Question about Reebok Exercise & Fitness
How do I change it to mph from kph on my reebok treadmill t5.1
5 Suggested Answers
SOURCE: change speedometer readin on elite 507 treadmill from mph to kph
I know this is an old thread, but if you are still trying to change between mph and km, then follow these instructions.
The setting is changed by a switch on the console circuit board. Unplug the power cable. You will need a medium philips screwdriver. The console is fixed to the frame with 4 screws, climb under the console and remove 2 screws from the top and 2 screws from the bottom. Get back up and lift the console up slightly making sure you do not dislodge any cables from either the left or right-hand side of the console. Look under the console from the left-hand side, in the middle of the circuit board you will see a small slide switch (silver casing with black slider), slide it to the other position. You will see next to the switch the letters mph and kpmh. gently reseat the console, put the 4 screws back in, the console should now display the speed in kmph when you plug it back in and turn it on.
All the best
Posted on Feb 24, 2011
SOURCE: I've just bought the Reebok Edge 2.2 Treadmill
In order to change the speed increment, you will need to unscrew the front of the console from its housing by undoing the screws at the rear of the console, the front part will then lift off. On the circuit board underneath there is a black slide switch, switch it to whichever setting you want (M or K) and it will read in that measurement.
Posted on Mar 01, 2011
SOURCE: treadmill kph to mph
No need to take console apart, power up the treadmill, take the safety key out then hold down the start button and the incline down button at the same time then insert the safety key. You'll now be able to toggle between KPH and MPH by using start button
Posted on Jun 15, 2010
  • 218 Answers
SOURCE: converting kph to mph
press and hold the stop button while placing the key on, then release and hit speed + or - I don't remember which right now. One turns the store demo on/off and the other is for mph/kph
Posted on Aug 14, 2010
How do I change from kph to mph on my Everlast jx627sw treadmill ?
under the console display there are small hole. Use the point of eraser pencil, make click, and ready. Of course another recently model you can do it by going to the MENU, and selecting kph to mph, read you owner manual if it is your option or download
www.fitness.manualsonline.com
God bless you
Jul 17, 2013 | Exercise & Fitness
How do i change a life fitness cross trainer from mph to kph
Dear Sir:You can have some pencil, and with the point of the pencil, go under the display board, in the small orifice, and with the point of the pencil press the small button, and ready. Restart the machine.
sincerely. God bless you
May 03, 2012 | Life Fitness 95xi Elliptical Crosstrainer
How do I change kilometers to miles on a reebok i run treadmill
U need to take the four screws out from rear of panel, the console can then be seperated into two pieces. Then on edge of LHS of upper board there is a swicth to toggle between MPH & KPH.
Feb 05, 2011 | Reebok New York Giants Eli Manning Jersey
I have a reebok edge series 2.2 treadmill, i bought it in argos in ireland but im pretty sure it's been shipped from england, does anyone know if the distance ran on the computer is in miles or kms?
I had this very same problem. I sorted it out this way: the information that Argos supplies says the speed starts at 0.8 kph with a top speed of 14 kph. If your Reebok Edge starts at a speed of 0.5 and has a top speed of 8.8, then the speed and distance is measured in mph, rather than kph. You can check this yourself with the following online speed converter:
http://www.eforecourt.com/mph_kph_speed_convert.htm
Feb 03, 2011 | Reebok Acd1 Treadmill Motor Control Board ...
Convert from KPH to MPH
You need to go into the calibrate routine. If it doesn't cover it in your user manual, remove the motor cover and check for a spec sheet. The spec sheet will detail the entire calibration process, including changing kph to mph.
Oct 26, 2010 | Proform 595LE Treadmill Walking Belt
Converting kph to mph
Jul 14, 2010 | Proform CrossTrainer Treadmill
Treadmill kph to mph
Mar 21, 2010 | Reebok Exercise & Fitness
Reebok i-run computer how do i change miles to km
Jan 19, 2010 | Reebok Exercise & Fitness
Exercise & Fitness Logo
228 people viewed this question
Top Reebok Exercise & Fitness Experts
Electro Med Services...
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Are you a Reebok Exercise and Fitnes Expert? Answer questions, earn points and help others
