Question about HP Photosmart 2710 All-In-One InkJet Printer
Line in scanned document
How do I get rid of a line in my scanned diocument. I is not there when I copy
EPIJAB
  • 89 Answers
SOURCE: black lines
Not sure what you have tried but if there are no lines when printing but there when scanning there is something on the scanner. Could be something as small a single dot of dirt and it will put a line down the whole page. Try cleaning the glass.
Posted on Dec 14, 2007
  • 9 Answers
SOURCE: Black lines when scan and copy documents
It is because coping is not the best way to get a perfect copy on the printer, Try scanning with computer using black and white photo it will come out much better if you are doing a pic. then use color picture.
Posted on Feb 17, 2008
SOURCE: Black line vertically on scanned/printed documents
This problem can be caused by a number of different issues. If it occurs when you copy, check the scanning glass to see if there is any dust/gunk on the scanner glass. Also if you machine has a document feeder than you need to check the **** glass that the paper feeds past.
If it occurs when you print than you probably need to clean your printer. Check your manual for exact details on how to clean your printer but in general it could be on a paper feed roller or it maybe something on the drum. If you let me know what printer this is happening on I can direct you to a manual if needed.
Henry
Posted on Apr 22, 2008
checkitright
  • 1362 Answers
SOURCE: Black line on document when I scan from platen or ADF or scan to save as PDF.
As a tech I've never seen that happen. from the doc feeder only Yes, not both the feeder and the glass but not show up when you print from the computer ?????????
For sure there is a dot or something on the small strip of glass, only when you do it from the feeder.
the reason is that the document is moving and the dot on the "small" strip of glass now looks like a line to the copier.
You said it also does it when you lay it down on the glass !!??(platen) that should of indicated the drum has a ring around it, but since it doesn't come out on the PC copy then the glass must have a line on it.
Posted on Oct 07, 2008
antiochpc
  • 1314 Answers
SOURCE: vertical black line in scan document not in copies through document feeder
Lift the lid and to the left of the main glass is a smaller glass; that is what scans during the feeding process. Make sure that it is completely clean; even a speck of dust can cause a line to appear. I took a lens wipe and cleaned mine and my line was gone.
Posted on Jun 01, 2009
How do I fix this
Vertical Bands, Lines, or Streaks in Copies, Faxes, or Scans
support.hp.com/us-en/document/c02881567
Figure : Sample output with vertical colored bands or lines ... Remove any paper from the automatic document feeder (ADF) tray. ... To protect the scanner, do not spray the glass cleaner directly on the glass. .... determine if your printer is still under warranty, and then Contact HP Support to schedule a repair or replacement.
How to get rid of lines on a copied page - YouTube
? 2:10
https://www.youtube.com/watch?v=xTJpCg5sHl0
Feb 17, 2010 - Uploaded by Wayne Springer
When you make copies on your copy machine, does it ever leave a black vertical line ... QLS ' How to Eliminate Vertical Linesfrom Scans, Copies & Faxes ... Part 2- Fix or repair color laser printer with fading, light print, or lines ...
Dec 29, 2015 | Office Equipment & Supplies
How do I get rid of the lines when I make copies. It dose not happen if I print a scan
If you are using the ADF ( automatic document feed ) for your copies, raise the scanner cover and clean the strip window to the left of the main platen. If you are using the platen for copies and getting lines where scans are clean - you have a physical issue and it should be checked out by a technician.
Apr 22, 2015 | Canon Pixma Mx882 Mx 882 Photo All-in-one...
Everytime I fax something on my HP Officejet 5610 all in one, the recipient receives the document with a line going down the left side of the page. How do I get rid of the line?
Lines on scanned and copied documents is usually caused by something on the scanner glass such as ink, correction fluid or trash. Open the top of the printer and clean the scanner glass surfaces with windex and paper towels. See this article for more details:
http://www.ccl-la.com/blog/index.php/lines-on-scanned-or-copies-pages/
Jun 26, 2012 | HP LaserJet 3050 All-In-One Printer
Problem with copy/scan from Feeder
clean that small glass on printer if problem still continue open all machine and try blow it blower machine!
Apr 25, 2012 | HP Officejet 4500 Wireless All-in-One...
I have a lexmark x364dn. It has a line through the copies I make. I can print and scan and it is fine. The line is just on copies
Assuming the COPY uses a automatic document feeder. The doc feeder scans doc by passing doc over a narrow window. If there is a dot or several dots in the narrow window, it / they will show up on copies as a line.
Clean the window (looks like a long glass window about 1 inch wide ) carefully with a SLIGHTLY damp towel. Should get rid of the lines.
Nov 11, 2010 | Lexmark X364dn All-In-One Laser Printer
I get vertical lines on scans and copies when
Check out this page on our web site at:
http://www.ccl-la.com/dirty_scanner.htm This page shows you what to do to get rid of the lines on scans and copies.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Jan 12, 2010 | Brother MFC-9440CN Laser Printer
When the Automatic Document Feeder (ADF) to copy I
There are two scan modes when copies are made.When you make copies through ADF you originals go past small **** glass located to the left of the main exposure glass.Any small mark on this **** glass( correction fluid mark,ink mark,small scratch,dust particle and so on)will show as a line on your copy.So to get rid of these vertical lines on your copies you need to clean this small exposure glass.
Oct 04, 2009 | Epson Stylus CX9400Fax InkJet Photo...
Black line while scanning and copying
Open up the document feeder and clean the scanner glass
Jan 25, 2009 | Brother Multi-Function Center MFC-240C...
Black lines
Dec 13, 2007 | Office Equipment & Supplies
HP Photosmart 2710 All-In-One InkJet Printer Logo
282 people viewed this question
Seeker5211
Seeker5211
