Question about Food Mixers
How to pull apart novelli mixer tap - Food Mixers
How do you take a 5k5m150 apart
Tap drip ring off, punch out pin through planetary. Remove back cover, unclip black wire and white wire from rear control board. Tip it upside down, remove pedestal. Undo 5 screws around where planetary came from, undo the remaining 4 screws on underside of gear case, pull the cases apart.
Mar 01, 2014 | KitchenAid K5SS Heavy Duty Commercial...
How do i get tap apart
Please clarify. What mixer what problem?
Sep 18, 2012 | Food Mixers
The mixer won't release the beater
If lightly tapping the beater to get it to compress the spring does not work then you can drive the pin out that holds the beater on.
Once the pin is out you should be able to wiggle the beater and pull it straight off the shaft without having to push it up and rotate it first. If necessary just tap it lightly and it should slide off. Then you can replace the pin and lubricate the shaft with some olive oil or other cooking oil
Bob
Apr 21, 2010 | KitchenAid K5SS Heavy Duty Commercial...
Trying to fix my KA mixer, and cannot get the planetary housing o
A screwdriver is for turning screws. What you need is a drift pin slightly smaller than the diameter if the pin you are trying to remove. If you can back the shaft up with something heavy like a hammer head and then try to drive the pin out you will be successful. They are pressed in with a light press fit and should yield to the above technique.
Mar 07, 2010 | KitchenAid K45SS Classic Stand Mixer
The lever on my bathroom mixer tap is getting stiff to lift and may jam up entirely can I fix this?
Easier to buy a new one and replace it. You can pull it apart after shutting the water off by removing the plastic cap (has a small screwdriver groove) beneath it is a phillips head screw, remove it and pull up, remove the retaining nut and pull the assembly apart. You can then take steel wool and polish it and put it back togethere but it will soon do it again.
Feb 28, 2010 | Food Mixers
Took apart, pull magnets from sides, now the thing
ECARRERO2004 - Those 'magnets' you removed from the sides of your mixer are the electric motor brushes that provide power to the commutator/armature assembly so your motor runs. Did you remove the brushes to replace them or were you just inspecting them? I'd suggest removing them again and making sure the contacts are facing in the right direction to contact the commutaor. The concave contact face should be resting completely on the comutator. If you've turned it 90 degrees too much, it wont' seat properly and you'll get no 'juice' to the electric motor so it won't start. I hope this helps - Howard, Burke, VA
If this solution has helped you, please rate it. hslincoln
Nov 24, 2009 | KitchenAid KSM5PS Heavy Duty Stand Mixer
How to adjust the slicer attachmenton the mixer attachment
take the attc. apart on the back btm of thecutter assy. there is a hand nut loosen shaft should slide either up or down depending on the thickness you want then tighten nut
Nov 03, 2009 | Hobart A200 Stand Mixer
How to fit POLO PULLOUT SPRAY KITCHEN SINK MIXER TAP 0119 **NDD**
hi i need to fix a pull out sink mixer...but i have no idea how to fix.pls help.thanks
Oct 05, 2009 | Food Mixers
How do I get access to the switch on a KitchenAid Classic mixer? I've removed all the needed screws,I think, and nothing comes apart except the silver band and the back plate....
the chrome ring around the rotating head needs tapped off to and drive the pin out of the center shaft of the head. Pry it off to access 5 ring gear screws under the head. The also hold the two halfs of the case together along with the 4 obvious ones.
Dec 12, 2008 | KitchenAid K45SS Classic Stand Mixer
Mixer attachment
make sure attachment is turned full counter clockwise to release point give a good tug if doesnt work try a light tapping with a rubber hammer or lobster wooden hammer
Nov 20, 2007 | KitchenAid KSM150PS Artisan Series Stand...
Food Mixers Logo
257 people viewed this question
Top Food Mixers Experts
eyecam
Are you a Food Mixer Expert? Answer questions, earn points and help others
