Question about IBM Infoprint 6500 Matrix Printer
IBM InfoPrint 6500 E58 SHUTTLE JAM
E58 shuttle jam
3 Suggested Answers
  • 13 Answers
SOURCE: 058 shuttle jam
This can happen for a number of reasons.:-
a. The print mechanism needs to be adjusted ( You'll need a technician to do this if yu are not familiar.
b. Something is clogging the print mechanism, eg Old ribbon residue, or sticky labels etc.
c. The paper thickness lever is set to incorrect setting . Try adjusting it out .
Aido
Posted on Mar 06, 2008
yooperbud
  • 8637 Answers
SOURCE: Error 058 Shuttle Jam on an IBM 6400 Matrix printer
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Posted on Jan 25, 2009
Where we get IBM printer model 6400 010 print head ?
Its not really a print head, its a shuttle assy, The shuttle takes individual frets are you looking for the frets or the whole shuttle assy? What ever you are looking for i would need the shuttle part# in order to get you the correct shuttle of fret.
Feb 28, 2012 | IBM 6400 Matrix Printer
I have a SINGER 2263. I've used this machine less than ten hrs. I have a jam, I've cleaned everything. The machine will turn un-restricted in reverse but forward half a cycle. The needle will either...
With the machine unplugged, remove the bobbin case and the shuttle mechanism. Clean and oil it. Check for any fabric or threads in your feed dogs. Change needles in case that one is bent slightly. If the jam was really bad, you may have messed up the timing, unfortunately.
Mar 15, 2011 | Singer Sewing Machines
Shuttle jam appear
www.oki.com.tr/binaryData/13882/OKI_UM_250011A.pdf
in this pdf u have got the problem solve the shuttle jam problem
Apr 01, 2009 | Printronix P7010 Printer
Hardware may be
first of all do one thing and that is keep your platen marked A,B,C in b or c position then start printer if it prints then it means your shuttle gets very much tight in position A, for that please switch off the printer remove paper and loose your shuttle and adjust your shuttle according to the movement of paper. also do one thing that is clean your shuttle senser also.
Feb 19, 2009 | Printronix Line Matrix P5005B Printer
Jan 06, 2009 | IBM 6400 Matrix Printer
How to re-insert bobbin shuttle
maybe one of the parts diagrams at the Singer site would help? or us the contact there?
Oct 29, 2008 | Singer 3116 Simple
"Shuttle jam" see manual problem on Printronix line matrix P 500E printer
Verify that there is nothing clamped between the platen and the shuttle.
Last time I had this fault, it turned out to be a broken wire in the harness that connects the CMX board to the shuttle module.
Other possibilities include a failed shuttle or CMX board.
Steve W
LazerTek LLC
Jul 06, 2008 | Printronix Line Matrix P5005B Printer
058 shuttle jam
Aido
Jan 18, 2008 | IBM 6400 Matrix Printer
IBM Infoprint 6500 Matrix Printer Logo
132 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
jasbo
jasbo
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
