Question about HP LaserJet 1020 Printer
Printing codes in memo field for laser printing in foxpro 2.6 for windows
Want to print Text bold or underline in a Memo field, was easily done with ESC characters in dot matrix printer how to do it in laser printer. How to put the esc sequence
3 Suggested Answers
SOURCE: foxpro dos programme not printingin usb printer laserjet cp1515
You can access your printer connected to USB port with loop back configuration and print from DOS.
Not only that, you can also print to a printer on the network
Try
Net use lpt1: \\Comp name\ printer name /persisten:yes
Posted on Jan 22, 2009
SOURCE: not printing in foxpro 2.6 dos to hp laser jet 1020
You write "type the above line at command prompt". I dont't know Where exactly to write? Can you tell me!
Posted on Dec 02, 2009
How to repair a corrupt FPT file
Use eRepair DBF is designed to be used by a wide range of users from the novice to the advanced user. The software has a user friendly interface that requires very little user interaction.
For more: http://dbf.erepairtools.com/
Jul 28, 2015 | Microsoft Visual FoxPro 9.0 Professional...
How to recover a database on known *.bak file?
Completely - in any way. If you find also tbk the file - then is possible. bak is
backup copy of the dbf file, tbk - a backup copy of fpt (there a memo of a field are).
However you were perhaps lucky, and actually fpt the file wasn't cleared.
And it is possible "to restore" of course simple renaming of bak file into dbf file. Of course then have to be reindexed the table, and if the structure changed, in general, to recreate the indexes from scratch. and perhaps "to treat"
the container Database dbc/dct (if you use it of course).
If so it doesn't turn out, then try to restore through DBF Viewer Tool. It well restores.
http://www.dbf.viewertool.com/
Come here on a forum and look at councils for this subject is there.
http://www.filerepairforum.com/forum/databases/databases-aa/dbase-iv-clipper-foxpro/1355-help-to-repair-dbf-file
Feb 10, 2015 | Microsoft Visual Fox Pro 9.0 - 34001231
How do i unlock memo on galaxy s2
Hi Andre,
You must gain root access in order to reset the password as there is no other way. If you do not have access, search XDA Forums for instructions on how to root. Rooting procedure for S2 is pretty established and straight forward.
Once you have root, you will need to do the following steps:
  • Get a Root File Browser which can edit and save text files. I used: Root Browser. Make sure you download the plugins at first run. (2-3MB in size)
  • Browse to: /data/user/0/com.sec.android.app.memo/shared_prefs/
  • Open AppLockPreferences.xml with some text editor.
  • Change the value field in front of applock_enable from "1" to "0".
  • Change the value field in front of encrypt from "true" to "false"
  • Save the file. Open SMemo, it should ask you to set a new password. Your memos should open with the password you just set.
    Please contact me if you need further assistance,
    Thanks,
    Hunter Quinn
    IBM Technician
  • Jul 08, 2014 | Samsung Galaxy S GTI9000 Smartphone
    How do i bold print
    Bold underlined itallics fontsizes and colours
    Type <b> before the writing that you want bold.
    End the bold text, type </b> after the part that you want in bold to go back to normal.
    Type <i> or <u>, to write in italics, or underline.
    Type <center> to center a selected area. When finished, you will need to type</center>
    Type <font color="colorcode"> and end it with </font>,to write with different colored fonts.
    Type <font fontsize="size">to change the size of the font you would like to use.
    hope this helps
    Aug 13, 2012 | Microsoft Windows Vista Home Premium with...
    My Canon pixma MP250 can print, but does not scan or copy
    Try to do it by manually.
    If you can get a print out from your printer.....do it as manually.
    Go to window start button and find drawing tool under program....(there are games, calculator, memo..etc)
    And open up the drawing tools and will see the scanning option under "file manu".
    And try to scane manually...
    If you would like to save money, try refill kit by "ROADINK".
    Not only they are easy, but also the printing quality is good.
    For your better understanding pls check out my youtube video.
    And will see how easy ink refill can be done.
    http://www.youtube.com/watch?v=tZlkJ-YDsZA
    May 18, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
    How do I set the on screen right margin in Outlook 2007? Can't find this anywhere. I did find some mention of changing the margins in the normalemail.dotm. I tried this, but the on screen margins didn't...
    1. Office Button --> Print --> Page Setup --> Memo Type
    2. Print layout shows wrapped text, that's disabled in MS Outlook 2007, you can customize quick accrss bat fot it:-
    Office button --> Customize --> Enable all tools --> Select Print Layout View
    Apr 07, 2010 | Microsoft Office Outlook 2007: Windows
    Ricoh CL3500N - not printing all characters on the page
    It might be a print driver problem. I think there several different drivers. Go to Ricoh-usa.com and download all the drivers for the operating system you are using and try them. If there is a rpcs driver that might be your best bet.
    Apr 24, 2009 | Ricoh Aficio CL3500N Laser Printer
    Not printing in foxpro 2.6 dos to hp laser jet 1020
    Feb 05, 2009 | HP PSC 1610 All-In-One InkJet Printer
    Pls help in this VB code, Sato CX400 barcode printer
    jst try this u create a label from label printing software using ato font then make a prn
    then attach u r vb code in to prn it will work
    rohitjain
    prn example-------------
    A
    Z
    A
    CB+18
    Z
    A
    CD250,3300
    Z
    A
    AR
    Z
    A
    A100950647
    Z
    A
    %2h416v0072BG01031>H23456111
    %2PSP02h573v0021L0101XS922
    %2PSP02h618v0021L0101XS18K
    %2PSP02h415v0089L0101XS17125
    %2PSP02h416v0039L0101XSPO124
    %2PSP02h416v0022L0101XS215gms
    %2PSP02h618v0043L0101XSDR37/0.20
    %2PSP02h618v0064L0101XSDR37/0.20
    %2PSP02h618v0085L0101XSDT/B44/0.82
    Z
    vb code example------------------
    Open "LPT1" For Output As 1
    Do While rs.EOF = False
    For I = 1 To Val(Text1.Text)
    Print #1, "A"
    Print #1, "*&"
    Print #1, "Z"
    Print #1, "A"
    Print #1, "CB+18"
    Print #1, "Z"
    Print #1, "A"
    Print #1, "CD250,3300"
    Print #1, "Z"
    Print #1, "A"
    Print #1, "AR"
    Print #1, "Z"
    Print #1, "A"
    Print #1, "A100950647"
    Print #1, "Z"
    Print #1, "A"
    X = "%2h380v0065BG01031>H"
    Y = rs.Fields(6).Value
    X = X + Y
    Print #1, X
    Print #1, "%2PSP02h618v0085L0101XSKT"
    Print #1, "%2PSP02h600v0085L0101XS", rs.Fields(1).Value
    Print #1, "%2PSP02h618v0064L0101XSNetWt"
    Print #1, "%2PSP02h600v0063L0101XS", rs.Fields(2).Value
    Print #1, "%2PSP02h618v0043L0101XSDiaWt"
    Print #1, "%2PSP02h600v0041L0101XS", rs.Fields(3).Value
    Print #1, "%2PSP02h618v0021L0101XSColWt"
    Print #1, "%2PSP02h602v0021L0101XS", IIf(IsNull(rs.Fields(4).Value), " ", rs.Fields(4).Value)
    Print #1, "%2PSP02h430v0084L0101XS", rs.Fields(5).Value
    Print #1, "%2PSP02h371v0028L0101XS$"
    Print #1, "%2PSP02h405v0028L0101XS", rs.Fields(7).Value
    Print #1, "&"
    Print #1, "Z"
    Print #1, " A"
    Print #1, " #E5"
    Print #1, " Z"
    Print #1, " A"
    Print #1, " CS2"
    Print #1, " Z"
    Print #1, "A"
    Print #1, " 0000"
    Print #1, "TEXT1.TEXT"
    Print #1, "/"
    Print #1, "Z"
    Feb 04, 2009 | SATO CX400 Thermal Label Printer
    Not printing print jobs
    pause all the other jobs and print only the one you need. if the memo is with in the print job go back to your software that you use to create it and select to print just the page number you need.
    Dec 04, 2007 | HP Photosmart C4180 All-In-One InkJet...
    HP LaserJet 1020 Printer Logo
    66 people viewed this question
    Seeker5211
    Seeker5211
