Question about Frigidaire FRT18G4A Top Freezer Refrigerator
Frigidaire FRT18G4A nothing running except light
Water pooling on top shelf. Freezing as well. How do I fix this?
Probably the water drain is blocked. The auto defrost generates a fair amount of water which is channeled into a tube leading through the fridge wall to a tray fixed to the motor where the heat will evaporate it.
Oct 05, 2015 | Frigidaire Refrigerators
My Westinghouse RS662V fridge is not cold at all. I have turned the dial to full cold but it has made no difference. The freezer seems to be working OK. Could it be the thermostat in the fridge?
Yes you need to adjust the thermostst located inside the fridge compartment to change the temp. setting of the fridge.
Regards.
PLZ. dont forget to rate my suggestion.
Jul 19, 2011 | Frigidaire FRT18G4A Top Freezer...
Will the freezer work after being plugged in 6 hrs after transporting it on it's side?
yes it should be fine how ever you may need to run the unti for about fifteen minutes then shut it off four half hour or so then start it back up you should not have nay problems with it./
Nov 12, 2010 | Frigidaire FRT18G4A Top Freezer...
Can a frigidaire be transported long distance laying down? Or must it be in an upright position?
You can lay a fridge down if you do it right...this tip will tell you how to do it so that it will work again when you get it moved and set it back up.
Moving a Refrigerator What is the best way
heatman101
Oct 04, 2010 | Frigidaire FRT18G4A Top Freezer...
The frig part and the freezer part are not getting cold. They get cold every two days, then gets warm for two days and then it re-peats the cycle.
Hi, check to see if both the fans are running or check and see if there is frost builing up inside the freezer. Are the condesor coils clean? These coils are located under the refrigerator near the compressor.
Please let me know if I can assist you further.
Thanks
Vic
May 16, 2009 | Frigidaire FRT18G4A Top Freezer...
Frozen food in fridge
Start with a total clean, vacuum and defrost. Unplug it before cleaning the motor compressor area. Make sure all the coils you can reach are clean. Plug it in and see what happens. If still the same - time to have a tech do pressure tests.
Mar 29, 2009 | Frigidaire FRT18G4A Top Freezer...
Fridge freezer light on nothing else after transporting.
IS THIS A AUTOMATIC DEFROST UNIT? IF SO THEN THE DEFROST CLOCK PROBABLY IS BAD, LOOK UNDERNEITH BY THE COMPRESSOR AND THERE SHOULD BE A SQUARE ISH BAX THAT HAS 4 WIRES COMING OUT OF IT. TAKE AND TURN THE RED KNOB WITH A SCREW DRIVWER UNTIL THE COMPRESSOR COMES ON. IF THAT WAS NOIT IT TAKE A HAIR DRIER AND HEAT UP THE LIDUID LINE DRIER SOME TO TRY TO CLEAR THE RESTRICTION ON THE DRIER. GOOD LUCK (SORRY ABOUT ALL CAPS BUT GOT TIRED OF CORECTING THE SPELLING) NOT SHOUTING
Jan 11, 2009 | Frigidaire FRT18G4A Top Freezer...
FREEZER NOT FREEZING REFRIGERATOR NOT COOLING
can you feel the compresor??? is it hot??? if this is hte case, your compressor is hot and hte fan the freezer section is still circulating warm air sounds as ifyou have a sealed system issue, 5yr manufactue warr.. (should be anyway check your manual)
Nov 30, 2008 | Frigidaire FRT18G4A Top Freezer...
Not cooling
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jun 03, 2008 | Frigidaire FRT18G4A Top Freezer...
Frigidaire FRT18G4A Top Freezer Refrigerator Logo
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
