Question about Behringer Sx2442fx Eurodesk 24channel Mixer New
Sound gets muffled at certain frequencies. Please Help!
We are using a Eurodesk 2442FX for our church audio system. For vocal to track performances. There has been a problem with the audio being muffled when it seems to hit a certain level or frequency, it doesnt seem like a malfunction but seems as if the board is going into some type of protection mode. We are using alot of High frequency on the mic, the volume of the mic track is passed unity gain during performance. When the sound muffles i take away some trim and high and it will return to normal audio and then go back to being muffled soon after. How can i prevent this from happening??? it is becoming a problem to our singer and our audience, we are a house of worship and this interrupts us. (Equipment: 100ft Musicians gear snake, 2 Allto Professional 800 Watt Active speakers and 1 Alto monitor with same specs, speakers are being plugged into the Eurodesk 2442FX through Snake returns on stage into Main Out Left & Right, Stage Monitor through AUX Send 1.. Audio Track is being played through Track 17/18, usually leveled at Unity gain with a little more trim and high and less low Please Help, thank you!
    Top Expert:
  • Behringer Master
  • 3,130 Answers
I think that rather than the mixer, that your front speakers may have a limiter built into the high frequncey amp. You may be asking them to do more that they are capable of.
Posted on Mar 05, 2017
  • 5603 Answers
SOURCE: no sound to speakers
There are many things, including hardware failure to cause this.
Make sure that the PFL buttons are ALL up. The LED indicators on the right are shared with solo channel and main output.
REMEMBER that the MAIN 1/4 inch jacks are TRS balanced and plugging a mono cable into these OR st the other end plugging into a MONO will short out the balanced line drivers. Since this also goes to the power amp, that can ground out the signal to the amps. All the other 1/4 inch jacks are pseudo balanced and mono plugs will not cause a problem other than possible hum or noise levels.
Do you get anything out of the PHONES jack?
Note that the standby switch must be UP in the upper right corner... it kills the first 12 channels. ALso with two speakers make sure the MAIN slide switch is in the MAIN A MAIN B upper position.
Start with all your PAN controls at 12 o'clock.
I have repaired two of these units and a PMP3000. Great caution: NEVER pull or insert speaker cables while unit is on. Great damage can be done. IF the fuse blows do NOT replace it!!! Get serviced immediately as replacing the fuse will likely do more damage. The worst damaged one required replacing around a dozen transistors and other components.
The power amps in these have a habit of arcing out... NEVER store in a high humidity area!!!
Try a set of stereo headphones plugged into the L and R MAIN out 1/4 inch jack... If you have audio there your power amps have failed or the +/- 85 volt supply has smoked.
Posted on May 19, 2010
  • 6 Answers
SOURCE: I am currently having problems with our PA System.
To get to full power your speakers to be at 4 ohms, not 8. You can achieve this by either using to 4 ohm speakers OR chaining to 8 ohm speakers together, two left, two right. In Bridge mode you may need an 8 or 16 ohm speaker load but sound will be mono and only available from one side of you speaker outputs
  • 5603 Answers
SOURCE: My PMP 3000 is a dead stick. Help? We were
Please note that the outputs of the MAIN L/R line outs are TRS balanced. If you plug mono plugs into these or connect to mono device you MAY have a problem of grounding out half of the drive internally. ALSO please read my tip on here regarding a polarity hazard of speaker cables of PMP amps if you do NOT have Speakon to Speakon cables, but have Speakon to 1/4 inch cables.
Likely one of the power amps in this has failed If no lights come on the unit now, then the power supply is wiped out as well. It takes about $50 worth of parts and quite a bit of skill and work to restore the unit, including carving out burned board and re-insulating. Likely a feedback occured on that mic and started the whole thing. Supersonic feedback is something most musicians are NOT aware of, but if the feedback is above the range of hearing, the amps can be strained as they may go to maximum power trying to amplify the sound you can;;t even hear. Piezo tweeters are capable of frequencies up to 30KHz.
If this is under warranty exercise it immediately.
Posted on Oct 20, 2010
  • 5603 Answers
SOURCE: you seem to be the
The MON faders ONLY control the output to the MON L and MON R jacks, NOT the split use of MAIN/MON outputs. You MIGHT try varying the MONO fader and see if it varies the MON part of the split output.
Best to use the unit as MAIN L and R to main speakers and use a stereo amp or POWERED monitors driven from the MON L and R jacks. With this, the MON faders will control your monitors as you would like them to.
ALSO make sure ALL equipment connected together is powered from teh same recepacle power system. Powering interconnected equipment from receptacles at opposite ends of the room is asking for damage due to ground bounce and faults.
PLEASE read my tip on here about a HAZARD of speaker polarity if you use Speakon to 1/4 inch cables.
Posted on Oct 29, 2010
  • 5603 Answers
SOURCE: been looking everywhere for this... i just hooked
The JBL EON 305's are 8 ohm speakers. The PMP5000 wi;; produce 400 Watts per side into a 4 ohm load (600 Watts peak). Into your 8 ohm speakers, the peak current will be halved while the voltage remains the same so you ACTUAL power per side is 200 Watts. It is hard to know how much you expect to get out of the amp. This power would fill a venue of at least 2000 sq ft. If you need more sound, try borrowing another 8 ohm speaker for each side and parallel them with the EON's as a test. That will double the power and add 3 Db more of sound. Your main slider should be around unity typically. This amp is a class D switching type (very efficient) and runs on +/- 70 volt rails. giving about 45 volts RMS output. At 4 ohms, this is just over 10 amps giving 450 Watts... at 8 ohms this is around 5 amps or 225 Watts.
Please read my tip on Fixya about the ground hazard of channel A when using 1/4 inch cables out of the PMP units... essentially the BARREL of the connector from channel "A" is the HOT,... NOT the tip of the PLUG. Ground the barrel IN ANY WAY AND YOU FRY CHANNEL "A" AMP !!!
Posted on Jan 16, 2011
Removing vocals
I dont think you can remove the vocals on audacity because it uploads it all as one stream whereas all the audio needs to be separated from the start. Maybe try and download the song as a backing track without vocals?
Apr 06, 2013 | Music
I am trying to record from xenyx 2442fx to audacity. I am not sure how. I think it has something to do with usb, but do not know how to connect the mixer to the computer to get a good sound. Please help.
First, connect the USB audio interface which came with the Xenyx to a USB port on the PC. Then connect the TAPE OUT from the Xenyx to the IN of the USB audio interface. And connect the OUT of the USB audio interface to the TAPE IN of the Xenyx. You should now be able to record from any of the Xenyx channels. To listen back, engage the control room button which reads CD/TAPE. Contact me if you need any clarification.
Sep 06, 2011 | Behringer XENYX 2442FX Mixer
How do you connect behringer sx2442fx eurodesk sttudio mixer on acomputer in studio
WIthout a quality audio interface the answer is you don't... You need to procure an audio interface for the computer. The internal audio systems of computers are too noisy to get decent results. The manual for the mixer will show the typical studio connection with a suggested audio interface.
Aug 06, 2011 | Behringer Sx2442fx Eurodesk 24channel...
I am trying to record in multi track mode-want to know how to record for example vocals on track one then without erasing the vocals add for example harmony or guitar so i get two things on one track. At...
How multitrack recording works is assigning each recording to a different track. A way around this is to record the vocals to track one, then your harmony to track two. Save that as a single recording, or mixdown, then open that saved mixdown to track one. You may need to be connected to a computer to do this.
I use the same technique when using Cool Edit Pro (outdated, yes, but I've been using it for 4 years, and I know most of the ins and outs), especially on the guitar tracks, where for studio sound, you've gotta use 4 total tracks. Putting two tracks together frees up your processor, and uses less in the way of effects, as well.
Hope that helps!
Feb 07, 2011 | Samson Technology Zoom H4n Handy Recorder
I have a Eurodesk 150 watt power supply that will not power up. It may have been struck by lightning. I am looking for a schematic and advice. Thanks, Tommy
You MAY find the schematic is close to one of these:
http://elektrotanya.com/behringer_sps-400_sch.pdf/download.html
or
http://elektrotanya.com/behringer_sps600_power-supply_sch.pdf/download.html
If the main switchers are shorted, then likely the driver transistors are also gone.
Fpr personal SAFETY please use an isolation transformer when working on this.
Hint: Use a 60 Watt light bulb in series with the power input to act as a fuse when unit is "restored" to protect it if not quite all of the blown parts are found, during troubleshooting.
Jan 09, 2011 | Behringer XENYX 2442FX Mixer
I have a Peavey 8600 amplifier. It sounds great but when only operating vocals, in order to get the highs of your voice just right, the speakers put off a large amount of white noise. While singing, you...
There is not enough info here to provide a complete answer, but let me give you some background:
There will always be some hiss. This is due to general amplification where a small amount of noise is amplified along with the general signal. In most cases, the signal is strong enough to overpower any noise that is present (vocals in your example). This noise should not be that noticable in normal cases. If there is an automatic gain control in the line, this could account for it as with "silent" times, the gain will automatically be increased potentially to the degree where the noise is noticable.
Barring that scenerio, if the input signal is too low, the overall gain necessary to produce reasonable volume at the speakers will also be such that the noise is noticable. In order to track this down, please provide details about the current setup including:
1) Microphone make and model being used
2) Input being used on the mixer
3) Gain level being used for the mic channel
4) Gain level being used at the master level.
Dan
Jan 07, 2011 | Peavey Xr 8600 8 Channel Powered Mixer
I am having trouble getting the trim set right. i have audio tech condensor mics, one for vocal and one for guitar, i have them in inputs a and b and the phantom power on. but i cannot find a level where...
Make sure you do NOT have a monitor speaker that is active! If you have a monitor speaker, it is POSSIBLE that there is a SUPERSONIC feedback going on that you cannot hear. This would saturate the system and distort your recording. Studio mics have a lot of gain and a wide response.
Dec 09, 2009 | Fostex Mr 8hd CD 8 Track Recorder with CDr
Boss BR900CD External MIDI
I'm not totally familiar with that Boss Digital Audio Workstation but it sounds like what you want to do is record both the music and vocal track at the same time. If that's the case I believe you can push both "Line" and "Mic" input buttons (perhaps not exactly named as such) at the same time to record both simultaneously. Otherwise I would suggest copying the music to it's own stereo track (or two individual tracks, each panned opposite from one another to maintain stereo) and then record your vocal track separately. That way you can record several takes and edit down the best parts to one final track.
I hope that helps.
Dec 02, 2017 | Boss Micro BR Digital Recorder
Behringer Sx2442fx Eurodesk 24channel Mixer New Logo
100 people viewed this question
Top Behringer Music Experts
Michial Gueffroy
Ben Armstrong
Are you a Behringer Music Expert? Answer questions, earn points and help others
