Question about LG WM-2277HW Front Load Washer
Can't open the door
MAY BE THE LOCK IS BROOKEN
Have you tried to open it when turned off at power. Wait 5 secs after turning off door release should open. If this does not work, put on a wash cycle, start machine then turn off the cycle and switch machine off. Door should open. Failing this I would say door lock mechanism is faulty.
Posted on Feb 20, 2012
GLTF1240ASO Front Door Won't Lock/Close
Most probably your door lock is damaged. You are not supposed to force it open, you have to wait for at least 2 minutes (or till the lock sign is off) after the wash is over to open the door, never force it.
You can just google your model number and search for parts to obtain it. It is quite possible you can change it yourself. See that the line is disconnected from the mains.
Jun 04, 2013 | Washing Machines
Screen on samsung computer
try with a other monitor,it can be brooken,or the videocard is brooken.
May 18, 2013 | Computers & Internet
2000 cadillac deville driver side won't open with the key
1) Key turns but dose not unlock door. This means that the rod that goes to the back of the lock has came off. This also means that is the reason door is not unlocking with the remote as it pops the lock rod inside the door which pushes the lock open.
2) Key does not turn lock at all but works passengers side door. This means that the locks has been changed in the door, but that doesn't sound like the problem as you say the remote doesn't open the drivers side door so more than likely the rod has came off the back of the lock
Nov 07, 2012 | Cars & Trucks
Fiat doblo door open light stays on and doors won't lock
this is the door open light indicator on your instrument panel correct? it thinks the door is open. do interior courtesy lights work? i.e. turn on off when opening doors? check for "normally open" circuit faults in the door switches
Aug 27, 2012 | Fiat Doblo Cars & Trucks
96 Grand Cherokee driver's door lock
w/ the power lock s only????
Jun 17, 2012 | Cars & Trucks
Can't get drivers door open on 98 chevy blazer
if you can't get it to open from inside or out the lock broke get a new lock the open the window look down at the lock with a long screw driver break apart the lock it plastic
Apr 14, 2012 | Chevrolet Blazer Cars & Trucks
The lock on the driver side door wont unlock and the door wont open
Hey Kim!
Well, the first question is, and please don't think I am under estimating you on anything, is can you pull up at all on the lock rod? Or, does it feel jammed? Second, yes, the door has to be open to remove the panel because of the bottom pins that hold the panel to the door.
So, let's try and get the door open first.
Dec 03, 2011 | 1998 Ford Explorer
My daughter touched the rear door lock mechanism by mistake and now it's locked although the door is open. This means the rear door can't shut properly. It doesn't unlock using the remote. ...
depends on year and model but check she hasnt pused in the lock hook on the lock ? hold the handle open and with your finger release the lock close door and try locking it ????more info needed?????
Sep 07, 2011 | Volkswagen Passat Cars & Trucks
Electronic control panel stuck on Whirlpool Duet Sport Washer
it looks like the panel switch is brooken . if you take the panel off and see if the switch.it may get stuck.
Feb 16, 2008 | Washing Machines
LG WM-2277HW Front Load Washer Logo
183 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
