Question about Akai Xr20 Xr 20 Beat Production Station,drum,new
Midi conroller set up in akai xr20 im stuck on SEND OUT MIDI ?
5 Suggested Answers
djlaplaya
  • 74 Answers
SOURCE: Loading an MPC5000 with midi files
if the mpc has GM soundbank then this should be possible. You might be better off recording the audio from a suitable GM unit first of all before gigging with it, then you can make it sound the way you want and change the key to suit etc.
Posted on May 06, 2010
SOURCE: IMac not detecting EWI4000s via midi-usb adapter
My Imac does not find the midi ports form my Ewi 4000S. When I try to install midi ports ( just one choice possible) it does not work. What can I do ?
Posted on Aug 29, 2010
  • 1138 Answers
SOURCE: I've just tried to connect a simple MIDI interface
Here is a link to the best site in North America for wind synthesizers:http://www.patchmanmusic.com/WindControllerFAQ.html I am not a Mac user myself but it sounds like you might not have the threshold adjusted correctly on your Akai. It works differently when connected to external synths. Anyway I am sure you will find the answer on that site or in your manual. There is also a link on the site to download the latest updates.
Posted on Oct 25, 2010
djredskyy
  • 670 Answers
SOURCE: Akai MPK mini MIDI Controller Keyboard, 25-Key ...
I have the same keyboard, what do you mean from where it clips on. Do you mean the keys itself are broken? I'm not sure how you did that, but you can contact Akai and see if they will send you a new one. Those keys are supposed to be pressure sensitive and unbreakable. Please rate me for assisting you today! :-) PS I love that little thing!
Posted on May 09, 2011
Why are the Keys on my axiom pro 61 not sending MIDI messages?
Does your keyboard have a "MIDI OUT" port? If yes, then
there is a selection to choose between USB or MIDI OUT port.
For my M-AUDIO oxygen 61 (silver), I must press the [Advanced] button then Note F3 on the music keys manual to toggle the MIDI-OUT.
If set to INT, it will not sent via USB. If set to USB it will not send via MIDI-OUT port. To use MIDI-OUT port I need external 12V DC adapter.
Jul 29, 2014 | M-Audio Axiom Pro 61 Advanced 61-Key USB...
Does akai synthstation25 work on linux?
yes it does. i have it working with various midi soft instruments in avlinux. it's seen as an ALSA midi device. with alsa2jack (a2jmidid), it works with jack midi as well.
Apr 10, 2014 | Akai Professional SynthStation 25 MIDI...
Usb cable broken
Yes, you need to have midi in/out on your computer. Also you would need the optional AC adapter, which can be purchased separately from akai, in order to power your controller
Jun 18, 2013 | Akai Professional AKAI MPK88 USB MIDI...
Akai MPK mini MIDI Controller Keyboard, 25-Key ... my keysare broken from were it clips on
May 09, 2011 | Akai MPK mini MIDI Controller Keyboard,...
I plug two roland pk-5a to have 1 octave above the other one but the problem is I can't play in the BASS MODE or MONO MODE with the HOLD function on and stop the note I play on one unit when i play a note...
If you have two MIDI sources that you send on the same MIDI or to the same MIDI sound generator you have to use a "MIDI MERGER" or you will get notes stuck on. A MIDI merger assembles complete messages before sending them to their destination. Without it, the messages are mixed which makes them garbled.
Mar 24, 2011 | Roland PK5A MIDI Controller
I am trying to record sounds from my keyboard into my MPC 1000. I have what I think is the proper set-up. MIDI sync...softthru as track...etc. Problem is when I set it up I can play one sound and record...
It is not clear whether you are recording audio or MIDI. If you recorded Audio samples, you will get the same sounds back even if you change the voice on the keyboard.
If you record a MIDI sequence, and then play it back you will STILL get the same sounds UNLESS you also record the MIDI voice or patch changes so the voice is changed as it occured when you recorded it. Usually there are options taht you can enable or disable voice changes.
Feb 11, 2011 | Akai Music
Have a casio px 320 and trying to use it in GarageBand on my Mac OS X. Connecting USB cable from USB output on Casio to USB input on Mac doesn't work. Any help?
use the audio output to send the keyboards internal patch sounds, or use a usb midi adapter to use the keyboard to trigger the garageband midi sounds, if the keyboard has a midi output, that is. the usb output requires software drivers to use, and IS NOT mac compatible. You may have to select a midi source in garage band preferences or settings if you are using midi.
Nov 14, 2010 | Casio Privia Keyboard Case
I NEED TO KNOW HOW TO SET UP MY ROLAND JUNO D WITH MY AKAI MPC 1000, PARTICULARLY HOW TO SET UP THE MIDI ON THE ROLAND.
Simple way is MIDI out from Juno to MIDI in on MPC, then (depending on how you want to work), connect MIDI out from MPC to the in on the Juno. If you do this you MUST turn local control off on the Juno or else you'll get double triggers (internal + msg in from MPC). Now to record sequences on MPC , set MIDI to as track in setup window (on the 2500, this is accessed by pressing MODE then pad 9, then press button under the corresponding tab [on LCD]) then set your MIDI channel by port, meaning if your MIDI cable is physically connected to out A, in your LCD in bottom right corner it will show as follows: 1A. This indicates you are transmitting on MIDI channel 1; port A. Remember, MIDI IS NOT AUDIO!!!!! Since the Juno is a synth and not a workstation, all transport controls are handled by the MPC, that's pretty much it... Hope this helps a little, enjoy!
P.S. Go to mpc-forum.com its THE sh**! They also have links for their e-book I have one for the 2500 and its awesome!!!
Aug 16, 2010 | Roland Juno-D
Nov 09, 2008 | Akai Ewi4000s Electronic Wind Instrument
Akai Xr20 Xr 20 Beat Production Station,drum,new Logo
156 people viewed this question
Top Akai Music Experts
Michial Gueffroy
drivealot
Are you an Akai Music Expert? Answer questions, earn points and help others
