Question about ASUS Computers & Internet
My Asus notebook did not bring a restore jump drive or disk
Asus eee pc 4g error message grub rescue
This would imply a Linux distro.. What are you attempting to do, exactly? The error occurs when you install Linux and then it is removed;(sometimes incompletely other time when you remove the partition from the Windows Disk Manager). If you want to retain Linux, just put the disk/flash drive for it back in and finish the installation or boot to the recovery. If you only want a Windows system, follow the steps:
  1. You'll need a disc for the version of Windows on your hard disk drive. Place it in and select for whatever will bring you to your advanced options. (This is so you can get to your recovery command prompt).
  2. Instead of Restoring from Disk Image or whatever other standard choices you have, you'll want the command prompt.
  3. Using the following commands will restore the Windows Partition, if it's on there still.
    1. bootrec.exe /fixboot
    2. bootrec.exe /fixmbr
    3. bootrec.exe /ScanOS
    4. bootrec.exe /RebuildBcd
  4. Once you reboot afterwards, it should restore your Windows system if it didn't get removed during the Linux installation.
Hopefully this helps, if not; I'll need more information as to how it happened.
Apr 18, 2014 | ASUS Computers & Internet
OS Hard drive missing
Using Recovery Partition
The Recovery Partition quickly restores your Notebook PC's software to its original working state. Before using the Recovery Partition, copy your data files (such as Outlook PST files) to USB storage devices or to a network drive and make note of any customized configuration settings (such as network settings).
About the Recovery Partition
The Recovery Partition is a reserved space on your hard disk drive used to restore the operating system, drivers, and utilities installed on your Notebook PC at the factory.
Sep 12, 2013 | ASUS Computers & Internet
This computer is old. Can I help it run better?
If you bring it back to factory settings yes it will run faster. The only way to do that is to use the disk the computer came with to bring it back to factory settings
Feb 05, 2013 | ASUS X83VPA1 C2D253 141 4GB 500GB DVDR 6C...
It comes up no bootable device
use the restore disk or windows installation disk to reinstall windows to the computer.
Feb 28, 2011 | Acer Aspire 5050-3242 Notebook
I need to restart the netbook to go back to factory settings
You will need the following items:
1. External USB DvD Drive; Can be purchased from local retailer
2. Your Asus Eee PC Restore Disk; This should have come with your netbook. You can order an additional disk by calling Asus, 888- 678-3688.
3. Once you have the above items be sure all your photos, music, documents, data etc. are backed up to a flash drive or dvd. A factory restore of an Asus netbook will ERASE all personal data on the hard drive. You must back up the data on another device in order to preserve it!
4. Connect the external DvD drive to your netbook and insert the Asus Eee PC Restore Disk.
5. Restart the netbook and boot from CD (usually the default key to boot from CD is F12).
6. Follow the onscreen instructions that are on the restore disk.
7. After installation of all software, update windows and reinstall all your necessary software.
8. Enjoy!
Jan 24, 2011 | ASUS Eee PC 1000H Laptop
How can i bring asus G71G back to factory after i wiped the disk
Hello and thank you for using Fixya!
You will need to order the restore disks from the manufacturer. They usualy charge around $30.00 (US) plus shipping.
These are always great to have "just in case" you need them in the future. You can call the Asus support or visit them on the web.
Jennifer
Dec 21, 2009 | ASUS G71G-Q2 Notebook
How to reformat asus eee pc
Normally laptops come with a restore disk(s). Simply put the disk in the drive, restart the pc and boot the pc to the disk.
If it won't say (boot to disk) automatically, simply press F2 when you turn on the computer till the BIOS loads up. Then change the boot order to CD drive first.
Once it boots to the cd the process will run automatically.
If this solution has helped you, please take the time to rate me.
Oct 04, 2009 | ASUS Eee 4G Notebook
How to reformat ASUS Eee PC 900 notebook?
I have the linux version, not sure if you have the windows version or if it really matters. If you are looking to "reformat", you can go with the other suggestions with the USB stick. However, if you are reformatting to get back to the default settings, power on the computer and immediately hold F9. This will bring you to a screen that gives you the option to "restore factory defaults". You will lose all your previous settings, but if you were reformatting anyway, that's probably not a big concern.
Jan 13, 2009 | ASUS Eee PC 900 Notebook
Laptop
try to bring iut up in safe mode by pressing f 8 key immediatly after pressing power button should bring you to admin screen where you can remove your password or you can reformat it with the restore software / disk / partition that came with it
Oct 24, 2008 | ASUS Eee 4G Notebook
Computers & Internet Logo
20 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
