Question about KitchenAid Architect II KEMS378SSS Stainless Steel Electric Double Oven
Kitchenaid combo oven and microwave model # kems378sss
I have just bought a brand new kitchenaid combo oven and microwave model # kems378sss . My problem is that when the microwave gets a the end of his cookingtime*0:00*, it make's the 3 normal beep, the heating stop,** BUT the plate keeps on turning,the light stays open and the fan keeps on workind too. I bought thisoven/microwave in november 2 2011, they have come now 3 times to repair it and cannot find the problem.And now they sent me a new one,and still does the same thing. What can it be or what m i suppose to do? Do you think they have a problem with a part at the factory? Or did ever somebody saw that before?
  • Alexandre Hart Feb 21, 2012
    just the heating stops, but not the fan,not the light and not the turn table. And it will stay on as long as you dont press cancel or open the door.( that means that if you forget something in to the microwave, it will keep on working day and night without heat for as long as you dont open the door or press cancel
5 Suggested Answers
  • 116 Answers
SOURCE: Oven will not heat at all after an interrumpted cleaning cycle (power went off)
There is a thermo fuse located behind the back panel of the oven. If the oven appears to be working but is not actually heating then this is the cause. The oven will have to be removed from the wall, power to the oven shut off at the main breaker and the back panel removed. the thermo fuse is just to the left and up from the center of the convection fan. It has 2 wires connected to it.
Posted on Mar 11, 2007
SOURCE: OVEN will not heat
After reading the above, here is how I fixed my KEBS177DSS9
I pulled out the wall oven from the cabnet. Took off the back tin panel about 10 tin screws. Follow the wire from both heating elements. They are both connected to a thermo fuse. When using the self clean feature this fuse protects the oven from over heating and starting a fire. I put a jumper wire from the hot lead on the left and connected it to the 2 leads on the right side. I turned the power back on and turn the oven on to bake at 350 degrees. Yep It worked like a charm. I bypassed the thermal fuse and used the oven, until the new thermal fuse was ordered. If you have any questions about this fix email me at jodunn5555@aol.com Good luck
Posted on Dec 24, 2007
SOURCE: kitchenaid oven door will not stay closed
I had the same problem on my parents Kitchenaid KEMS378GWH0 oven, the door would only close enough to keep the light on. They propped a chair against it to cook. My father replaced the hinges and it worked for about a week. He noticed that pulling outward on the door at the very bottom edge often allowed it to close enough to use.
After completely dismantling the oven to get access to the brackets that the hinges slide into, we found it was not broken. We decided to expand on the only near solution we had and find a way to make the bottom of the door 'push out'. Our solution was very simple. Remove the small metal plate that covers the door insulation. This revealed that the insulation is a braided hollow rope that is held in by small clips that push through holes in the front of the oven. We threaded some small metal rods about 3/8 inch in diameter into the hollow insulation pushed the clips back in to re-attach the insulation, replaced the metal cover plate.
It worked!
Posted on Nov 29, 2008
hbsurfdawg
  • 95 Answers
SOURCE: Kitchenaid KEMS378sss fan noise
Does it keep heating food? You do not run it without the fan very long and maybe it will shut off or down when it senses the fan stopped and might stop cooking. You want to isolate it is the fan and not the magnatron (cooking device). It is pretty new for that but always a posibility.
Do you have a straight vent fan that you can turn on without cooking? try that and see what you get. If it does the same, I think you have a defective fan.
e
Posted on Nov 19, 2011
Kitchenaid superb microwave.oven combo KEMC308KSS0 is giving F2 E0/E1 error. Replaced the switch membrane and also the Control board. The error still shows up.
Ledgestone Technologies has replacement keypads for NO LONGER AVAILABLE Whirlpool and Kitchenaid models. Each one comes with a new ribbon cable and 2 year warranty.
Contact FixYourBoard.com for more information!
512-355-1108 info@fixyourboard.com
Apr 15, 2017 | KitchenAid Ovens
Kitchenaid selectra
possible but unlikely. they are physically connected?
Mar 07, 2014 | Ovens
e
Nov 19, 2011 | KitchenAid Architect Series KEMC308KSS...
MY KITCHEN SUPERBA MICROWAVE/CONVECTION OVEN BEEPING IS ANNOYING
Sorry, I have the same oven and the same complaint. The manual doesn't indicate anything. BTW- the service manual is inside the oven frame, between oven "lining" and the outside sheet metal.
Jan 03, 2010 | KitchenAid 27 in. Built-in...
Multiple replacement of Microwave door springs
KitchenAid Architect Series KEBC107KSS Electric Single Oven problem error F1E7
Sep 15, 2009 | KitchenAid KEBC107 Electric Single Oven
Need to replace light bulb in kitchen aid microwave
KitchenAid wants $58 for the replacement bulb. I bought it for $1.99 from www.lightbulbsdirect.com and it works just fine. The Item number is Q5G412V. It is a halogen 5-watt, 12-volt bipen G-4. Replacing the bulb requires some dismantling of the microwave. At first I was nervous about removing so many parts to get to the bulb but in the end it really wasn't so bad. The only tool I needed was a Phillips screwdriver. I surfed the net a eventually found instructions left by a friendly Blogger that guided me through the whole process. KitchenAid engineers were so STUPID when they designed this microwave. It takes two hours to replace a bulb that should take 5 minutes. Oddly enough, replacing the bulb in the normal oven below the microwave oven is a piece of cake.
Jan 19, 2009 | KitchenAid KEMC308 Electric Double Oven
KitchenAid Wall and Microwave Oven Combo - KEMS308SSS
Have had this oven for 8 years. At least three times, usually after using the clean cycle in the main oven, the latch mechanism has broke and the oven door will not open. In March they installed a 'new design' to prevent this. It's seven months later, and it broke again. Has anyone had similar experiences? How did you resolve?
Aug 27, 2008 | KitchenAid Architect® KEMS308SSS Stainless...
KEMC308KBL01
send me am e mail at b4829@yahoo.com with the model number
May 31, 2008 | KitchenAid Architect Series KEMC308KSS...
DOUBLE OVENS FROM KITCHENAID
Redhead Do nothing and call the manufacturer. Your oven has one year warranty. Gendos...post back
Mar 22, 2007 | KitchenAid Architect Series KEBC278KSS...
KitchenAid Architect II KEMS378SSS Stainless Steel Electric Double Oven Logo
63 people viewed this question
Top KitchenAid Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
