Question about Refrigerators
I have a Kenmore coldspoy model Number 106.54589400... The watere dispeser and ice maker wont work. Seems like no water is geting to it. Help PLS
fridgetech
  • 473 Answers
SOURCE: ICE MAKER NOT WORKING Kenmore cold Spot model# 106.55536400
Most common problem is a broken ice maker module.  Should also replace ice maker thermostat when changing the module.  Make sure fill tube isn't frozen first. If you take the ice maker out pull off the plastic cover and in the center of the wheel that kind of looks like a gear there are two little plastic studs.  If one is broke or they are pressed together then the module is bad. Make sure to replace the thermostat along with some silicone grease because a bad thermostat is what causes the module to break.
Posted on Oct 20, 2007
SOURCE: Kenmore Refrigerator
check the mirco-switches behind the panel at the dispenser section. basically, when you depress the lever for water or ice, those levers make contact with a switch, and the switch turns on the ice dispenser motor. if the lever is pushed too hard, the switch can be knocked out of position. I had to re-position my ice switch with some duct tape.
Posted on Feb 16, 2008
maklean
  • 1665 Answers
SOURCE: no water to ice maker
  • The water line that's attached to the back of the refrigerator. Make sure you have good water flow. If the flow is poor, repair, clean, or replace the tubing or the shut-off valve that supplies the water.
  • The water-inlet valve. Replace it if it has failed.
  • Posted on Jul 28, 2008
    duby1990
    • 370 Answers
    Check to make sure you freezer is at 0 to 5 degrees. If it is not the water valve to the ice maker will not even open.
    Posted on Nov 20, 2008
    • 36 Answers
    SOURCE: Kenmore Elite refrigerator ice and water dispensers not working
    check for a child lockout button it will look like a tiny padlock ,press and hold for 3 sec.(could be the freezer door light switch)
    Posted on Jul 24, 2009
    My icemaker stopped working but the water on the door still works what can the problem be model number 106.51552104
    02fd7a9b-9a65-43a6-ae76-6bf68d211304.jpgThanks for the model number. If the ice slots inside the ice maker are empty try pouring tap water in and allow the water to freeze. If after the water freezes the ice drops into the ice bucket and the ice maker does not refill this would indicate that the side of the=> W10408179 Water Inlet Valve is defective on the side that controls ice maker water supply. If the ice maker just sits there and does nothing this would point to a defective ice maker. Depending what is wrong with the ice maker will determine what parts are replaced. Here is a list of those parts here=> Kenmore Refrigerator Model 106.51552104 Ice Maker Parts and if need you may be able to find a complete ice maker replacement by asking. Most people don't like replacing ice maker parts. I am here should you have questions or comments, Sea Breeze
    Aug 30, 2013 | Kenmore Refrigerators
    I have a Kenmore model number 106.51552104 my ice maker stopped making ice.. The water on the door still works but no ice what should I do??
    I believe I answered this one on another page of unsolved problems HERE. Thanks for the model number. If the ice slots inside the ice maker are empty try pouring tap water in the slots and allow the water to freeze. If after the water freezes the ice drops into the ice bucket and the ice maker does not refill this would indicate that the side of the=> W10408179 Water Inlet Valve is defective on the side that controls ice maker water supply. If the ice maker just sits there and does nothing this would point to a defective ice maker. Depending what is wrong with the ice maker will determine what parts are replaced. Here is a list of those parts here=> Kenmore Refrigerator Model 106.51552104 Ice Maker Parts and if need you may be able to find a complete ice maker replacement by asking. Most people don't like replacing ice maker parts. I am here should you have questions or comments, Sea Breeze
    Aug 30, 2013 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
    The water dispenser and ice maker have stopped working
    I would recommend to check the water shut off valves at the wall (behind the refrigerator) and under the sink before you call a plumber.
    Aug 11, 2009 | Refrigerators
    Kenmore side by side ice maker is not geting water. water is on and if I temp change electrical connectors on the silinoid and work the water arm on the door I can get water to the ice tray. What is wrong...
    You have a bad water valve . Both solenoids work independently of each other . 1 for the water dispensor and one for the icemaker .The icemaker when 5 degrees and harvests , tells the valve to give it water (electronically) .
    Jul 07, 2009 | Kenmore 57029 Side by Side Refrigerator
    Nov 20, 2008 | Kenmore 53642 / 53644 Side by Side...
    Ice maker not working, water not going in tray.
    Here is a tip that I wrote about the reasons why ice makers do not work.
    Ice Maker Problems and Ice Maker Troubleshooting
    heatman101
    iuoiout
    Mar 28, 2008 | Kenmore 21.7 cu. ft. Side-by-Side...
    there is some times a water relay that turns the water on and off the over heats, it located in the back where the water connects
    Dec 08, 2007 | Refrigerators
    Refrigerators Logo
    100 people viewed this question
    Top Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
