Question about Magic Entertech ED-9000 Mic Sing Along with 200 Songs Microphone
No voice, music and video are ok - Magic Entertech ED-9000 Mic Sing Along with 200 Songs Microphone
Music is too loud voices are too quiet
do you have a center channel speaker hooked up? Most voices during movies should come from the center channel
Sep 01, 2014 | Sony STR-DE445 Receiver
When watching videos, can't hear voices when I use headphones. (EEE PC 1005HA)
Have you tried using other headphones? Also try using another video player such as VNC.
Mar 11, 2013 | ASUS Eee PC 1005HA-PU1X-BK Netbook
Distorted sound on pc women sound like men voices
Maybe your speakers are bad. How does it sound when you play a music cd or when you watch a music video on Youtube.com?
Mar 28, 2012 | Computers & Internet
Music too loud voices soft on laptop
1/2 the movies made are like that,
if one movie is ok, and other not , it's the sound mixing
man that made movie. (many are bad)
like when they play loud music over dialog in a drama.
silly but they do,that, . (unlike better movies)
the only cure (hope) is using dolby 5.1 on up
and hope the sound channels can allow you to hear what you want. some content allow the front speakers to be increase for better voice.
Oct 12, 2017 | HP F-450 Computers & Internet
I have a Onkyo TX-8222 receiver. Sound is ok for music but voices are very low. When two voices, one is very clear abd the other very low. What is the problem ?
You don't say what source(s) are affected. I'm guessing TV or Cable-TV is the problem because music with vocals has voices and you say it sounds ok. Your speakers have no clue whether a sound is a voice or music so that lets THEM out and your receiver doesn't know or care either.
In the modern multichannel world it's usually assumed your electronics are multichannel. This receiver is old-school stereo.
The Center channel is usually where voices are found but some systems (like yours) don't have a Center speaker so they have to be configured to share the Center duty with the front left and Right speakers.This isn't possible or even normally necessary in your case. WYSIWYG
http://www.retrevo.com/support/Onkyo-TX-8222-Receivers-manual/id/469ci869/t/2/
The audio coming in from 'wherever' should be correctly mixed to 2-channels at the source or you'll probably be missing something. I'd look higher up the audio food chain for where the voices are being attentuated. If a cable box is involved I'd look at its audio settings regarding stereo mix-down
Wait, I just had an inspiring thought. Centered voices being mono in nature would partially cancel out if your two speakers were out of 'phase' with each other. Bass would also suffer. Make sure your two speakers are wired identically regarding the red and black (or plus and minus) conductors. If turning the Balance control fully to one side makes bass of voices sound louder you probably have a phase mismatch. Reverse the wiring on either speaker to match the other. There is no absolute right or wrong for phasing as long as they're all the same.
Dec 31, 2010 | Onkyo GX-D90 Main / Stereo Speaker
The voice sound on my computer is distorded, all voices are in high pitch, music is ok, tried everything but no result.
microphone issue? can you try another microphone and also update the sound card driver?
Dec 04, 2010 | Computers & Internet
How to put music on a lg scoop
hi,
Start by formatting the MicroSD card
1. Insert a microSD card into the phone.
2. Press OK to enter the Main Menu.
3. Within Settings/Tools select Memory then press OK.
4. Press 3 to select Card Memory.
5. Press the Right Soft Key under Format.
6. Press the OK key for Yes.
To Transfer Music
7. Connect the USB cable between the phone and your PC.
8. Press OK to select Transfer Music.
9. Press OK again to confirm disabling voice calls.
10. On the computer, drag and drop music files into the drive.
Apr 09, 2009 | Microsoft Office Professional 2007 Full...
No Manual (instructions) for Jazz hdv178
Press RECORD/PLAY Button to switch from Record Mode to Playback Mode.
The Playback Mode is for viewing and managing movies and pictures as well as listening to voice and
music on the built-in memory or on an optional memory card.
Operation Display Screen
Press RECORD/PLAY Button ( ) to switch
from Record Mode to Playback Mode Main Menu.
• There are 4 options in the Playback Mode, movie,
picture, music and voice.
• Direction Buttons can be used to select the
specific option.
• Press OK Button to view movies/pictures, listen to
voice or music.
Feb 18, 2009 | Jazz DV-179 Digital Camera
Can't delete voice recordings
Hard to tell without a model number, but in general:
  1. Connect your player to the computer.
  2. Launch Windows Explorer.
  3. Select and delete the unwanted music, pictures or video files under Philips. For voice recordings, select and delete the unwanted recording files in the Voice folder.
-Tha Mp3 Doctor
May 28, 2008 | Audio Players & Recorders
Acer aspire 5570 z series laptop computer
Normal 0 Go to Control Panel and Click on Sounds, Click on Audio, then Click on the Microphone. Then Click on the drop down and unselect Camera Microphone.
Click OK and it should be shut off.
Hope this helps. Bud
Dec 14, 2007 | Archos JBM Camera 100 - Hi-Speed Webcam
Top Magic Audio Players & Recorders Experts
conquer111
Level 1 Expert
T-Comtech Repairs
T-Comtech Repairs
Lyle Siemens
Lyle Siemens
Are you a Magic Audio Player and Recorder Expert? Answer questions, earn points and help others
