I need a code an awa LE-32G90G to program one for all
How do I program an MTV Universal remote controller to an AWA TV. I need the code for the remote controller which is a 2006 MTV Networks remote.
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Mar 13, 2016 | Universal Remote Control Televison & Video
What is the code to auto tune a AWA LE4603-O5 with a universal remote.
Every remote has a different way of programming it. You will have to find the manual for your remote online or at home. That is the only way to program it correctly. Look up the manufactures website for further info.
Mar 12, 2016 | Universal Televison & Video
Can't get my sansai univ remote URC-L969 to program with my AWA MHDV2445 tv
If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the relative post easily.
May 27, 2015 | Televison & Video
Phillips Universal remote SRP2008b/86 will not operate my AWA DP239 DVD player even though there is an awa code listed.
Try using code search. Also, Philips may be able to provide a code as code lists are sometimes updated.
Nov 13, 2013 | Televison & Video
I have a remotec F-BW0930 and the code for AWA dvd players 00375 does not work, I have an AWA DP220, do you know the code?
I don't have other code for your DVD but I can give you the steps on how to program your remote to your DVD without the list of codes.
1. Turn on your DVD.
2. Press the DVD Mode Key.
3. Hold down SET on the URC for 2 seconds until the indicator lights up.
4. Enter 0005. The indicator should go out immediately.
5. Press the DVD Mode Key again as in step 2.
6. Hold down SET for 2 seconds until the indicator lights up and your URC is ready to start searching.
7. Aim the URC at your DVD, press the power key repeatedly, slowly until the DVD has been turned off. Once your DVD has been turned off, immediately press SET to lock in code and the indicator should go out.
Jun 13, 2010 | Universal Remote Control Remote Control
Region Code for AWA DS-A33I
Have no disc in the tray
Press the set-up key
Go to system info
Enter 1101
Press OK
Enter Code 0
Let me know if it works
Mar 28, 2009 | Televison & Video
Televison & Video Logo
53 people viewed this question
Top Televison & Video Experts
Electro Med Services...
