interactive Health Health & Beauty
Who has an ijoy chair power cord
Need to attain a new power cord for my ijoy chair. Where can I find it's power cords? Need supplier names and contact information.
4 Suggested Answers
jyackle5
  • 8197 Answers
SOURCE: Need new transformer and cord to connect to Chair
You can get the cord on the link below.
http://www.zis4u.com/brookstone-adapter-12vac-2000ma-p-364.html?cPath=40_41
Good Luck and please rate 4 thumbs up for the free answer
Posted on Jun 27, 2010
SOURCE: Need parts & repair manual for the iJoy 100 massage chair..
i have camel electric massge chair repair centre in mumbai address and contact numbr . plz help me
Posted on Dec 08, 2011
SOURCE: Massage chair fuse on it keeps blowing Model iRest SL-A08-3L
Get its PCB checked for any shorting or ask a technician to brush up the whole pcb with some alcohol and try 5A fuse instead of 4A. You can also look for latest Jade massager bed Carefit 5000 which is more advanced than a massage chair
Posted on Jun 09, 2012
Where can i find the fuse?
What Can Break in a Massage Chair? - Elite Massage Chairs
https://www.elitemassagechairs.com/what-can-break-in-a-massage-chair/
So believe it or not, the most common problems in a massage chair - about 90% of ...but it's not always easy depending on the design of the chair to find the fuse that ...This is the electric motor that moves the footrest up and down in a smooth ...
power outlets fuse location Electric Massaging Chairs ...
www.fixya.com > Forum > Tags > power outlets fuse location
Electric Massaging Chairs power outlets fuse location questions and answers. ... I need to find the massaging mechanism unit for my ijoy 250 massage chair Product ...Where can I purchase a plug in outlet chord (power chord) for the osim ...
electrical fuse blown Electric Massaging Chairs Questions ...
www.fixya.com > Forum > Tags > electrical fuse blown
Electric Massaging Chairs electrical fuse blown questions and answers. ... In short does anyone know where I can get a circuit board for this chair? ... I need to find the massaging mechanism unit for my ijoy 250 massage chair Product manual: ...
radio ht Electric Massaging Chairs Questions & Answers ...
www.fixya.com > Forum > Tags > radio ht
Electric Massaging Chairs radio ht questions and answers. Ask your radio ht electric massaging chair questions. Get free ... Do you know where I can find fuses?
Amazon.com: Electric Full Body Shiatsu Massage Chair ...
Dec 14, 2015 | Furniture
Replacement Upholstery
I have the same problem. Did you ever find something?
Apr 29, 2013 | Interactive Health Ijoy 130 Massage Chair
Power plug on chair losing power
The problem may be that the power cord's internals were broken by keeping the wire plugged into the chair at a bad angle That damaged the connection. If this is the case, you may need to purchase a new power cord.
Try shopping online for a replacement or calling the manufacturer.
Jun 01, 2012 | Pyramat Sound Rocker Gaming Chair
I'm borrowing a Jet 3 Ultra from the local Am. Legion for my Mom to use. They know nothing about it except they were told it had a new battery. I plug it in and all the LED's light up with the...
The batteries need charging and when you plug in the charger and the power is on the lights wil flash indicating that the charger is plugged in. Now look at the rear of the chair near where the charger cord plugs into the chair and you should see a voltmeter. With the charger plugged in the voltmeter will indicate about 5-6 amps and after charging overnight the voltmeter should be reading 0 amps. If when you plug in the charger cord and the voltmeter indicates 0 amps then I would suspect that the charger is not working or that the fuse is blown in the charger circuit. The only way to see if the batteries charge would be to borrow or find an offboard charger that will plug into the charger port located under the front of the joystick and after charging for 10-12 hours see if the battery level lights show full charge Hope this helps
Jun 25, 2011 | Pride Used Mobility Jet 3 Power Wheel...
When I plug in my Jet 3 Ultra 4500, it seems to charge - the charging lights come on - but it never charges. In fact, I can't get it to move at all, even when plugged in. I think I am using the...
when you plug in the charger do you get any amp reading on the meter located at the rear of the chair near where the charger cord plugs into the chair. When you plug in the cord the meter should deflect and read 6 amps or so. If you aren't getting any deflection of the amp meter then either the batteries are dead or the charger is bad. If you have a voltmeter you can set it to 200 volts dc and plug the leads into the charger port located under the front of the joystick Plug the leads into the 2 outter holes of the port with the charger plugged into the wall you should be reading 27-30 volts. Unplug the charger and you will be reading the battery voltage and fully charged they should read 25-27+ volts. If you aren't reading 25-27 volts without the charger plugged in you will need new batteries( anything less than 10 volts will not let the chair turn on) if you aren't getting 27-30 volts with the charger plugged in then the charger is bad and you can get or borrow an off-board charger and charge the chair thru the joystick port Hope this helps
May 07, 2011 | Jet 3 Ultra Power Chair
I HAVE A JET 3 ULTRA CHAIR, WE LOSS THE 24V PRIDE JET 3 Ultra Power Chair Smart Battery Charger, CAN WE USE A COMPUTER CABLE INSTEAD IF NOT WHAT CAN WE DO.
You can use the AC charger cord from a computer as a replacement for the AC cord of the charger. If the AC cord plugs into the wall and plugs into the charger or charger receptacle on the back of the power chair, you can use it.
If I remember correctly, This chair has a 4 Amp on-board charger which has an AC receptacle on the back of the chair to plug in an AC cord. The off-board chargers take a universal AC cord which will work with a universal computer AC cord. If the AC cord plugs in, use it.
Nov 25, 2010 | Pride Mobility Products New Pride Mobility...
Nov 09, 2009 | Human Touch Ijoy 100 Robotic Massage Chair...
Health & Beauty Logo
29 people viewed this question
Top Interactive Health Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you an Interactive Health Health and Beauty Expert? Answer questions, earn points and help others
