Question about Casio GShock Giez watch #GS10011A Watch for Men
Is it possible to convert the resin band strap of casio GS1001 to metal bracelet? If yes, where can I get the metal bracelet?
  • cjdg Feb 21, 2012
    Thanks Pat for the link but most of them are resin straps. I am looking for a stainless steel metal band just like with the GS1000D. Is the metal band of GS1000D be compatible with the GS1001?
    Sniper:
  • 76 Answers
I have just found this site, it has all sorts of watch straps for all casio watches.
I am sure that you will find it useful
www.casiosalesandservice.com/starasp/a=3&dept=cwband&class=gshock.
Posted on Feb 20, 2012
    Genius:
  • 1,056 Answers
You can find metal replacement bands at a number of places. Personally I would suggest looking at places like Amazon, or some of the online retailers.
Posted on Jun 09, 2014
escapement
  • 2334 Answers
SOURCE: how to resize (remove links) from metal band on casio wtg900da8v
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Don't forget to rate, please.
Posted on Mar 21, 2009
SOURCE: how to adjust metal wrist band on casio watch?
Take it to walmart or any store with a jewelry section, they'll fix it
Posted on Sep 20, 2008
indays
  • 111 Answers
SOURCE: Shorten strap of Casio Edifice EF-518 watch
good morning ! thats verry easy to make shorter !just look the possition of arow and push the pin to out use the pointed tool and anvil to releas the pin ! thank you !god bless !....
Posted on Sep 02, 2008
escapement
  • 2334 Answers
SOURCE: Can not figure out how to remove links from Casio watch band
Job done!
Posted on Apr 01, 2009
escapement
  • 2334 Answers
SOURCE: how to adjust metal bracelet on casio A168 watch
Job done!
Posted on Apr 05, 2009
How to repair my broken wrist band
The local SEARS store has a watch-repair department.
May 19, 2014 | Sportline Solo 910M Heart Rate Watch
Neeed a replacemet strap, band or metal bracelet for Nautica N19558G Black dial Resin Mens watch
You can get it from Authorized Dealer of this Company. If it has nothing to do with it's warranty, any alternative shop will be an economic option.
Mar 29, 2014 | Nautica N19558G Black dial Resin Mens...
BG1301 Casio watch replacement band
Go to "casio.com" and click on "support".
Although they don't say so directly, their repair section imply that they can replace straps.
Jul 20, 2010 | Casio BG1301-4V Pink Baby-G Watch with...
How to shortend the metal band
On most brands, there are pins that form hinges for the links of strap. You need to push them out. usually you would find arrows marked from inside of the metal bracelet which show you the direction in which to remove the pins. You can remove it if you have a small watch maker's screwdriver but you have to be careful. or get one of these ..
http://www.amazon.co.uk/Watch-bracelet-link-adjuster-remover/dp/B001ZKIL2S/ref=sr_1_1?ie=UTF8&s=watch&qid=1254695541&sr=8-1
which should help you to remove the link pins safely without scratching.
Sep 30, 2009 | Casio Edifice EFA110D-1AV Wrist Watch
Adjust-a-Casio-S-1087DY-Watch-Band
On most brands, there are pins that form hinges for the links of strap. You need to push them out to remove links. Usually you would find arrows marked from inside of the metal bracelet which show you the direction in which to remove the pins. You can remove it if you have a small watch maker's screwdriver but you have to be careful. or get one of these ..
Aug 31, 2009 | Casio Edifice EFA110D-1AV Wrist Watch
Lock on the eco-drivel wrist watch snapped
IF they still make the same bracelet for your watch you will be able to buy a replacement. If the watch is a leather strap then it is much easier as I can guarantee they will have a compatible strap. Contact citizen to see if they have any metal bracelets or leather straps for this watch.
Jan 02, 2009 | Citizen Eco-Drive BL006056H Wrist Watch
Watch strap to loose
If you are ready to take that risk, here is how you can do that.
First- get watch on your wrist and by squeezing the bracelet count how many links you have to take out to make it tight enough (say 4 for example).
Check the sides of a bracelet. You will notice that the upper bands metal is flipped over the bracelets side. Take tweezers or small pliers and unbend one of these. Try to do as little damage as possible.
When it's done, you will see two metal staples inserted into the bracelet. You have to pull them out. While pulling out, remember how they where positioned, as you will need to drive them back in the same manner.
So, when the staples are out, do the same on the other side of bracelet. Now you have bracelet in two halves.
Count off 4 links and undo the staples in joint of 4th and 5th link in the same manner as previously.
When links are out, take the staples and drive them back into the bracelet koining two ends together. You have to do that exactly the same way and position as you took them out.
When all staples are in place, bend the metal back over to the bracelet sides.
BE WARNED: as you gonna do it first time, be ready that you can damage the bracelet or can not put it back together.
Good luck.
Dec 18, 2008 | Watches
How do you replace the watch band on a casio g-shock
The following proccedure mentioned can be implied for replacing only resin(plastic) strap.
If you have a spare Band, you can replace it with the help of one small four mouth screw driver and one small 1, 2 or 3 no. screw driver which you can get from any electronics/ computer hardware shop.
Band = Strap
You just need to remove the strap with the help of 1, 2 or 3 no. screw driver which ever you find convinent by removing the Spring Bars. After removing the strap put out spring bars from both sides as these may be used for again fixing the band.
If you find difficulty in removing the Band, you just need to unscrew the screws on for side of the watch case and remove the ring and after fixing the strap you can fix the ring again.
The new band can be fixed in the same way as it has been removed. You need to put the spring bar in the hollow space of strap and keeping the buckle side part of starp above the watch i.e 12 position over the space where it has to be fixed, then put one end of the Spring bar on one hole in the watch case and press the spring bar to get inside from other side (hole in the watch case). In the same way you can replace ******** other side.
In case of any difficulty take your watch to nearest Casio Service Centre for assistance or solution of problem.
Jul 20, 2008 | Casio Watches
Casio GShock Giez watch #GS10011A Watch for Men Logo
610 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
