Question about LG Dryers
Lg dryer dlg2532 dryer blower seems not to be blowing air
I would suspect the thermostats
Posted on Feb 21, 2012
MNTECH
  • 1543 Answers
SOURCE: blows cold air and produces little lint in the vent
To get a rear control LG dryer apart: Open door and remove two phillips head screws at the 5 and 7 o'clock positions. Use a putty knife to release the clips holding the top panel to the dryer front by pushing the clips in at the seam of the dryer top and front, a couple inches in from each side. Swing top back. Remove two phillips head screws at the top, allowing front panel to pull forward. Unplug drum light and door switch and drum sensor plugs, allowing front panel to be completely removed and set aside. Now, look at the burner area at the lower right. Behind the gas valve you will find a small (about dime sized) high limit thermostat on the left side of the burner cone. It has two wires attached and has a small pin in the center of it. (Only on gas models) Push the pin in.
Now, if that get's you ignition again, CORRECT VENTING ! Get rid of flexible vent material. (use only rigid aluminum vent pipe and elbows) Clean out vent pipes and outside vent hood. Outside vent hood should be the kind with a four inch flap for the opening, not a two inch flap. Tripping of the high limit thermo is almost always caused by inadequate air flow.
Posted on Dec 28, 2008
yecalam13
  • 41 Answers
SOURCE: Our dryer does not blow hot air? The cloths do not
more than likely the heating element has gone out. if your clothes have no heat then the element is the most likely cause. you can get one for anywhere between $30 - $50. you'll need to know model and serial #'s. usually easy to replace.
Posted on Jul 30, 2009
SOURCE: Dryer heats sometime but clothes do not dry
when you turn the switch dryer makes humming noise like its going to start but doesn't
Posted on Sep 09, 2009
  • 1382 Answers
SOURCE: LG DLG2532 dryer not heating up
Hi, Make sure you check these to fix the problem.
  • Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
  • Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
  • A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Posted on Apr 16, 2010
  • 4 Answers
SOURCE: The dryer is not blowing air. I checked the vent,
If you are not getting heat it could be several things like a bad limit switch or element burned out, the only way to know for sure is with a test meter to track the flow of electricity. If you are not comfortable with electric wiring it is best to call a repairman if you are comfortable useing a volt meter and a ohm meter I can walk you through the steps.
Posted on Apr 17, 2010
Vents are clear, getting hot, but clothes will NOT DRY! Tried to reset to no avail. No idea what's up...any ideas?
ok,, you said the vents are clear, did you check the outsite to make sure it was blowing out good,, take the vent off and start it check at the back of the unit to make sure it is blowing good and hard, if its not you have a blower issue,, if it is try running it with the vent off and see if it helps, if it does the it is in the vent, if it doesnt help, you have a issue inside the unit and i would get someone to look at it, just becouse it is a gas unit, dont risk any gas leaks if you are not sure
Jan 19, 2011 | LG DLG2532 Gas Dryer
The dryer doesn't heat up on the heat dry cycles. It still works on an air dry cycle. What could the problem be?
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 14, 2010 | LG DLG2532 Gas Dryer
My LG dlg2532 takes forever to dry clothes. When the drying cycle ends, the clothes are still quite damp. It's a gas dryer and the dryer seems to be getting gas since it does eventually dry the clothes...
How long are the vents? do they go for miles in your house?(sarcasm) Does the dryer have good ventilation? Check the vents again and make sure it is clear.
May 27, 2010 | LG DLG2532 Gas Dryer
Why doesn't my LG Dryer not dry clothes well?
Sometimes blower wheels will get loose in dryers. Sometimes they will get a whole lump of lint in them or you can hear a rattling noise in the dryer, this is the blower wheel, its worn out and it can cause the fuse to blow too,or it can half *** work and take fifty forever's to dry the clothes.Or it could be just that the dryer needs a good blowing out .I use a lawn blower to get all the lint out of the dryer as well as the vent pipe and vent to outside. I take the filter HOUSING out and wash it also. That is, I remove the housing and clean is good! Making sure that the dryer is properly flowing air is a good thing!
Nov 26, 2009 | LG DLE2514 Electric Dryer
LG stackable dryer made a snapping noise and now appears not to be blowing air. The dryer is heating but I checked the dryer vent and there is no air coming out.
hi welcome to fixya what has happend is blower fan has snaped this is an easy fix go to applince shop take your model number ask them for blower fan take off back of dryer open fan shrode remove old blower make sure you get all pices replace blower close all back up thank you for useing fixya please take the time to rate me
Feb 21, 2009 | LG DLE5977 Electric Dryer
LG DLG2532 Gas Dryer will only dry on manual setting
If you use dryer sheets, LG recommends no.  Dryer sheets cause a film that will not allow the sensors to feel the clothes moisture during the drying process thereby causing the computer to countdown the timer quickly.  To clean out the sensors, use a green pad and scrub the sensor bars inside the dryer drum.  That should remove the film left by the dryer sheets.
Mar 12, 2008 | LG DLG2532 Gas Dryer
Dryers Logo
43 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
