Sony pcv-rs520 boot bios - need BIOS entry key for changing boot drive
  • 669 Answers
Should be the F2 key to enter setup. Make sure you are pressing this key during the VAIO spash screen on boot. If you press it after the spash screen the bois will not load and you will have to power cycle the computer to get the spash sreen back and try again.
Posted on Feb 20, 2012
RescueTechLA
  • 2653 Answers
SOURCE: Boot a Sony DVD RW DRU-840A drive in DELL precision 530
Have you tried changing the boot order.
If you're trying to use it as a boot device you need to tell the system to boot the cd /dvd drive FIRST and of course you need to have a bootable cd / dvd in the drive.
Let me know if you're already tried this.
Posted on Mar 04, 2009
  • 56 Answers
SOURCE: Changing Sony Vaio BIOS
you should be able to exit and save changes, which my guess is you are exiting without saving the changes. theres is a way around this, by pressing either F8, F9, F10, or F12 to access the boot menu, and then you can boot from cd to install your linux operating system
Posted on Jan 09, 2008
marked
  • 6487 Answers
SOURCE: emachine boots to bios with a new hard drive installed
Go inside to your BIOS menu then set the BOOT sequence to CD as the first boot so when your PC with the operating system installation disk inside it will load the installation wizard.
Good luck hope that helps........
Posted on Jun 16, 2008
pra0099
  • 153 Answers
SOURCE: my sony vgc-rb40 will not boot bios with cpu fan connected
mostly all fans are 12V DC try connecting all the fans directly to SMPS of the system i.e the red and the black wire
Posted on Sep 18, 2009
parrotheadpc
  • 2600 Answers
SOURCE: PCV-C12L Sony Vaio Pent. 4 proc. Reboots.
In most cases sonys boot into BIOS by one of three keys, the first being the delete key, the second is the F2 key, third is the escape key.
Posted on Sep 27, 2009
The boot order was saved in the bios and now when i press f2 it wont let me in
Restart your computer During the boot process you will see on the screen a certain key to press usually the Delete or F2 to enter setup this may vary depending on your computers bios other possible keys Acer: - Ctrl +Alt +Esc
ALR PC: (F2) or (Ctrl)(Alt)Esc)
AMI BIOS: (Del), (F1) or (F2)
AST, Advantage, Award, Tandon: - Ctrl + Alt + Esc
Award BIOS: (Del) or (Ctrl)(Alt)(Esc)
Apr 17, 2013 | Sony VIAO P4 PCV-RS712 3.0GHz 512MB 200GB...
How do I get into the cmos
during the boot process you will see on the screen to press a certain key usually Delete or F2 to enter setup
this will differ depending on which bios you have
Press and hold that key during the boot up process to enter BIOS
if you have changed any of the BIOS settings by mistake
you can load failsafe or optimised defaults using the arrow keys you can after you make any changes in BIOS press Esc then press the F10 button save to cmos to restart
CMOS is an on-board semiconductor chip powered by a CMOS battery inside computers that stores information such as the system time and date and the system hardware settings for your computer..
hope this helps
May 09, 2012 | Sony PCV-2222 Vaio 2.4GHz Pentium 4 768MB...
Can't find hard disk drive error message!!!! takes me to Bios menu. I reset the defaults and restart but windows won't load! need help!
The next time you go into Bios check the boot order menu to make sure that the hard drive is listed first. If not changed it to boot first!!!!
Oct 01, 2011 | Sony PCV-RS620G PC Desktop
Ran out of disk space on my Vaio desktop PCV-RZ24G. 120 gig drive but c formatted to 19 gig. purchased a WD 250 gig and did a disk clone. installed in pc and at first power on it stops at no boot device...
This is what I disliked about the "Sony hard drive partitioning plan" - they don't give you all of the C partition and then you run out of space. Out of frustration, I formatted the entire hard drive so that no remnants of Sony was in it and installed a fresh copy of the operating system, used the product key from the original operating system, sticker (label) affixed on the case to active Windows again. I got the entire C partition all to myself! Since you cloned that hard drive, you still have the "Sony hard drive partitioning plan".
Dec 30, 2010 | Sony VAIO Digital Studio PCV-RZ24G PC...
I have a sony vaio pcv-L400 when I turn it on it says: disk boot failture, insert system disk what can I do I dont have the system disk
That message means that, for one reason or another, the computer can no longer see it's hard drive. The hard drive may have failed, or it might just not be firmly connected (especially if you recently moved the computer).
Sep 15, 2010 | Sony VAIO PCV-L400 PC Desktop
Sony vaio pcv rx680g desktop
First, ensure that the bios is reading the hard drive and that the hard drive is part of the boot sequence. If you have a known working drive and the drive is not been read by the bios, you will get the Disc Boot failure error because windows resides on the disc which the bios cannot access.
Secondly, if the bios is reading the disc then ensure that the disc is set as part of the boot sequence-preferably the item after DVD drive should be Hard Disc in the boot menu.
If both of these items are in correct order then you could have a bad boot sector on the drive. Run a C:Chkdsk. If no bad sectors are found try C:Fixmbr-ensure that the Windows installation disc is in the CD/DVD drive when running Fixmbr.
If that fails do a clean install of windows.
Good Luck
Sep 28, 2009 | Sony VAIO Digital Studio PCV-RX680G...
PCV-C12L Sony Vaio Pent. 4 proc. Reboots. Can't access BIOS, don't know what key to push. Need to set BIOS to boot from CD to reinstall OS Possibly corrupt System files.
Sep 27, 2009 | Computers & Internet
Sony vaio pcv-rs510 fails to fully boot. Goes past initial windows screen then blanks out.... safe mode fails to boot as well... command lines just pile the screen.. need help plzz
reinstall os.bios should be preset to boot from cd/dvd but if not power on then press delete key or escape key till bios loads-in boot opt. select cd/dvd drive first boot.put os disk in drive and restart when asked to press key to boot from cd do so.follow inst. instructions.after insall detects previous version of xp select repair (r key) and follow inst. should solve startup problem without losing data.if not reinstall os but select leave files intact instead of format or you will lose all files.
May 31, 2009 | Sony VAIO PCV-RS510 PC Desktop
Jan 09, 2008 | Sony VAIO PCV-RX511 PC Desktop
Computers & Internet Logo
107 people viewed this question
David Payne
David Payne
