Question about Sony DCR-VX2000 Mini DV Digital Camcorder
I use a sony vx2000, and lately, i've noticed when that the shot gets lighter and darker and then lighter again, like the iris is opening and then closing suddenly. i film skateboarding, and the f
I filmed the day after it got hit, and this didn't happen.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Sony Master
  • 102,366 Answers
It looks like the camera's autoexposure is compensating for the changing light levels. As you pan around, the brightness of the scene changes and the camera changes exposure to compensate.
Try locking the exposure, using the instructions in the "Shooting with manual adjustment" section of the manual (page 44 in my copy). If you need a copy of the manual, you may download one here.
Posted on Feb 22, 2012
Testimonial: "thank you!"
2 Suggested Answers
  • 63 Answers
SOURCE: Burnt CCD sensors?
Yes - the CCD is damaged by the IR portion of the sunlight.
Posted on Aug 22, 2009
Testimonial: "Thanks! Just needed to confirm the source of the problem. That was very quick response."
Tape stuck inside Sony VX2000
If you are on about the VX2000 which is similar to the professional DSR-PD150 remove battery or supply then simply apply 3volts to the main mech drive motor and unthread the mech from the load position you will notice if it is in the load position because tape will be laced around the drum assembly hence the fact you can not remove the tape
John www.jvsvisual.com
Apr 02, 2013 | Sony DCR-TRV285E Digital-8 Digital...
We have a Frigidaire electronic ignition range about a decade old. The stove works fine. But lately we've noticed if we're using any stove elements the oven won't ignite and heat up. Conve
Sounds like the pressure regulator on the stove is going bad. The pressure regulator is located in the back. Your gas supply line should connect directly to it.
Dec 23, 2012 | Kitchen Ranges
Phillips 47PFL422D/37 I've had the tv about 6 years with no trouble. But now the picture is to dark to watch it also pulses. I've tried to unplug it and plug it back in I get a picture for
First, average life on these sets is about 3 to 4 years at best and only boards are sold so even if you can pin point the board (no individual parts are sold) it is likely if will not get fixed and doing so is a bad investment as all the boards are now old.
Dec 04, 2012 | Televison & Video
I notice horizontal lines like "glitches" only when I go to put the footage on my computer. I tried head cleaner but it failed to solve the problem. I also noticed the sound cuts off for a brief...
This is usually caused by an oxidized, misaligned or defective Audio/Video drum. If you've tried running a cleaning tape through the camera with no success, the camera will need to be serviced by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Sep 13, 2011 | Sony DCR-VX2000 Mini DV Digital Camcorder
I have a sony vx2000 mini-dv camera and when I try to play back some tapes I've recorded on the camera I get an error code c:21:23, I don't get this everytime, just sometimes.
Tape mechanism problems can be quite complicated. This will require disassembling the camera to repair the tape mechanism and can be done fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com.
Jul 09, 2011 | Sony DCR-VX2000 Mini DV Digital Camcorder
How do I replace the right hinge on the lid of a Sony Vaio PCG-6Z4L?
That link for the PCG-K series is no good (e.g. a site for how to take apart an printer would be just as useful; sorry Martin Murray).
I have the same laptop as you (PCG-6Z4L), couldn't find a site. Like most laptops, it's about getting all the screws out and then being gentle with the plastic barbs (spudger or fingernail helps). In our case, there's only one hidden screw, discoverable by taking off the memory plate. The other tricky part is separating the top most plastic keyboard/palmrest assembly from the rest (then your on to getting at things like the hinge).
I've attached a pic so that you can see your laptop in two pieces (i.e. that part of the lighter grey stays with the darker grey; again, spudger or fingernail and knowing the two separate should help).
Apr 06, 2011 | Computers & Internet
I get a blue screen and won't let me record
The dcr-trv250 has to common problems that apply to your camcorder. Bad iris or bad ccd imager. I've seen about a 100 of each lately. Look into the lens while you turn the power off then back on into camera mode. You will be able to see the iris open. If you don't see it open then it's most likely bad. Larry's Electronics Sacramento Ca. 916-362-8708 ledstiles@hotmail.com
Apr 23, 2010 | Sony Handycam DCR-TRV250 Digital Camcorder
Overexposure on outdoors shots
i think it is a case of defective apparture system. the system controlling the change of apparture opening has been locked. the reason may be friction in the blade movement or defective flex pcb carring the signal to the apparture motor.
Jul 03, 2006 | Olympus Camedia D-550 Zoom Digital Camera
Seized vanes on iris motor?
Well some good news, I hope. Your problems sounds like the Sony Blues. Read this from Sony and YES your camera the 717 is covered. Important Notice About Your Sony Product Posted: 10/03/2005 Thank you for your support and patronage of Sony products. It has recently come to our attention that a limited number of products, manufactured prior to March 2004, that incorporate a certain type of image sensor device (CCD) may exhibit the following: When the product is used in camera mode, the LCD panel and/or electronic viewfinder exhibits either a distorted image or no image at all. We have determined that this only occurs in a limited number of devices, but may be accelerated if they are exposed to hot and humid environments. From October 3, 2005 through October 2, 2007, Sony will repair, free of charge, affected products exhibiting the above-mentioned problem where it is caused by the image sensor device. Sony will also cover the cost of shipping and handling to service to correct this issue. Please contact the Sony Customer Information Services Center for further assistance at 1-866-703-7669.
Jun 12, 2006 | Sony Cyber-Shot DSC-F717 Digital Camera
Sony DCR-VX2000 Mini DV Digital Camcorder Logo
139 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
