Question about Gestetner Office Equipment & Supplies
Hw do l clear error sc402 - Gestetner Office Equipment & Supplies
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 76 Answers
I have just found this site and I am sure it will be of use to you
www.scribd.com/doc/8007865/Codici-Errore-Ricoh
Posted on Feb 20, 2012
2 Suggested Answers
  • 7 Answers
SOURCE: Error code on display. Sc402. what does the error
Transfer problem
Your Transfer unit disconnected or bad connection.
Unlikely, but a transfer power supply could be faulty.
A piece of paper stuck in the transfer area could also cause that code to come up.
If the machine is dirty and you see toner all over when you open the right side of the copier, have it cleaned thoroughly, that will most likely solve your problem.
Posted on Aug 24, 2011
Transfer problem
Aug 24, 2011 | Ricoh Aficio 120 Copier
Tip
How to elminated sc402
some times transfer unit current didn't receipted charge properly there is two springs charge transfer unit if one of both out of position may causes sc402
on Apr 23, 2011 | Office Equipment & Supplies
Fuctional problems sc402. ricoh aficio 150
SC402: Transfer roller leak error 2
A transfer roller current leak signal is detected.
The current feedback signal for the transfer roller is not detected.
- Possible causes -
  • · High voltage supply board defective
  • · Poor connection of the PCU
  • · Transfer/separation unit set incorrectly
  • · Transfer roller damaged
Jan 26, 2011 | Ricoh Aficio 150 Copier
Error Code SC402 in Ricoh Aficio 270
transfer roller negative current error
Jun 25, 2010 | Ricoh Aficio 180 Laser Printer
Gestetner 3225
SC401: Transfer roller leak error 1
-Definition- [B]
- Possible causes -
Jul 23, 2008 | Gestetner DSm618 All-In-One Printer
Aficio 1035
Not sure what SC818 is as not in my manuals please try the following.
Entering and Exiting SP mode
1. Press the Clear Mode key.
2. Use the keypad to enter “107”.
3. Hold down Clear/Stop for at least 3 seconds.
4. Enter the Service Mode.
To enter the Normal Service Mode:
Copy SP On the touch-panel, press Copy SP.
Once in the service mode turn the main switch off located on the left hand side of the machine wait 5-10 seconds then switch back on. This should get the machine working. Hope this helps
PLEASE DO NOT ADJUST ANYTHING ELSE WITHIN SERVICE MODE AS CAN DAMAGE MACHINE OPERATION)
Thanks J
Dec 24, 2007 | Ricoh Aficio 1035 Copier
Machine display an error code sc 500
YOU MUST RESET machin by: press clear mode key(yellow)---enter 107 by keyboard----press clear/stop key (red) for4 seconds--- turn off machin and on
Dec 22, 2007 | Gestetner DSm615 Digital Imaging System
Fault code SC402
A current leak signal for the transfer
roller is detected.
A current feedback signal for the
• High voltage supply board defective
• Poor connection of the PCU
• Transfer/separation unit set
incorrectly
• Transfer roller damaged
The above is what SC402 means the most common thing is that someone tried to change the toner and pull out the drum unit a little way.
OPen right hand door open front door lift green toner handle press green button and pull toner unit out press the green button further and keep pulling and then the toner unit will come out totally.
To the right of that is the drum unit pinch the unlock and pull out then push all the way back in. Reinstall the toner unit close all covers and turn machine on.
Hopefully this will work if not there is going to be a problem with the other possibilities listed above
Thanks J
Nov 19, 2007 | Ricoh Aficio 180 Laser Printer
Error code
The other end cut the received page as it was longer than the
maximum limit. Split the page into smaller pieces, or ask the other end to change their maximum receive length setting, then resend.
Oct 16, 2007 | Ricoh FAX5000L Plain Paper Laser
124 people viewed this question
Top Gestetner Office Equipment & Supplies Experts
Adorjani Laszlo
OfficeServiceAjnc
OfficeServiceAjnc
CheckitRight
CheckitRight
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
