Question about Canon MultiPASS MP390 All-In-One InkJet Printer
Paper won't feed in
The paper feed seems to have stopped working. When I load paper in the back, the rollers don't seem to turn correctly so the paper won't feed into the machine and I can't print anything. Anyone know if this can be fixed? thanks!
  • 2 more comments
  • coolmomjen2 Oct 28, 2008
    It sounds like the paper should be feeding in but it's not.
  • Anonymous Nov 21, 2008
    I have the same problem. I turned my machine upside down and a staple fell out...I cleaned the rollers and the paper still wont feed
  • mauiphil Dec 12, 2008
    Paper won't feed in
    nothing appears stuck in the paper feed
    I do know the rollers are dusty but of course can not fit hand into space
    I've never used this software before. . .sounds like a good idea when many of us have the same problem
  • Anonymous Mar 23, 2014
    paper feeds and then stops. I can hear the rollers going around but it just stop feeding while the rollers continue to spin
  • 34 Answers
Look down into where the paper goes into printer in the back, usually there is something stuck inside autosheet feeder.
Posted on Nov 11, 2008
My canon pixma mx320 won't feed paper properly it seems to grab one side of paper and feeds it crooked then stops
When the paper does not feed straight, dirty or stickyrollers can cause it to jamb or crinkle, also failure to remove all traces ofpaper from a previous paper jamb will cause further paper jambs.
Check for tiny pieces of at the edges of the rollers, and remove these piecesof paper. The rollers may be dirty or sticky and causes the paper tonot feed straight.
Try cleaning the rollers with methylated spirits.
Jul 26, 2011 | Canon PIXMA MX320 Color USB InkJet Printer
I've had my brother mfc-7440n for over 2 years and it's been working great until this past week. Now, it has a paper jam every single time I try to print anything, causing me to have to remove the...
85% of paper jams are caused by worn rollers . The rubber treads in the rollers wears down, making them smooth, so they won't pick up the paper. Sometimes, they are aged, which also gives them a smoother rounded texture, causing jams. The quick fix is to liven up that roller with a mixture of alcohol and soap. Damp a rag with the solution and wipe the rollers clean with it. That's make them more pliable and the paper jams will cease. If you plan to keep your printer,
Replace the pick-up and feed rollers.
Metal Tab Separation- Pull out your paper tray and examine either end where the paper sits in. If any of the corners are held down by metal tabs, this is your paper feed system. Chances are, you only have one rubber roller or one set of rollers arranged along side of each other. Reach in where the tray goes and feel up. You should feel some rollers. They might be completely round, or they might be shaped like a half moon. Clean whichever part of them you can with the solution, and this should stop your paper jams. It might be necessary to turn them, but don't force them if they don't move freely.
Pickup Roller and Separation Pad-
If your printer uses this paper feed system, you should see a small piece of flat or slightly curved rubber or cork. It would be towards the end of the paper tray, or deep inside the paper loading cavity on top loaders. This 'separation pad' rubs against the paper feed roller, so if you find the pad, you've found the roller. Clean it and your jams should stop.
Three Roller Paper Separation System- Pull your paper tray out, and look for a roller on either end of it. If you find one, clean it. Then look inside the printer where that roller would rest with the paper tray inserted. You'll find another paper roller there. Clean this one also. Finally, look further back or closer to the front of your printer (depending on which way your paper feeds) to find another roller or set of rollers. Clean all of these, and your paper jams will go away
Jul 10, 2011 | Brother MFC-7440N Laser Printer
My Dell 1110 laser jet printer begins to pick up a sheet of paper, but then stops just as the paper turns up with the roller. This will happen several times before the printer actually picks up the...
Three Roller Paper Separation System- Pull your paper tray out, and look for a roller on either end of it. If you find one, clean it. Then look inside the printer where that roller would rest with the paper tray inserted. You'll find another paper roller there. Clean this one also. Finally, look further back or closer to the front of your printer (depending on which way your paper feeds) to find another roller or set of rollers. Clean all of these, and your paper jams will go away.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Jun 20, 2011 | Dell 1110 Laser Printer
My CLX 3175FN printer continues to have a paper jam. Right now I cannot print any paper size without it jamming. What can I do to correct this problem?
Paper jams
85% of paper jams are caused by worn rollers. The rubber treads in the rollers wears down, making them smooth, so they won't pick up the paper. Sometimes, they are aged, which also gives them a smoother rounded texture, causing jams. The quick fix is to liven up that roller with a mixture of alcohol and soap. Damp a rag with the solution and wipe the rollers clean with it. That's make them more pliable and the paper jams will cease. If you plan to keep your printer,
Also:
Start a print from tray 1/manual feed and just as the trailing edge of paper is entering the machine; quickly open it to stop print and take out the cartridge and look at the drum and the paper underneath. If the issue is there at that point then it would point to the cartridge. If not then it is in the fuser area.
Thanks, Joe
Apr 21, 2011 | Samsung CLX-3175FN Printer
HP Photosmart C6280 Will not feed paper correctly
Please onsult this HP support article and follow the steps outlined there to clean the rollers, etc. Frequently this roller cleaning and possibly a reset is all that's required to clear the jam error. (If you have access to compressed air, you can gently blow air throught the printer to clear out paper dust and debris from inside.
Also be sure to follow the instructions in the manual or here to load the paper correctly, fan sheets before loading, and if the problem continues, try flipping the stack of loaded paper upside down and reloading, or try another kind of paper..
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jul 03, 2009 | HP Photosmart C6280 Printer
5300 won't load 8 1/2x 11 photo-weight paper.
''grabber'' roller out of work sometimes, you may try
1) there is a input paper sensor around roller, the roller out of runing if the sensor is not senitive enough or sensor switch dirty,
clean the sensor as you can find it,
2) Lighter-weight paper feeds and prints fine, which means this paper input sensor works ok, but you need to make sure they are same paper input sensor,.
3) the paper surface bright and the roller worn could be cause paper feed fail, you need clean the roller anyway. still not fixed, you need to adjust the roller pressure by increase the spring force.`
Feb 07, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Paper will not feed correctly
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Jan 31, 2009 | Canon Pixma iP6000D InkJet Photo Printer
The paper will not load correctly
This not the problem with cart ,this is the problem rollers ,please these steps
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
Jan 24, 2009 | Lexmark X1270 All-In-One InkJet Printer
G85 Out of Paper
Are the rollers turning when the job is received? This is a very fussy printer and seems to misfeed often. If the rollers are turning, clean those rollers well with a damp rag. Take a can of air and throughly spray it out. Check for bits of paper that have been lodged in the rollers. Make sure the paper is well fanned by hand (put air in between the sheets) before you load it. Make sure the paper is all the way back.
If the rollers are not turning, then you have either a software problem (job not received correctly) or a mechanical issue. Hope this helps. If so, would you please rate this solution? Thanks!
Sep 25, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
Canon MultiPASS MP390 All-In-One InkJet Printer Logo
162 people viewed this question
old marine
old marine
