Question about Mitsubishi Diamond WD-65831 65" Projection HDTV
Mitsubishi WD-52631 top 3 inches wavy.
Recently moved bulb just replaced
  • Drew Mill Feb 20, 2012
    I have tried different inputs, reset the bulb, reached in and tried to smooth out the screen (sort of), moved to different outlets...
    By "top" I'm referring to the screen.
  • 20 Answers
Best,Genuine and Simple Online business which Really Makes you a Millionaire ! visit :- http://bit.ly/xM9lTH
Posted on Feb 20, 2012
    How does that help?
  • 3422 Answers
SOURCE: Outer screen scratch
You can try for the parts from HERE or from HERE
Goodluck,
Please don't forget to rate the solution.
Posted on Mar 27, 2008
SOURCE: Mitsubishi WD-52631 HD TV lamp problems
After contacting mitsubishi again i have found out the problem they say is a design fla the filter on the back the mesh gets filled with dust and then over heats .
Its funny that soon as I told Mits about what tv I had and how long i had the 2nd bulb they told me we will have on out to you as soon as 2-3 days?????
I do have a service guy looking into a new balace,, thats his thought. All I know is Mits has been put on my sh*t list of tv not to buy
Posted on Jul 17, 2008
  • 179 Answers
SOURCE: Mitsubishi DLP wd-52725 wavy lines from top left to bottom right
the DM board is going bad and needs to be rebuilt. check out www.tv-techs.com
Posted on Jan 07, 2009
  • 184 Answers
SOURCE: Mitsubishi WD-73732 has 1 inch blue/purple band at screen top.
Is this a DLP or LCD projector?
Posted on Feb 14, 2009
SOURCE: WD-52631 Red Light-No Picture, still have Sound
unplug it from the wall, wait 30 seconds, then plug it back in. i had the same problem and this simple solution worked for me. Good Luck!!!!
Posted on Feb 17, 2009
Mitsubishi tv flashes yellow light
IT might not have been the bulb, it could be the ballast, it could be the power supply. The other things that it might be are the fan, the temp sensor or a bad bulb.
Mar 28, 2014 | Mitsubishi WD-52631 52" Projection HDTV
Misubishi wd-52631 DLP TV, it shuts off suddeny. when turn it on again, the green power light is flashing, then steady green, then shut off again. the lamp light is NOT falshing or red. the status light...
Hi, have you replaced the lamp after 2-3 yrs of usage? The lamps used by mitsubishi tend to last around 4000 hrs 1-3 yrs.It is common for the green light to light up.Other common failures are the ballast which is the board that powers the lamp.Also check if its not overheatin, dust out the fans.Heres where u can get the lamp or ballast http://www.discount-merchant.com/SearchResults.asp?Search=wd-52631
Apr 19, 2011 | Mitsubishi WD-52631 52" Projection HDTV
My Mitsubishi WD-52631 went "POP"
No,probally a capacitor the help the power supply board to work or other boards to work is blown.Call some tv shops get a best quotes prices,get a tv tech out to it fix,if ur tv is out of warrenty.
Jun 17, 2010 | Mitsubishi WD-52631 52" Projection HDTV
I have a mitsubishi wd-52631 approximately 3 years old have had to replace the bulb 7 times is there a malfunction in these televisions that should be fixed to avoid having to keep replacing these...
You have a problem that is destroying your "Bulbs" this is NOT normal at all. This is indeed a problem when people aren't experienced enough with technical matters. You see the "Bulb" is a Symptom, of the actual "Fault" NOT the main cause. This, "main cause" MUST be fixed FIRST, before one replaces anything, otherwise what you are experiencing, will simply happen over and over again, and gets more expensive that if one had of sent it to a reputable service centre/man in the first place. We really ARE worth our salt.
Feb 12, 2010 | Mitsubishi WD-52631 52" Projection HDTV
WD-52631 Audio works, but no picture
Probably a bad lamp. This is the first thing I would try....especially if the lamp has not been re[placed in awhile.
Oct 10, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Jan 02, 2009 | Mitsubishi WD-52725 52". Rear Projection...
So far I have had no good luck with Mitsubishi. I have had them send me two bulbs and had the tv repaired in the two years I have owned it. My last tv lasted 14 years with NO issue and didn't cost me $1400!! I have been told there is an air flow problem and power supply problems which both lead to low lamp life. I think that if Mitsubishi wants to avoid a class action lawsuit they need to start giving away free lamps for this model. Also, this is not localized to just the 52" tvs. My wifes ex has the 62" and it has the same issues.
May 23, 2008 | Mitsubishi WD-52631 52" Projection HDTV
Mitsubishi is currently offering the following parts
Model Number Model Description Part Number Part Description Price Available WD-52631 52" DLP TV I/B WD52631 OWNERS GUIDE $15.00 YES WD-52631 52" DLP TV I/QR WD52631 QUICK/REF WD52631/57731/65731 'G' $3.50 YES WD-52631 52" DLP TV 915P049010 LAMP (150W) (V33/V33Y/V33+) 'G' $249.00 YES WD-52631 52" DLP TV 290P137010 REMOTE 'G' $33.10 YES
Mar 27, 2008 | Mitsubishi WD-52631 52" Projection HDTV
Mitsubishi 52 " model WD-52631
Nope the bulb is fine. This set sucks up dust and contaminates the light engine. Rarley does blowing the set out with compressed air fix this, The light engine can be disassembled and cleaned but this is best left to someone who has done this once before. Because if it gets messed up you get to buy a $1500.00 light engine
Feb 13, 2008 | Mitsubishi WD-52631 52" Projection HDTV
Mitsubishi Diamond WD-65831 65" Projection HDTV Logo
74 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
