Question about Maytag MBF2256H Bottom Freezer Refrigerator
Freezer works, fridge doesn't
I haven't used my fridge for about a year, and now that i connected it my the top part doesn't work only the freezer works. we changed the temp. to 30 something but then it goes to 80 something. i can not afford buying another fridge right now.
How do I drop the computer comp. out of the top of my Model# MBF2256HES fridge. I need to replce it
Posted on Jun 13, 2011
    President:
  • Maytag Master
  • 2,651 Answers
Freezer ok no refrig???? do you here a fan on in the freezer sect when you open the freezer door?? common problem to have a bad evap fan motor and the unit will not blow the air up to the refrig compartment
Posted on Oct 27, 2008
Whirlpool top freezer 18c.ft w/ icemaker: freezer works fine. fridge does not cool below 56 degrees. vacuumed dust from bottom, turned entire unit off and restarted but still not working, in back of
i think you have to check to make sure that
the fan inside the freezer is cycling on.
it will be concealed of course but you should
be able to hear it. i replaced one once with
the same symptoms and that fixed fridge
portion of a 2002 or 3 whirlpool. make sure
to listen closely and not mistake it for the
stronger fan motor which operates in
conjunction with and nearby the compressor.
Feb 05, 2013 | Whirlpool Refrigerators
We inadvertently left the freezer door slightly open the frrezer ran continuusly for twenty four hours. Would this cause the condenser to frreze up and burn out? The frrezer is still cold and we...
leaving your freezer door open does nothing ,but work the freezer harder,,,it wont cause no of the prolems you stated,,it will cause your electric bill to rise ,,your ok...the condenser is part of the seal system and it exspell the heat usally under the fridge...good luck
Sep 03, 2011 | Kenmore Top Freezer Refrigerator
The top freezer is working but lower part refrigerator compartment doesn't cool at all even adjusting temperature to Max cooling??? It is like fan doesn;t blow cold air from the freezer
There is a drain that carries water from the freezer to a drain pan in the base of the fridge. It has plugged preventing water from draining and in turn the water has froze blocking the flow of air to the fridge. First you must find the drain line in the rear of the fridge and unplug it as well as thaw the fridge out overnight to allow the water to drain... be patient as there will be a lot of ice to be thawed out, let me know if it works! good luck!
Jul 20, 2011 | Kenmore Top Freezer Refrigerator
Fridgidaire Mini Fridge not cooling
pulled off back panel on inside of freezer, to find it was a solid block of ice. thawed, and plugged back in... working properly
Feb 08, 2010 | Electrolux Refrigerators
Freezer not working on ariston fridge freezer 2 orange lights on top of fridge keep beeping every two hours causing fridge not to work is there a reset button
freezer not working on ariston... Solve freezer not working on ariston fridge freezer 2 orange lights on top of fridge keep beeping every... (More) freezer not working on ariston fridge freezer 2 orange lights on top of fridge keep beeping every two hours causing fridge not to work is there a reset button
Sep 13, 2009 | Freezers
Magic chef fridge not working
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Could also be beginning of defros problem.
Jun 04, 2009 | Magic Chef CTB1821AR Top Freezer...
SERVIS MO262S FROST FREE FRIDGE/FREEZER, FRIDGE NOT WORKING
servis frostfree fridge freezer not working after 2weeks holiday returned it had completely defrosted fridge & freezer power supply still connected. warning light on. done all the trouble shooting in the srvice manual still want go cold or freeze. light on in the fridge, no water in the rear tray & cleaned the overflow pipe??. Model No M0330-ALU 5yrs old. think it has 2 seperate thermostats, surely they wont both have gone at the same time???????
Mar 30, 2009 | Amana ATB1832AR Top Freezer Refrigerator
Fridge losing coldness
Defrost problem. Either defrost heater, defrost thermostat, or defrost timer is bad.
Sep 05, 2017 | Frigidaire GLRT184RA Top Freezer...
Maytag MBF2256H Bottom Freezer Refrigerator Logo
351 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
