Question about Tefal Kitchen Appliances - Others
The plastic push down button on my Tefal Avanti Elite toaster has broken, could anybody advise me where I may source a replacement?
Tefal Avanti Elite
maklean
  • 1665 Answers
SOURCE: Avanti toaster service agent
Hi have a nice day.
See step by step procedure to repair at link below:
http://home.howstuffworks.com/how-to-repair-small-appliances1.htm
Does it helps you?
Posted on Feb 23, 2008
Merlinblaise
  • 10 Answers
SOURCE: Tefal toaster wont stay down - Avanti Elite, twin.
Hi, I assume that you had the toast carriage pushed down when you check the solenoid (hold down coil) volts ? .. a bit dangerous to try though
Either way, try resoldering the solenoid connections, they can develop hairline cracks that limit the current.
Posted on Dec 19, 2008
VtToolMan
  • 704 Answers
SOURCE: can you email the user manual for tefal toaster
Hello Val,
Here's the link directly to Tefal's site where you can select the exact toaster manual from the list provided. I wasn't sure of the exact model, since Tefal has two (2) Avante Deluxe model toasters available (both a 2 and 4 slice version) and sometimes the Fixya site only has a limited selection for certain products for users to request assistance with.
In any case, they are all on the page at the link below. Simply click and you'll get a free manual that you can save or print out for your use and future reference.
http://www.t-falusa.com/tefal/Consumer_service/Use_instructions/HomeUseInstructionsTemplateFile.aspx?NRMODE=Published&NRNODEGUID=%7bC41F9AC8-8DCD-439E-8171-0CA2B8E9C7E3%7d&NRORIGINALURL=%2fConsumer%2bservice%2fUse%2binstructions%2fuse-instructions_home%2ehtm&NRCACHEHINT=NoModifyGuest
If it doesn't come up, simply select "toasters" from the pull down window on the screen and hit "go"
I also have a folder on my computer that I've labeled "Household Appliances and Equipment" into which I save an electronic copy of all Owner's Manuals and Guides for all the appliances we have, just so they're readily available without having to search the web for them.
I hope you find this Very Helpful and best regards!
Posted on Nov 23, 2009
SOURCE: tefal avanti hi speed 4 slice toaster one side not
When the push down lever hits the bottom it pushes another little lever which makes contact with the positive and negative terminals. over time, these terminals get ever so slightly bent, especially if you start pushing the lever down hard. what you have to do is take the toaster apart, get to the positive and negative terminals and pinch back into shape with some pliers. you should understand once you look at it. Then put back together. if it doesn't work then it's likely a component has gone so, unless you have a multi-meter and a soldering iron I wouldn't suggest doing this.
Oh yeah, unplug it before you do anything.
Posted on Aug 19, 2010
eugbug
  • 479 Answers
SOURCE: I have lost the manual for my tefal avanti deluxe
The instructions can be downloaded here:
http://www.tefal.co.uk/NR/rdonlyres/89C9BBE6-235A-4142-B9E4-9D5C115AD973/0/Avanti1.pdf
Posted on Mar 15, 2011
Manual download
Here is the tefal home page for the classic 4 slice toaster. I believe it is the same taoster as you have described but let me kow if it isn't.
At the bottom of the page is a downloadable pdf manual for this toaster.
http://www.tefal.co.uk/Breakfast/Toasters/Tefal-Avanti-Classic-4-Slice/p/1500532718
Hope this helps
Jan 29, 2014 | Tefal 5332002 4Slice Toaster
My tefal avanti stopped working
something had been gone short due to the power socket.let the socket be ok but sometimes due to heavy voltage this could possibly happen.just check if somme parts is burnt ,turned black or smelling foul oudor,or when you on the machine now it passes burning fumes from some where.
Aug 11, 2008 | Tefal OT806000 Avante Elite 1600 Watts...
CAN YOU PLEASE FURNISH ME A COPY OF TYHE TEFAL OVEN MANUAL FOR MODEL 572325
You can download the manual here:
http://safemanuals.com/user-guide-instructions-owner-manual/TEFAL/AVANTI-_E
Oct 24, 2010 | Tefal OT806000 Avante Elite 1600 Watts...
How to operate it
web search -tefal avanti toaster operating instructions- 7th site down to download instructions
Oct 12, 2010 | Tefal Avante Deluxe 4 Slice Toaster
Tefal avanti hi speed 4 slice toaster one side not working, Not staying down Left side right side ok
Jun 03, 2010 | Tefal Avante Deluxe 4 Slice Toaster
Can you email the user manual for tefal toaster avanti deluxe for me to download please
Hello Val,
Nov 23, 2009 | Tefal Avante Deluxe 4 Slice Toaster
Lever to lower toast has snapped off just inside the toaster casing. It is plastic and cannot be reattached
Hello Sue, I've attempted to locate replacement parts for for Tefal Avante toaster, but there doesn't appear to be a broad source for these, which troubles me as I've got the same toaster and use it everyday.
I did locate the Tefal customer support/service contact that should be able to provide you with either a local authorized service location or provide you with the replacement parts you need to get it working again.
You can call Tefal directly at 1--800-395-8325 from 8:00 AM to 5:00 PM Monday thru Friday, EST
Here's a link to the contact page, in case you prefer to send an email instead.
http://www.tefal.com/Consumer+service/Contact+Us/Contact+international/United+States.htm
With luck, Tefal will be able to assist you in getting your toaster working like new soon.
Nov 23, 2009 | Tefal Avante Deluxe 2 Slice Toaster
Feb 11, 2008 | Kitchen Appliances - Others
Kitchen Appliances - Others Logo
64 people viewed this question
Top Tefal Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
paul
paul
Oscar Netto
Oscar Netto
Are you a Tefal Kitchen Appliances - Other Expert? Answer questions, earn points and help others
