Question about Kenmore Elite 21086
Kenmore elite washer won't start
Just won't start 'dead'.  there's power but no display or reaction to pushing buttons
  • laurenmanrai Nov 11, 2008
    When I push the start button, the washer is not responding.
  • Anonymous Mar 24, 2014
    power button won't work
  • 36 Answers
Dear Customer
Please perform the following
unplug the washer for 5 minutes and then plug it back in,This can resets the system
Please rate this,Thank u
Posted on Dec 17, 2008
My proscan tablet is locket and ican't unlocket it what can i do???
Since I don't know which exact Proscan Tablet you have, here is how to restore the PLT9045K.
1) Make sure the tablet is powered down.
2) Press and hold VOLUME UP(+) and DOWN(-) buttons, plus POWER button all at the same time.
3) Insert a metal pin in the RESET hole at the back of the tablet, then push and hold it for 2 seconds, while still holding the VOLUME and POWER buttons. Make sure the pin is pushed. It seems like nothing happened, but just keep on going to the next step.
4) Power ON the tablet and immediately, PRESS and RELEASE continuously the VOLUME UP(+) button in order to get the display as showing dead tablet (dead robot).
5) This is the critical part. Make sure you do the right sequence or you will start again from the beginning. Press and hold the POWER button, then press and release VOLUME UP(+), and the display will give you a screen showing different options.
6) Choose the option wipe data/factory reset, by clicking POWER button to scroll down. To execute the selected option, press VOLUME UP(+) button. The tablet will reboot back to its factory setting.
Jul 12, 2014 | Proscan 7-Inch Android Internet Tablet,...
I have locked myself out of my tablet
You will need to do a factory reset:
Oct 29, 2013 | Proscan Recertified - PLT7035 4GB NAND...
My Fisher & Paykel 708 smart drive washing machine won't starts and beeps.
That is Error code 9
9.
(00001001) Phase 1 to 5 - Size Error
Phase 4 to 5
The Display size switch setting does not match that stored in memory.
Action - Reselect the size of Smartdrive by using the SIZE SETTING MODE. Push and hold
the water temp up button, then press the power button to enter SIZE SETTING MODE. Three
LEDs are used to identify size. The cold water temperature LED identifies 5kg. The low water
level LED identifies 6kg. The hold spin speed LED identifies 7kg. If the product has not been
setup before all 3 LEDs will be on. To set the size for 5kg push the wash temp up button then
the power button. To set the size for 6kg push the water level up button then the power button.
To set the size for 7kg push the spin speed up button then the power button. This locks the size
into memory. To check the size is set, start a cycle.
Dec 20, 2012 | Fisher and Paykel Washing Machines
Kenmore Elite Model 110.42926 202 after setting the desired cycle will not start when you push the start button
see this causes and fix it. God bless you
Incoming Power Problem If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the home.
Power Cord If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.
User Control and Display Board If the washer won't start, the user control and display board may be defective. Check for power to the washer first.
Timer If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Line Fuse If the washer won't start the line fuse might have blown.
Thermal Fuse If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Line Fuse and Holder If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.
Main Control Board If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.
Door or Lid Latch Assembly If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Oct 05, 2012 | Kenmore Elite 45986 Front Load Washer
When you push start button nothing happens
Sep 28, 2012 | Washing Machines
PSU hangs the system: can't turn on; turns of in 30 min
either the power supply needs replaced or there is a short on the board...
pull the mb and guts of the system out of the chassis
connect the power supply with one cpu and one stick of memory for testing.. no add-in cards installed
then test the power capabilities..
if the system works out of the chassis.. ( alot of work to do ...understood )then there is short to the chassis of the from the motherboard
i really think the power supply is the issue though
Sep 29, 2009 | Computers & Internet
Dell Inspiron 500m can´t start
Appears to be a dead/dying power adapter.
Require 2nd opinion on this one before making a decision though.
Apr 12, 2009 | Dell Inspiron 500m Notebook
Washing Machines Logo
885 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
