Question about JVC Car Audio & Video
JVC headunit oranges with white stripe (illumination wire).
I am installing a JVC headunit in my car and i brought a control harness so that i can still have use of my steering wheel controls but on the secondary harness coming from the JVC headunit it has three cables which are not connected two i understand why the are not connected but the orange with white stripe wire which states in the wiring diagram as illumination i have no idea if i need or not. Could someone please tell me what this wire does and if needed where it needs to be connected to? Thanks Daniel.
    President:
  • JVC Expert
  • 300 Answers
As far as I know, If the illumination wire is connected, the radio dims the display when headlight is turned on.
Posted on Mar 10, 2012
I need a wiring diagram for the steering wheel radio controls for a 2013 Ford F150 XLT with SYNC
contact your local Auto parts store.. They should have the diagram and should be able to print it up or E-mail it..
Dec 30, 2014 | Ford Cars & Trucks
How do i program my stereo to work with my steering controls.. after installation i could no longer use steering remotes on a chrysler 200 2012 model
Im fairly sure that no aftermarket headunit will work with oem steering wheel controls, only the original oem unit will. Same also applies to oem bluetooth accessories in your vehicle.
Nov 06, 2014 | Pyle PLD70BT Car DVD Player
What wire runs steering wheel controls on a 2500 gmc sierra
This is not a question for JVC but more for GMC. On the JVC radio side, if it can be controlled via steering wheel, you will see a blue with yellow stripe cable that states [STEERING WHEEL]. Not all radios can adapt to steering wheels controls.
Aug 02, 2014 | JVC AM FM CD DET FACE CAR STEREO
Radio pro 4 wiring
You should purchase a radio harness for your car, and it's wires will connect to wires of the same color from your JVC radio harness. Join the two harnesses together (solder, crimp caps, barrel connectors, etc.) and then one end plugs into your JVC, the other end plugs into the factory harness that the original radio was connected to. If for some reason, your factory harness plug has been cut, you'll have to hardwire the JVC harness. I've included a link to the wiring diagram for your car. The steering wheel controls are moot; they will not work unless you've got some aftermarket adapter that allows them to interface with the JVC radio.
2004 pontiac grand prix speaker wiring diagram Google Search
Nov 13, 2017 | Car Audio & Video
Steering wheel controls
JVC radio doesn't work directly with car's steering wheel control. You need an adapter. Metraonlie.com offers pretty reliable ones.
Aug 25, 2013 | JVC KD-G230 CD Player
I brought a wiring harness to install a cd player into a 93 nissian pickup. I match all wires but had one left a orange one where does this attach to.
orange may be for power antenna or dimmer, or steering wheel volume controls, try it without orange it probably functions properly.
Aug 22, 2011 | Car Audio & Video
Ok i need to know how to assemble the steering wheel
Steering Wheel Removal & Installation Special Service Tools (SST) Required:
  • J1859-A Steering Wheel Puller
  • J42578 Steering Wheel Puller Legs
To Remove:
  1. Before servicing the vehicle, refer to the precautions in the beginning of this section.
  2. Place the ignition into the OFF position.
  3. Perform the SIR System Disabling procedure.
  4. Remove the inflator module
  5. Scribe an alignment mark onto the steering wheel hub in line with the mark on the steering shaft.
  6. Loosen the steering wheel nut.
  7. Position the steering wheel nut flush with the end of the steering column shaft.
  8. Loosen the steering wheel using the J1859-A SST.
  9. Remove or disconnect the following:
    • The steering wheel controls electrical connector (if equipped)
    • The horn switch lead from the steering hub
    • The steering wheel nut
    • The steering wheel from the steering shaft
    • The steering wheel controls and the steering wheel controls harness from the steering wheel (if equipped)
To Install:
  1. Install or connect the following:
    • The steering wheel controls and the steering wheel controls harness to the steering wheel (if equipped)
    • The SIR connector properly routed through the steering wheel
    • The mark on the steering wheel with the mark on the steering shaft
    • The steering wheel CAUTION
      The fastener is prevailing torque type and may only be reused if the fastener and its counterpart are clean and free from rust and the fastener develops 27 inch lbs. (3 Nm) of torque or drag against its counterpart prior to the fastener seating. If the fastener does not meet these criteria it must be replaced.
      1. Torque to: 33 ft. lbs. (45 Nm)
    • The horn switch lead to the steering hub
    • The inflator module
    • Enable the SIR system.
  2. Ensure that the steering Wheel controls operate properly (if equipped).
  3. Ensure proper horn operation.
Jul 03, 2010 | 1997 Chevrolet Venture
My jvc dosnt work in my astra
you need a pc99-x06 and then a patch lead which is stereo specific, so if you buy a JVC it will be pc99-jvc, alpine will be pc99-alp etc etc for your steering wheel controls (these are made by a company called autoleads who do loads of different stuff for car audio)
the stereo you purchase will have to be steering wheel control compatible, which should be stated in the description/instructions
you can have a sub amp etc with steering wheel controls, as thats run from the stereo and main wiring loom, and isn't affected by your steering wheel controls
Jul 26, 2009 | JVC KW-XG700 CD Player
Jvc car audio KD-PDR51installation problem
Your switched ignition lead is hooked to a constant voltage wire.
You need to find a source wire that is only given power with the key in the on position.
One wire (yellow) on radio goes to a power wire with +12V constant power (regardless of key position)
The other wire (RED) on radio will need to be attached to a Power wire whose supply is only +12V when the ignition is enabled.
Since you are using a wire harness, you just need to reverse the 2 wires as they currently are installed.
Hope this solves one problem anyway.
the wires being reversed on the harness also may not activate an internal relay allowing the steering wheel functions to operate.Switch the 2 power wires, and re-try.
If the steering wheel controls still fail to operate properly, your module may be defective.
Post your results.
Jan 15, 2009 | Car Audio & Video
Car Audio & Video Logo
536 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
