No power my LCD TV monitor 900t
Pls help me... for the diagram of PSU....THANKS to anyone who can help me...
    Novelist:
    Champion:
  • 212 Answers
Well, that looks like you have what we call a dry joint on the power supply connector of your monitor. With experience , i have discovered this to be a normal problem. Get a compute technician to open up the monitor for you and then take a closer look at the circuit board where the power supply is connected. Check for any dry joints (this means that there is a component on the circuit board that is directly related to power supply, and it is not properly attached to the board (soldered). Notice all the dry joints and use a soldering gun to put them back together and try to power the monitor. Check also for bulged or leaking capacitors. Replace them with the same type
Posted on Feb 21, 2012
4 Suggested Answers
MarkDay
  • 111 Answers
SOURCE: sony SDM-M81/B 18" LCD Monitor (Black)
Sony does not sell replacement parts to the general public, only a Sony authorized repair center can get you these parts.
Posted on May 16, 2008
SOURCE: I have a proview lcd
For the above LCD Monitor, I actually saw a small spark at the top part of the main board once the power input jack was connected. It prompted me to the exact location and when I check the SMD ceramic capacitor (that generated the spark underneath it) with analog meter set to X 10 K ohm range; it actually developed a slight short circuit. Replacing only the fuse and the SMD ceramic capacitor solved the no power problem in this 19" LCD Monitor. This Monitor uses the inverter IC (OZ960G), A1084-25CM (2.5 volts voltage regulator), AMC1117-3.3 (3.3 volts voltage regulator), ADC IC (MST8136B) and CPU IC (MYSON MTV312MV64).
Posted on Oct 07, 2010
budmrtn
  • 11361 Answers
SOURCE: i have samsung lcd monitor 17" . my lcd problem
You can look through here for service manuals:
http://elektrotanya.com/?q=showresult&megnev=Samsung%20&megnev2=710N%20&kategoria=monitor&kat2=schematics
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
Posted on Jan 05, 2011
I need a diagram for TNP A5808 PSU panasonic.. can anyone help me pls...thanks...
If you wish to get some details; check the site linked here. Pull up older posts.
Circuit diagrams of SMPS section of many popular brand devices are given. Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
May 18, 2016 | Panasonic Viera TX-L32B6B 81.3 cm 32"...
Samsung LCD monitor Model 740N no display.
pls chek 1000/25cap ,and inverter fuse, and 5402 ics
Jan 11, 2013 | Samsung SyncMaster 740N 17" LCD Monitor
I have a proview lcd monitor model pl866s .What is the size of the power connector for the 19vdc @3068a psu?I have an extra psu with the correct voltage /current .Thanks Robert.
Oct 07, 2010 | Proview PL 866s (Gray, Silver) 18 in. Flat...
Need to fix the PSU
sir for this monitor you can check this link "http://www.pacificnotebooks.com.au/store.php?specs=LGM1055A&shopref=6"....
here you will get all the details...
Apr 24, 2009 | Computers & Internet
No Power, No lights ... Nothing! Is there a fuse inside?
Definitely an internal power supply issue. Dell uses a combo inverter/PSU board with P/N 790441202. This particular board uses a tablet type fuse very near the AC jack. Should a replacment be warranted rather than component level repair, pls reference this page.
This of course would require a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings. Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 14, 2008 | Dell E176FP 17" LCD Monitor
Proview 900T
hope this helped you , if you need more help just ask and i will assist you as best as possible
electech
Oct 30, 2008 | Proview PL926WBi 19" LCD Monitor
No Power or responce when turned on
This is a Common problem MOST if NOT ALL, problems like this with this type of fault it is invairably a problem with the Power Supply, in the PSU Electrolytic capacitors dry out and often cause this type of exact problem... It is a relitively simple fix, by replacing the caps with new ones... Any good shop should be able to fix for a modest fee.. OR if ya know anyone handy with a soldering iron maybe they could do it for you there are generally about 4 - 6 to replace... in the PS section, just do them all to be safe.. Generally most LCD's problems can be traced back to a bad PSU... almost 80% of the "problems" I find in my shop are indeed this.
Dec 26, 2006 | Xerox XG-71D 17" Flat Panel LCD Monitor
Computers & Internet Logo
54 people viewed this question
David Payne
David Payne
