Question about Water Heaters
Nlsh18an reset help
I have one of the above heaters. The outut was covered by a rack of drying clothes falling on it (yes lesson well learnt) and heater is now not working so am guessing thermal fuse has blown. From trawling the internet I am pretty sure that this heater has a resettable switch. Can anyone tell me how to reset. THanks for your help.
  • stephanie croce Feb 20, 2012
    The above is a night storage heater but I'm sorry I don't know how to re-post in appropriate section.
  • 659 Answers
SOURCE: My Rinnai infinity 20 water heater isn't working.
http://www.rinnai.com.au/h_water/..%5Cpdf%5CHW%20man.pdf
Follow the link above for your usuer manual. Hope this answers question and solves your problem.
Posted on Mar 21, 2009
oldmanewtoys
  • 414 Answers
SOURCE: Do you know of any water heater manufacturer in
they were designed reduce heat loss after usage. I have never seen or heard of such a thing and I have replaced a couple hundred tanks in the last 10 years at appartment complexes and installed 4 new tanks in my homes too. There is something else going on with this deal sounds funny
Posted on Mar 05, 2010
  • 7 Answers
SOURCE: reliance gas water heater 640ycrs pilot light will
if water heater will heat a tank of water before the pilot light goes out you need to replce the gas thermostat
Posted on Mar 17, 2010
  • 395 Answers
SOURCE: How does the reset work? I am helping a friend
The reset button is set up to open the circuit if excess current is drawn by a failed Element. It works by getting hot and switching off due to current above its rating. The burnt wiring more llikely happened over a period of time because of a resistive joint in the block getting hot due to the high current that water heaters consume. It seems that the element has failed if the reset button does not get the system working.
Posted on Sep 17, 2010
SOURCE: I have a bosch mod.
1) Call Bosch.
Gas Products Technical Support: 800-642-3111
Electric Product Technical Support: 866-330-2729
2) Save money and buy whole new tank-type
electric water heater at local box store for $250, and go on-line and get coupons before purchase.
http://waterheatertimer.org/pro-n-con-for-tankless-water-heater.html
Posted on Sep 15, 2011
Why doesn't my dryer dry clothes?
You can find the Installation Instructions and your owner's manual here: http://www.kmart.com/whirlpool-duet-174-7.4-cu-ft-he-gas-dryer/p-02692332000P The links are about halfway down the page and are in red. There are instructions for cleaning the lint screen, which if clogged, will effect the drying time. Hope this helps.
Jun 25, 2014 | Whirlpool Duet WGD96HEAW 7.4 cu. ft. Front...
Water in basement in flood that covered the lower element. When power was turned back on, the green light on the top of the heater was blinking twice. When I hit the reset button, it is now blinking...
Yes sensor should be replaced along with lower element.
1) Manufacturer's say that flooded water heater should be replaced: Call homeowner's insurance company.
http://waterheatertimer.org/Flooded-water-heater.html
2) Brand of water heater is not known, but it could be the American or Craftmaster or Whirlpool energy-smart electric with control box.
http://waterheatertimer.org/Whirlpool-Energy-Smart-electric.html
3) With energy-smart:
1 flash is start-up failure, and 3 flashes is sensor failure.
The moisture probably shorted element and/or lower sensor.
4) The moisture inside tank will take long time to dry out, especially since the foam insulation is wrapped tight. To dry out element and sensor, you have to remove cover and insulation over element, but if you leave insulation off and run water heater, then the sensor is exposed to cool outside air and will not read temperature inside tank.
Plus a wet water heater is electric shock hazard.
5) Add a comment for more free help.
6) Take a moment and rate answer for accuracy:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 13, 2011 | Water Heaters
How do i troubleshoot the element and thermostat to determine if they are working?
Troubleshooting requires some electrical skill and cheap multimeter from home center.
Plus understanding that 240Volt water heater can kill you if it has gotten wet or is wet, or if you touch electric terminal, electric wire, or electrified part, or if water heater is improperly grounded, or if you stand on wet surface or touch metal pipes or anything metal or any grounded object.
Be sure to stand on dry boards or dry surface, do not stand on bare soil, and wear dry clothes and shoes, and don't touch or lean against anything metal, or on a metal ladder, or put metal object in mouth, and tape tester leads to wood sticks to keep hands away from electricity. And don't sweat.
Other than precautions above, testing electric water heater is simple enough using information on following link:
http://waterheatertimer.org/How-to-troubleshoot-electric-water-heater.html
http://waterheatertimer.org/images/Test-water-heater-with-Multimeter.jpg
Look at label on side of tank to see voltage of water heater and wattage of element(s)
Also take advantage of fixya expert assistance live.
Apr 22, 2011 | Whirlpool Water Heaters
It has cold water comign out no hot
Yes, the reset probably is tripped...push in the red button hard
Then turn it on and try it...
Check out this tip..
How to replace the Thermostat and Element for
Electric Hot Water Heater
heatman101
Jan 18, 2011 | RELIANCE ELECTRIC WATER HEATER
WHERE IS THE RESET BUTTON ON THE 6EM30-2 FROM AUG 2004?
Electric water heater has panels located on front of water heater.
Remove top cover, and insulation to reveal thermostat and element.
Stand on dry surface, including boards or plywood.
Do not hold screwdriver in mouth.
Do not touch any metal.
Red reset button is located on thermostat.
Push in reset.
If reset will not re-engage, then thermostat may be bad, or some other problem exists.
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
Screw terminals on thermostat are live.
When finished, insulation and cover must be put back over thermostat so thermostat not exposed to cool air that will cause thermostat to misread tank temperature.
Put ear against tank to hear bubbly-fizzing sound that says water heater is working.
If water heater is leaking or wet, do not touch unless circuit breaker is turned off.
Electric water heater is fully repairable by homeowner.
ECO red reset button trips when upper thermostat senses overheating.
You many have underlying problem if reset continues tripping:
Dec 09, 2010 | Audiovox Richmond 6EM30-2 30-Gallon 6-Year...
Water is not hot
If your water has NO hot water, then click circuit breaker
Next, click red reset button.
Turn off power.
Open cover on water heater.
If heater has 2 covers, open top cover
After re-seting water heater, insulation must be put back over thermostat to prevent cooler air from affecting thermostat.
1) Reset button is a good starting place to check water heater.
Reset clicks off for a number of reasons, including overheated water.
2) Reset will not reset, then replace thermostat.
3) Resets clicks on, but clicks off again later, you should diagnose the problem.
Clicking reset is not a hazard
Click the reset as often as you want until you have time to diagnose.
4) Reset is not tripped, and you still do not have hot water:
Then use tester on top two screws (T1 - T3 screws -or- 1 and 3 screws) of upper thermostat to check if you have power.
If you have power, then replace thermostat.
If problems continue, a full diagnosis is needed as per the link above
If you need more help, add a comment and I will respond
Oct 29, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Water heater will not work unless i push reset button will work for 24 hours or so then will stop working and i have to go out and reset it
The reset button or ECO (emergency cut-off) is a safety device.
The ECO trips and cuts off power to entire water heater when it detects temperatures over 150 degrees.
This prevents overheating and eventual explosion of water heater.
The ECO will trip for 4 possible reasons:
1) Bad thermostat. Water temperature inside tank exceeds 150 degrees F because thermostat is sticking in ON position, and thermostat does not turn off element correctly.
2) Loose wire inside or near upper thermostat that causes ECO to sense higher temperature
3) Bad element shorted to ground near center of element, and short does not cause breaker to trip
4) Factory-installed insulation and cover are removed from water heater >>> cooler air causes thermostat to read wrong temperature, and thermostat keeps heating water inside tank
Steps you can take:
First thing is to check if factory-insulation-and-cover are present.
Next look for signs of burning at or near screw terminals. Tighten loose wire if found.
Especially check the lower element screw terminals.
Take a photograph of the parts so you can see the parts larger on your computer, and compare parts more easily when buying new parts.
Next most likely suspect are the thermostats.
For around $22, you can buy generic upper-and-lower thermostats at Lowes or hardware store > then replace the thermostat(s) and see if problem persists.
If problem continues after steps above
You will need to test water heater parts to track down the exact problem:
You need a inexpensive multimeter from Radio Shack, and the steps are simple, and you will know everything about an electric water heater afterward.
Answer back if you encounter something not covered above, and I will help.
Oct 25, 2010 | RELIANCE ELECTRIC WATER HEATER
How does the reset work? I am helping a friend troubleshoot his water heater. One of the wires that connected the pig tail to the power block fried inside the water heater cover. I decided to remove the...
Sep 17, 2010 | Rheem 81VP15S Point-of-Use Electric Water...
Rheem ap12938 anode rod installation
I suggest replacing the whole water heater instead of just the rod. Usually the water is at the end of its useful life it the rod needs replacing. You will probably need to do that soon anyway. However, if you do replace it and have no head room, you will have to totally disconnect the heater, lay it on its side to do the job. (might as well replace the unit if you are doing all that work.)
Sep 17, 2009 | Rheem Water Heater Anode Rod AP12938
Water Heaters Logo
78 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
