Question about Onkyo Audio Players & Recorders
Need code to control comcast cable and dvr box RN200 with my Onkyo 803m remote
Remote Control RC-803M, The codes listed in the manual do not work.
SOURCE: remote control not working and need programming code for cable television/universal remote control
remotes.com says oerseas item-not available?
Posted on Feb 24, 2008
SOURCE: onkyo Remote Controle Codes for XBoX 360
There should be a code on your remote index for DVD Player XBOX
Posted on Mar 30, 2008
IrishDruid
  • 2712 Answers
SOURCE: Onkyo remote RC 570M
You can find the remote control codes for different brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. - You can rate a solution with one of four ratings as explained under (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
Posted on May 05, 2008
SOURCE: Code for Sony BDP-S300 Blu-ray player on Onkyo remote
Player can be made to work without remote. But it is a pain.
You need to press pause then play in the right combination.and you can get both DVDs and Blu Ray disks to work. I bought a store floor model that did not have a remote. I went through the same problem when I would lose the remote for the HD-DVD player. My four year old daughter knows this trick pause pause play for DVDs and pause play pause play for blu
Posted on Sep 21, 2008
SOURCE: Programming the Acquos Remote
I got a a sharp LC-32D43U and for my motorola cable box i use hte code 31 from jerrold, i take it from the manual and i got it tryin every single code unti i get one that works.
Hope it works for you
Posted on Oct 21, 2008
My remote does not work
Remote Code for LCD Coby TV model TFTV2425 - Comcast Help and ...
forums.xfinity.com/t5/XfinityTV.../Remote...LCD-Coby-TV.../916553
Apr 14, 2011 - Remote Code for LCD Coby TV model TFTV2425 ... If your home entertainment device does not respond to the remote control after trying all of the codes listed for your ... I just changed to an hd box andcodes given by comcast did not work. Looked at my old remote notes and that is what I found and it works. Comcast DVR remote won't "select" an input from th...
May 26, 2011
Remote code for coby tvs
Feb 7, 2011
Comcast remote code for Coby tv/dvd
Mar 20, 2010
More results from forums.xfinity.com
Coby tv remote doesn t work Questions & Answers - Fixya
www.fixya.com > Forum > Tags > tv remote doesn t work
Dec 15, 2015 | Coby TFDVD2274 22 in. LCD TV
Onkyo rc-803m numbers for all elements HD TV
Hi Henri, please email me at askOnkyo@us.onkyo.com and I will email you the codes, Thanks, JT
Oct 08, 2015 | Onkyo Audio Players & Recorders
4 digit code Scientific Atlanta 8240HDC Cable box
0291,0265,02910. Try these codes. For more information http://electrohelponline.blogspot.com/ Setup procedure, and setup code list to many popular remote controls are given. Pull up older posts.
Dec 17, 2013 | Onkyo RC-693M Remote Control Part 24140693
How to program remote control?
Your Onkyo TX-SR304 receivers remote (RC-645S) is not capable of controlling devices by other manufacturers. It controls only Onkyo devices.
Other Onkyo remotes do have universal remote functionality and you can download Onkyo remote codes here.
I hope that helps.
________________________________________
Download Onkyo TX-SR304 users manual here.
Mar 26, 2010 | Onkyo TX-SR304 Receiver
Can't get my hannspree remote to work with comcast
10030 for the comcast dvr remote. Code is from NEC
Oct 02, 2009 | Hannspree HT09 28 in. LCD TV
Can't find a remote code for my onkyo rc-710m to control my dish network vip722k satellite/dvr receiver
Remote code will work but be sure you have VIP remote address set on 1. See page 56 of VIP manual or instructions on changing remote address.
Jul 25, 2009 | Onkyo TX-SR506 Receiver
Need code for comcast remote control
HI,
Could you kindly give the exact model of the comcast remote that you are using.
Thanks
Proton
Jan 03, 2009 | Philips 47PFL7403D 47 in. LCD TV
Sharp TV (LC52D64U) remote control Comcast cable (DVR) box ?
I had the same problem with my remote. I would enter the code and there would be no response from the remote. I looked up the manual for the other comcast remote and the codes are 5 digits instead of 4. Try codes 10093 or 11602. The reason why there is no response from your remote is because it is waiting for you to enter the last digit of the code. Hope this helps.
Dec 01, 2008 | Sharp Remote Control
There is a code out there to try.  The code would be 47.  Just follow the steps in your manual on how to program this box and you should be able to go from there. Can't garantee that it will work as that code came out with the newer tv but it should work.
Nov 08, 2008 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
Program Comcast remote to operate Samsung 46"LCD
Not sure which remote you're using. We have comcast Motorolla box and Samsung LN-T4671F. the code I used was 10812 and it works perfectly.
Go here for more and check the comcast section:
http://www.remotecodelist.com/remotes/
May 18, 2008 | Samsung TV Remote Control
37 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
